Question about JVC MX-D602T Shelf System
CD Changer hanging - JVC MX-D602T Shelf System
In a 3-CD changer system, the top (#3) tray gets stuck sometimes and will not open. When this happens, the other two trays also get stuck and no trays will open even though the mechanism is attempting to do so. If the power gets turned off and later turned on (next day or so), the CD's will play and all three trays can be opened and closed.
This problem first occurred within the last month of use with no previous problems. The system was manufactured September 1998 and was purchased new.
Thanks for any assistance you can provide.
  • 93 Answers
SOURCE: CD Changer & Tape Deck
Check for dirt on CD laser lenses. Also transmission on tape player.
Posted on Oct 03, 2007
  • 8 Answers
SOURCE: how to unlock protected mode on a jvc 5 disc cd changer?
cheack the speaker wireing.if thats not the pro i sugg the repair shop your unit could have over heated.
Posted on Mar 01, 2010
toolkits
  • 1099 Answers
SOURCE: HX-D7 DVD Compact Stereo Audio / Video System with 5 DVD Changer Shelf System: my jvc was working fine but all of a sudden it sto...
Hello
this could be a power fault, but first check the power plug if it is in contact with the power socket and if it is then you have to open the back cover of the system to check the fuses if blown resistor,capacitor and transistor with the use of a multimeter to check for back component and if bad replace faulty ones.
Then power on to confirm, if not on then take it to the manufacturer or a skilled personnel to handle it
Posted on May 19, 2010
gopakumarg43
  • 75178 Answers
SOURCE: I have an old JVC
Hello
There are two possibilies for this faut. The first one is related with its Laser Pickup Unit, and the second one is related to its loading mechanism. If loading mechanism did not load disc properly to to the holding disc drive motor, disc wont play, and will be ejected as it enters into the system. i don't know, how old your system is, and how much it used so far. Anyway try first by inserting a head cleaning disc into the tray and play it for two of more time. if this does not help you try replacing the loading belt. You have to open your system to do this work. Loading belt can be located at the loading mechanism, fastened with its loading gear and loading motor. If this also does not help you, there is no other way than replacing the laser Picup Unit with same type and number. To repalce either belt or laser pickup unit, you have to open and disassemble the mechanism itsef to do the work. If you are not aware in electronics, and not so experienced in doing this type of work, get help from an other who knows these well. Most of the [90%] of components used in this section are made of high density plastic, and can be damged easly. If any wheel in loading gerar mechanis has broken teeth with it, also will poise this probelm. So it also should be checked.
Anyway you have to open and disassemble the mechanism as a whole. OK
Posted on May 25, 2011
How could i find a replacement for my hx-d77/mx-c55 pcb amp board
Hello
Contact the nearest JVC Authorised Service Center at your town. They only can provide you the populated board. OK.
Jan 20, 2012 | JVC MXC55 500 Watt - 3-CD Changer Mini...
How to line up trays etc in the changer mechanism
There is a lot of timing that must be checked before the changer trays are assembled back.
You will need to check the timings setttings of the tray which must be set according to limit switch and the mode switch
Jun 16, 2011 | JVC MXKB30 300W 3-Disc CD Shelf System...
Have a jvc MX-J500. (purchased as a previously owned unit) When a cd is inserted in any of the three trays it just says "no Disc". Radio works as well as the cassette player. System was dusty but appeared...
You could try a CD lens cleaning disc which will clean any dust off the laser lens. But it is possible the laser power can be low if it is an old player. this will stop the discs being read fence the fault No CD as it cant see the disc. This will mean either a new laser assembly or complete CD deck. Try the cleaning disc first and if that does not work take it to a service centre or just use it as a radio cassette in the garage.
Jul 21, 2010 | JVC MX-J700 3-Disc, Triple-Tray CD Changer...
Cd changer repair
what is the problem?
Nov 29, 2009 | JVC MX-D602T Shelf System
Cd changer loading problem (panasonic sa-pm53)
Have a Panasonic SA-PM53 pulled a CD trays out to get stuck CDs out. So how do I get the 5 CD trays back into the carriage and in sync?
May 24, 2009 | Panasonic SC-AK78 CD Shelf System
Control board
This is not likely a control board issue. If hte CD changer is "out of timing", this problem can be seen. Are there any symptoms other than "no lights"?
Dan
Dec 02, 2008 | Panasonic SC-AK78 CD Shelf System
How to unlock protected mode on a jvc 5 disc cd changer?
Jan 06, 2008 | JVC HXD7 5-disc Home Stereo Theater System...
CD's keep getting stuck
It had to happen....
Af6ter having worked on more than 50 of these kinds of mechs i can definitely say they get old fast!
What you will need to do is realign the cd changer if you are willing to put about 4 hours work into this then let me know and i will see if i can hunt down the realignment manual for you.
Aug 19, 2007 | Panasonic SC-AK18 CD Shelf System
JVC MX-D602T Shelf System Logo
50 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
