Question about Hitachi 53UWX10B 53" Rear Projection Television
The TV will not turn on and the indicator light just blinks on and off and makes a beeping noise. What do I do?
3 Suggested Answers
SOURCE: TV makes chirping sound and power button blinks, T.V. does not turn on
Me too! help!
Posted on Apr 28, 2008
It is the lamp, you have to change the lamp, it's in the left side of the tv, have a litter compartiment, opened and take out two screw and take out the change and change it. you have to buy a new one. go to google.com and put the model of the tv and find the price of the lamp.
Posted on Jun 25, 2008
TV turned off by itself today, It initially makes a clicking noise, the green power light flashes and goes out after 2-3s hear 2nd click and nothing happens. No red blink lights, nothing.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Mar 25, 2016 | Panasonic Viera TH-42PZ80U Plasma TV
Sony Trinitron Tv shut off then made two beeping sounds and doesnt turn on anymore
Two beeps can be considered as two blinks. Blinks of standby light in Sony TVs are fault indications. Visit the site linked below to know more about the blinking codes and fault locations to Sony TVs. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Nov 30, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Won't turn on. Light flashes and makes a whirring noise
do you mean the light indicator in the front panel was blinking?. how many time does it blinks and can you give us more info about your tv, the brand as will as the model no. it was located at the back of your tv.so we can give much better solution to the problem.
Nov 17, 2012 | Televison & Video
Sony Bravia KDL-42V4100 42 in. LCD TV made a popping noise and then shut off and will nor turn on and red LED blinks 2 times..
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jul 17, 2011 | Sony Bravia KDL-42V4100 42 in. LCD TV
Monitors will not turn on due to a power spike. Tower makes a beeping noise with a red blinking light. What could be the problem?
The moitors did not turn on at all after the power spike?
If that is the case, probably some electronic components were burned due to power surge damage.
I advise you to contact the manufacturer for repair and your local electricity supplier.
The beeping noise and the red blinking could be indication that no monitor is plugged in.
Jul 06, 2011 | HP xw6400 Workstation - 2 x Intel Xeon...
All three lights turn on like normal and then nothing
Depending on the pitch. humming noises are either a motor ie: fan motor or if it is very low a defective capacitor . Since you have the yellow band and the high pitched beep my fist thought is somthing defective in the power supply. Take it to an authorized servicer.
Apr 07, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
TV wont come on screen black
i would say signal board ....or maybe short in the fly back section of the board...but my first suspicion would be check the signal board.....hope this helps
Sep 13, 2008 | JVC HD-61Z575 61" Rear Projection...
Strange beeping noise
I read on another site that if the indicator on the dash is malfunctioning and there's a fault code in the system, the beeping is a secondary indication that there's a need for service. I've had my air bag light blinking for some time now. Yesterday my gauges went out, Oil Pressure, Gas Level, Temp Level, and the Battery Charging Meter, all went dead. After starting the vehicle, it beeps 5 sets of 5 beeps. Since the dash obviously has problems, (Including the Air Bag blinking thing not working), the beeps I now hear are what you are experiencing. However, if you still see the air bag light blinking, maybe your situation is a bit different than mine.
Jul 22, 2008 | 1994 Ford Aerostar Extended
When the TV is swith on,the clicking like noise and the red indicator blinks continuesly.
fly-back has a leak im sure with that.try to check the flyback for blue colored current that goes out from it. this causes the noise, if it has then you can use a sealant to seal the leak
Mar 30, 2008 | InFocus SC-MOTGRY-106H MOTORIZED SCREEN
Tv wont turn on only clicks and then flashes red timer light
Well, I have found out that the number of red light blinks is a "blink code" that indicates the nature of the fault with the TV. Usually these are various failures of internal fuses or circuit boards. There's a fair amount of information on threads at techlore.com on this, so try searching there. Teh specific codes and manuals are usually it seems under license from Sony and not available for free to the public. Sorry!
Oct 17, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
