Question about Philips 50PFP5332D 50 in. Plasma Television
I have a Phillips 50pfp5332d, under 2 years old and it just died at 3pm today. checked circuit breaker, remote batteries, tried a new outlet and nothing. the blue light that's usually on in the bottom left corner is nowhere to be seen. any initial recommendations would be appreciated. thanks. Scott
  • Philips Master
  • 8,457 Answers
Replaced the power board,it dead,or might check for pop up capacitors,replaced it.
Posted on Nov 22, 2009
    Sergeant:
    Champion:
  • 245 Answers
2 YEARS AND DEATH......
WELL I HOPE U HAVE A EXTENDED WARREN TIE AND IT WILL GET FIXED FOR NOTHEING
IF U DON'T HAVE THIS IT WILL COST U APP. $1000 FOR A NEW SCREEN
HOPE THIS IS NOT THE CASE BEST TO CALL A SERVICE AND GET IT CHECKED OUT......EVEN A PHONE CALL TO PHILLIPS MAY HELP
Posted on Nov 20, 2009
Gas oven tripping breaker
Get an electrician in, do mess about u could burn the hse down. Wiring probably cann't handle the specialist load.
Aug 26, 2012 | Kenmore Kitchen Ranges
Fan was running on Low, we left the house for about an hour, when we returned the fan was off. Fan does not work, nor do the lights. We even tried new batteries in the remote and the circuit breaker. We...
remove the ceiling cover cap , and check for power at the unit in the ceiling box, if you have power there, go to the switches on the unit, check the wires coming out of the switches, if you have power there, your motor has probably died , but before you give up all hope, disconnect the remote receiver, and check the same items with the receiver out of the loop,, be careful,, the fan may just start up !!
Jul 20, 2011 | Hampton Bay 52 In.Carriage House II in...
My lg refrigerator just gave out. Its plugged in but its not working. I have checked the circuit brakers and everything is fine. Is this fixable or do i need a new fridge? I have owned this one 2 years
I had this problem a while ago. It may not be the circuit breakers but the outlet where fridge is plugged may have gone bad. Plug fridge into another outlet and see what happens. A 2-year old fridge is almost brand new.
Jan 23, 2011 | LG LSC27910 (265 cu ft) Side by Side...
No power
If your television has no power, try the following:
1. Check the power cord for breaks, tears, or exposed wires .
2. Check to be sure that the power cable is fully inserted in the outlet and that the outlet is working.
3. Go to your fuse box or circuit breaker box and check the fuse or circuit breaker of the circuit your TV is plugged into. Replace the fuse or reset the breaker if necessary.
4. Replace the batteries in the remote control, and then try turning on the TV using the remote.
5. Unplug the TV, wait five minutes, plug the TV back in, and then try turning on the TV.
If the recommendations above do not resolve your problem, most likely the power supply in your TV has failed and your television needs service.
Thank you !!
Jun 04, 2010 | Hitachi 55PMA550 55 in. HD-Ready Plasma...
61" samsung won't turn on???
If your television does not turn on, try the following:
If the recommendations above do not resolve your problem, most likely the power supply in your TV has failed and your television needs service. To begin the service process.
Sep 01, 2009 | Samsung HL-S6187W 61 in. HDTV
Washer stopped mid-cycle, water in the bottom of the tub. Circuit breaker popped due to over-load. Reset breaker and it immediately popped again. Could this be cause by a jam in the grinder assembly?
My dishwasher just quit mid cycle. (still has water in it) It is a whirlpool partner 1. I checked the breaker and it wasn't tripped... but i reset it anyways. When I tried the dishwasher again it worked for a second and turned off. I have done reading about the thermo fuse but can't find it. Not sure how big of a problem this is.
Dishwasher is 5 years old.
Thanks,
Dale
Jul 02, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
My Mitsubishi Plasma Won't Power On
it is very possible that it has died. If you can, try taking it off the wall and plugging a lamp in to make sure the outlet works, even thou you said that you have checked your circuit breakers. Sometimes the outlet can die without even setting the circuit breakers off. I would still leave the mount on the wall
Apr 05, 2009 | Televison & Video
No electricity in all bathroom outlets
you may have agfi outlet in the circuit. the outlet has 2 push buttons in the middle. it maybe an outside outlet that is tripped some contractors hook up the circiut like that
Mar 09, 2009 | Siemens Electrical Supplies
Bosch SHU3306UC dishwasher stopped
Make sure you visit the Bosch dishwasher recall website as this model is under the recall with a faulty controller which may cause a fire! Check your model under http://microsites.boschappliances.com/safetyrecall/dishwasher/
then call 800.856.9226 to setup a recall repair appointment. We just found out about this recall and was never notified by Bosch even though we registered our unit after we purchased it...talk about poor customer service! Hope this helps!
Sep 04, 2007 | Bosch SHU3306UC Built-in Dishwasher
Philips 50PFP5332D 50 in. Plasma Television Logo
305 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
