Question about ASUS Eee PC 900 PC Notebook
How can I split the use of my hard drives more effectively? My struggle with my C drive constantly to keep it over 300 M while my D drive sits there with over 5 G. The whole system pauses a lot because of low disk space. I bought this little thing because the salesman said it would be great for Java programming but not if it can't install and run everything from my D drive. Can I utilize this a little better? The salesman had no idea.
    Genius:
  • 1,584 Answers
Need to know what size each patition is. Double click on "My Computer" and see how many drives are listed, normally C, D but if you also have an E then its patitioned. Right click on each to see how big they are. The only way to re-organise a pertition is to back up all info / format the drive and re-organise the partition to about 50/50. You can get aftermarket partition makers but will cost you, Another suggestion is to transfer all pics, docs etc to the other partition so that only programs are running in C drive and nothing is stored on it.
Posted on Nov 20, 2009
Testimonial: "Thank you very much for your fast response. I will check the partitions now."
Continuous blinking
MY LG LSD TV SCREEN IMAGE IS CONTINUALLY BLINKING AND A GREEN VERTICAL LINE ABOUT 3 IN SHOWS CONSTANTLY IN THE SCREEN
Jan 08, 2014 | Maxtor OneTouch III 300 GB Hard Drive
Define hibernation & stand by
Hibernation: The computer saves all data currently in memory and all open programs just as they are. It freezes everything in a way. All the saved programs and data are written to the hard drive for storage. That way the computer can sit for a long time without drawing power to keep the open programs and data saved. However, it will take a longer time to wake up the computer.
Standby: The computer does not save open programs and data to the hard drive. Instead it keeps everything open and simply goes into a super lower power state. The memory receives a constant stream of minor power so that it can keep the programs and data in memory until the computer is woken back up. The computer will wake up much quicker but will draw power slowly as it sits in Standby mode.
Nov 05, 2012 | Computers & Internet
My laptop keeps blue screening point to hard drive issues
have your hard drive tested for errors you may use HD-tune for your own testing, if it pass the test, you may need to replace your laptop hard drive interface assembly or check your ddr memory for defects also..
Feb 09, 2011 | Hitachi Travelstar 5K500.B HTS545050B9A300...
The laptop makes a constant clicking sound
Sounds like the hard drive is having problems. Try running CHKDSK to check for errors and a good anti virus programme if that has no effect, try saving your data to another drive before it is lost and then fit a fresh hard drive loading your programmes back on.
It is a laborious task but better than losing all of your stuff!
Oct 16, 2010 | Acer Aspire 5610 Notebook
Hard drive noise
"hard drive noise" is much to broad. Need a better description. However, if the noise is constant then it is probably due to bad bearings. If so, it can't be fixed by the user.
May 31, 2010 | Hitachi 500GB 7200RPM 16MB BUFFER SERIAL...
I cant erase the files in my hard disk, if i erased it, it's keep on comimhg back..what will i do?
INFO:
Files are never really erased from a hard drive.
At various stages files are always recoverable.
RECOMENDATION:
To truly erase your hard drive take it out and completely destroy it down to many small parts.
Reformat the hard drive.
Hope this tip helps.
r/
David
Mar 11, 2010 | Seagate 250GB Maxtor DiamondMax Plus 21...
Emachine locked up won't start
Hard Drive Clicking = Going Towards End Of Life
Put the hard drive in a working pc and get any important data off it , its about to die!!!!!!!
Get a new hard drive and do a windows reinstall (not like you have a choice)
not sure about the rest though sorry
Jan 04, 2009 | E-Machines eMachines Desktop PC
Help!Help with external hard drive?
Your disk drive is a delicate instrument, it will react negatively if dropped on the floor.
However what you might try all be it rather radical in this age of micro fine technology is. take a deep breath and sit down. Take the disk drive in your left hand with the edge of the drive that struck the floor facing away, make a fist with your right hand and strike the opposite edge with with almost equal force.
The reason behind this is simply that when you dropped your drive on the floor the heads got jammed either into the disk spool or out side of it,
If you have to pay $300 for disk recovery you cannot be doing much worse than trying this before you have to.
Oct 20, 2008 | Maxtor OneTouch II external hard drive...
Using external hard drive for running applications.
FOLLOWING THINGS U SHOULD KEEP IN MIND WHILE GOING FOR EXTERNAL HARD DRIVE :-
1. PURPOSE OF EXTERNAL DRIVE - MEANS U WANT TO KEEP THAT TO USE IT FOR BACKING UP OF DATA?
2. DO THE COST EFFECTIVENESS OALSO EFFECTS UR PURCHASE?
3. TELL THE SPECIFICATION OF UR PC TO THE VENDOR BEFORE U BUY A NEW EXTERNAL DRIVE, AS IT MAY NOT SUPPORT SOME TIME.
4. ..... MAYN MORE...NOT COMMING TO MIND NOW... :-)
Apr 11, 2008 | Computers & Internet
Seagate 300GB ST3300601U2-RK
usb cable provides power to your hard drive.
try to use new cable.
hopes it works.
pls. confirm
Jan 30, 2008 | Seagate (ST3300601U2-RK) (ST3300601U2RK)...
ASUS Eee PC 900  PC Notebook Logo
65 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
