Question about Toshiba TW40X81 40" Rear Projection Television
The images on my TW40X81 have a RED halo on their left side (viewers right side) I have done the electronic convergence but the red will not adjust left, to the "Merge" cross hairs. it will move right,up and down and when I have adjusted it as far right as it will go, It will re-adjust back to the left. Just not far enough. Is there a mechanical adjustment to "Tilt" the lamp/lens back to within adjustment range? jackjames@fmtcblue.com
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
If Red will not move far enough you have one of three things wrong----if the two convergence chips have never been replaced--they are Q751 & Q752 and are black in color---
About 2 1/2 inches wide X 1 1/2 inches tall and mounted side (ON LARGE METAL HEAT SINKS WITH FINS) and they will have the STK-392-110 PRINTED ON THEM IN WHITE.
Either one of them is bad, or one of the 1.8 ohm resistors around them is damaged and off value OR you have a problem in the digital convergence unit--it stores and controls all the convergence adjustments.
I suspect based on your description one of the two chips damaged one of the protect resistors---
You can if you are able to do the repair yourself buy a pair of the chips on Ebay for about 12 dollars plus shipping--I do this for a living and have repaired hundreds of sets with convergence problems.
Let me know if you have questions or need advice--I am here to help people.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Posted on Nov 20, 2009
Is there a code number that needs to be entered to bring the convergence pattern or menu on screen.
From a user standpoint you would follow these steps to bring up your Convergence menu:
1) Press your MENU button.
2) Press the Right Cursor Button to enter the Picture menu.
3) Press the Down Cursor Button until you highlight the MANUAL CONVERGENCE choice on the menu.
4) You will then see the following choices on the right hand side of the menu: Convergence Red, Convergence Blue, Multipoint Red, Multi Blue, Save Multipoint.
5) Once you choose either the Red or Blue choices you will get a crosshair in the middle of your screen. You will then use either your Up, Down, Left, or Right Cursor buttons to get the two images to line up correctly. If you still have multi images on your screen in either Red or Blue you would then have to adjust the Multipoint choice for that color.
May 14, 2011 | Philips 51PP9100D 51 in. Television
Left side of sreen is blurry/halo effect. Right side is normal. Magic focus stops when it gets to green and flashes green number 3 on bottom left of screen.
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 08, 2011 | Hitachi 51F500 51" Rear Projection...
Double images, especially with red.
hi.
double image is caused by a faulty convergence circuitry. It needs repair, if you have a basic knowledge in electronics you can do it, just replace it with the new convergence kit.
Nov 22, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Double image, blue adjusted, red won't adjust
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 19, 2009 | Philips 51PP9910 51" Rear Projection HDTV
Mitsubishi - cannot converge red
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic2_bing.gif,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Dec 13, 2008 | Zenith R49W36 49" Rear Projection HDTV
Double image in bright blue with philips model 55pw9363/17f
You may have 1 of two problems.
1) Convergence Chips are failing - Using your original remote goto the "convergence" screen.
Try to adjust the red - UP - DOWN - LEFT - RIGHT
Next try to adjust the blue - UP - DOWN - LEFT - RIGHT
If you can move both colors in all directions you do not have a convergence issue.
If you can't move one or more colors in one or more directions the convergence chips are defective and need to be replaced.
If your convergence chips test out ok the most likely problem is......
2) CRT Coolant is cloudy  - The bright outline you described is one common symptom. Other symptoms include dull images, red or orange tint, halo around images.
If you goto the site www.TvRepairKits.com - and click on "Tips" - you will find more detailed instructions on how to check the convergence.
Dec 04, 2008 | Philips 55PW9363 55" Rear Projection...
Convergence issue
try fixing the convergence 2 after your've aligned the convergence 1 - the second (accessed via the set up control) let's you adjust on 9 different axis to align the red and blue tubes to the green. you select which + sign you want to adust by pressing the corresponding number for the + ie 1 for the top left, and 9 for the lower right corner.
good luck (note - you cant change the green only the red and blue, if the whole edge is a mess try moving the image (you need to be in zoom mode, and then access the position adjustment via the pitcure set up screen.
Nov 05, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Double picture on left side with red projector on Hitachi 55UX58B
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Oct 20, 2008 | Hitachi 55UX58B 55" Rear Projection...
Blue Halo, Tried to adjust on Projection TV
The convergence issue you have will not adjust out....repair
of the convergence circuit will be necessary....then adjust...T.
Dec 01, 2006 | GE 46GW947 46" Rear Projection Television
Toshiba TW40X81 40" Rear Projection Television Logo
169 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
