Question about Whirlpool Dryers
Dryer heat cuts out after 10 min. please help tested thermostats and element. cleaned out lint where eve i could. what else could it be
  • Whirlpool Master
  • 1,606 Answers
Pull the dryer out , and remove the vent hose from the dryer . Dry a load of clothes , and see it it dryes in a suitable time . If so , then a vent problem , either kinked hose , outside vent blockage , or if an up vent thru the attic , then possibly blocked . A dryer either heats or doesn't , and excessive time , indicates a venting problem .
Posted on Nov 20, 2009
Samsung electric dryer keeps burning up thermal cut-off thermostat
I am not familiar with the model.
That the thermostat keeps failing, due presumably to overheated/burned contacts does indicate the element is drawing too much current. I can think of no other reason to explain your experience except possibly there is excessive arcing at the contacts as they open and close. The addition of a suppressor capacitor might help but the big question to be answered is why is there too much current or excessive arcing...
I can only suggest you thoroughly examine the heating element looking for breaks and accidental short circuits between the coils of the element or connecting wires.
Feb 28, 2017 | Dryers
Dryer stops tumbling, but heating element stays on
Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat
May 18, 2008 | GE DBXR463EBWW Electric Dryer
Heats spins but doesnt dry. its clean and lint free there is no exterior vent on it bosch axxis v20-ul thx
If you have heat, then it's an airflow issue as inside your dryer you have several thermostats, one is called the high limit thermostat, when the dryer can not vent properly, the heat builds up in the dryer and this thermostat cuts off the heating element for safety reasons, and the heat may not come back on for 20 minutes, I understand there is no exterior vent but the dryer does vent air. More then likely once you take the dryer apart and clean the lint out of the inside it will run correctly. Hope this helps Tim
Mar 11, 2011 | Bosch Dryers
Where would the fuse be and how hard to get to, is it in the upper unit? From behind? or lower unit? Running but no heat.
The problem is obviously in the heating circuit which is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components.
Disconnect power then access the thermal cut-off (cut-out) and the high-limit thermostat. Disconnect the wires of each component then connect them together and insulate it properly. Reconnect power then start the dryer. The problem is indeed in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make. Indicate the exact model number of the dryer should you need further assistance.
Dryers with lint filter on the front.
Dryers with lint filter on the top.
Also bypass the cycling thermostat if the dryer still doesn't heat with the thermal cut-off and the high-limit thermostat bypassed. Check the heating element visually for obvious broken or damaged coil. An ohmmeter will be of great help in checking the resistance/continuity of the heating element. Replace the heating element if broken or damaged, NEVER attempt to repair it.
The problem is likely in the motor centrifugal switch if the dryer still doesn't heat with good heating element and the three components above bypassed. Indicate the exact model number of the dryer should you need further assistance.
Feb 01, 2011 | Dryers
Dryers tumbles but there is no heat
Dec 31, 2010 | Kenmore 600 6965 Electric Dryer
Replaced heating element/worked for 10 min now doesnt
Howdy: Check the thermostat on the inside in the back. If unpluged or lint is clinging to it , the unit will shut off heat. Please inspect. Good luck - It also could be defective. - Doug
Dec 09, 2009 | Kenmore Dryers
Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Jun 28, 2008 | Whirlpool GEW9250 Electric Dryer
Dryer runs but doesn't heat up when sttings call for heat.
You may need to do some troubleshooting. This can be done with the machine unplugged - you may have to activate the start switch, belt switch (if it has one) and the motor centrifugal switch manually.
Tip for troubleshooting 220v systems - clip one lead of a ohm meter to either L1 or L2 on the terminal block. It doesn't matter which one. According to the tech sheet (under console) follow the path for current from your clipped terminal, through the heating element, to the opposite terminal. All the readings should be less than 100 ohms, until you reach the failed part. Confirm failure by disconnecting a lead from the suspected part, and test only that part.
Live troubleshooting is sometimes slightly easier, but much more dangerous than the procedure described above. - It is definitely not recommended for beginners, or for professionals, if it can be avoided.
Mar 08, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool Model LE7010XSNO. No Heat After Lint Cleaned Out
Those are likely possibilities. Also check the wiring for disconnected or burned terminals especially in areas that get hot. The element comes out easily to visually check it for breaks. If that's OK I'd look at the safety thermostat.
Jan 06, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
62 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
