Question about Canon Rebel XT / EOS 350D Digital Camera
What is err02 and how do i fix it I have tried 2 different and new cf cards. Am I even close to the problem
  • roudesign
    roudesign May 11, 2010
    Err 02 means there's a problem with the memory card. It can be corrupted card, a bug, incompatibility issue, and so on. Try 3 or 4 different brand of memory card from what you have now and see if it works.Try to reset the camera to default, reinsert the battery, and try to take a shot without the card, (after you selected that as an option), see if it take the shot, without any error. if it does is probably a problem with the card module or with the card .I believe can be also a mechanical issue with the pins inside of the card slot (you can visually check the pins, maybe you have one misalign, bended, or broken), or a loose ribbon contact between the card assembly and the main board.What brand of cards you tried by now?, some are going very bad for no reason.need more details.
KARAOKEKATE
  • 3 Answers
SOURCE: CF Card not being detected
Jerseygirl98 does your computer reckonize the card if not it may be a bad card. That does happen..I the computer does right click on the card and rename it .JERSEYGIRLCAMERA
THEN LOOK FOR IT..Try to format the card in the computer..No luck just get another card..
Posted on Dec 25, 2007
  • 225 Answers
SOURCE: cf card reader sony a 100 dslr
Buy a camera that does not use CF. Time to upgrade.
Posted on Nov 13, 2008
Gryfox
  • 216 Answers
SOURCE: I am getting a ERR CF with my Rebel XT
You've probably gotten bent pins in the camera. Has to go to the shop.
Posted on Nov 27, 2008
  • 3 Answers
SOURCE: NIKON D100 LCD DISPLAY FLASHING CHA ERROR WITH ANY CF 1 GIG
I had the same problem and thought I had looked closely at the pins in CF slot but after finally taking it to a repair shop, the tech showed me a bent pin. It really wasn't that apparent first time around. He told me its a common problem as long as they use the CF cards. I had the pins replaced and my D100 is working great. Best of luck.
Posted on Mar 30, 2009
  • 126 Answers
SOURCE: Unable to format CF card
Try formatting it on your computer...make sure you are formatting "that" drive and not your C drive.
Posted on Mar 19, 2010
Canon Si5 Lens Error message. Have tried suggestions on line
Welcome to FixYa.
There where wo reasons why do you receive a "lens error".
1. CF card slot cover or battery cover opened with camera on
2 . CF card slot cover or battery cover opened while camera was recording to CF card
In this case you have to ensure that CF card cover and battery cover is closed while camera is turn on.
You also need to be careful not to block the camera lens when turning on. Lens will have issues while retracting if your hands or even small thing that will block the lens to retrack while in motion of turning on.
Thank you for using FixYa.
Apr 08, 2011 | Cameras
I get a memory card error even though it has a card installed
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a70#ServiceAndSupport
Issue: Memory card Error
Solution: Try a different memory card and/or Reformat memory card PowerShot A70
Formatting a CF Card You should always format a new CF card or one from which you wish to erase all images and other data.
caution_a70.gifPlease note that formatting a CF card erases all data, including protected images and other file types. Please check the contents of the CF card before formatting it.
  1. Turn the power on.
  2. Press the <MENU> button and select [ tools_icon.gif(Set up)] using direction_arrow_lt.gifor direction_arrow_rt.gif.
  3. Select format_icon_a70.gif(Format) using direction_arrow_up.gifor direction_arrow_down.gifand press the <SET> button.
  4. Select [OK] using direction_arrow_lt.gifor direction_arrow_rt.gifand press the <SET> button.
    • To cancel formatting instead, select [Cancel] and press the <SET> button.
    • The capacity of the CF card displayed after formatting will be less than the rated capacity of the CF card. This is not a malfunction of the CF card or camera.
  5. Press the <MENU> button.
  • If the camera does not work properly, the inserted CF card may be malfunctioning. Reformatting the CF card may solve the problem.
  • When a non-Canon brand CF card is malfunctioning, reformatting it may solve the problem.
  • CF cards formatted in another camera, computer or peripheral device may not operate correctly. When that happens, reformat the CF card with this camera.
Aug 03, 2010 | Canon PowerShot A70 Digital Camera
Mar 21, 2009 | Nikon D100 Digital Camera
Err CF then Err 99 - Canon Rebel XT / Hitachi 4GB Mircodrive
Nope, this is not card anymore.
As you know CF is card failure, sometimes this cause to start error 99 , that is lens error , even if there is no problem with the lens.
This happens because the built in software in the camera can get messed up after an error CF.
You fix the problem calling Canon, they will guide through upgrading the firmware in your camera.
First ensure that you are using the camera menu and command to format the new card, and that new cards are properly inserted into the machine.
Call Canon support to get a firmware upgrade.
Feb 13, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Not all CF cards are created equally, so yes, it could be your batch of cards. To determine if the error is CF related, and not anything else, try the following steps which are used to diagnose err 99's
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Feb 13, 2009 | Canon EOS 30D Body Only Digital Camera
Sony Alpha 100 gives error message when attempting to take pic.
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. I was getting the same error message as reported above: "Unable to use card" then "Format?" then that format fails. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.]
Best regards - Michael
Jan 07, 2009 | Sony Alpha DSLR-A100 Digital Camera
Err 99
Hi Ben ,
To isolate the cause of the issue, we suggest that you do the following:
4. Insert a fully charged battery, and turn on the camera.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
camera should be serviced.
Let me know if this worked, if not then the camera is dead and it would require some service or a replacement
Thanks
Proton
Aug 07, 2008 | Cameras
CF error
My canon xti had the same reading cf card error 99.
Since my camera is out of warranty. I had to find a way to fix it. After reading all possible solutions in this site, I looked at the pins (that used to connect to the CF card) and found out that one pin in the middle bent. That caused the problem. I used the tiny screw driver to bend that pin back to the original position. Inserted the card back and it worked. I felt so happy!!!! (Please make sure to have the battery removed while fixing...to be saved.)
Dec 28, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Can't power on with CF card
Buy or borrow a new Cf card. These cards, even when all the pins etc. are fine, often fail internally. They are not, as many people believe, a totally foolproof way to store data. If you get a similar problem with a different NEW card then you have to get the camera repaired professionally. Also to try would be reading your suspect card in a card reader on a pc or in another similar camera to see if you have similar problems - confirming if the card is the problem. However if the card seems to work fine in other appliances, it is probably the camera that is the problem, although Cf cards can be temperamental like that especially when they get a little old.
Dec 24, 2006 | Canon PowerShot A75 Digital Camera
Camera turns off
1. Try the camera with a different CF card. 2. Try the camera with a different battery. Defective components don't always fail in expected ways. The battery might have enough power to "sometimes" operate some functions but not consistently. The CF card may be malfunctioning is some way that draws too much power from the camera & at times causes it to "lock-up" or shut down. If you don't have another battery or CF to try, you may be able to bring your camera into a camera store where they may have & let you try 1 of each on your camera to see if it fixes the problem. They may do this in the hopes of selling you either a new battery, CF or camera depending on which proves defective.
Jan 07, 2006 | Fuji FinePix A605 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
74 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
