Question about Hotpoint RGB528 Gas Kitchen Range
I followed all the directions in converting from natural to propane gas on my stove and range. The oven works well. However, at any given time one or two of the top burners switches from the blue flame to a hissing yellow flame. What do I do to fix that?
  • savvyrebel Nov 20, 2009
    How do you purge all the air out of the lines?
  • savvyrebel Jan 04, 2010
    Neither has worked at all. It now has burned a hole through the burner and only burns yellow and uncontrolled flame
  • 770 Answers
Usually there is a rotating air inlet on the gas tube to the burner. It is typically held in place with a small "set" screw. Loosen the screw slightly and with the burner lit, adjust the air flow for optimum flame. Good luck...I hope this is very helpful.
Posted on Nov 20, 2009
  • 15,935 Answers
Is all the air purged out of the lines properly?
Recently acquired an older Hot Point Cooking stove with self cleaning oven. Need to know if I can convert to propane and how to do so. There were no manuals with the stove..
Stove conversion natural gas to Lp - YouTube
? 6:08
https://www.youtube.com/watch?v=iXX2mS6FrxI
Sep 2, 2014 - Uploaded by Clay Rogers
If anyone can do it so can you. ... Stove conversion natural gas to Lp ... How to Convert Your Natrual Gas ...
Nov 15, 2015 | Kitchen Ranges
I've just converted my stove from natural gas to propane and the oven and broiler flame are both to high, how can I lower them?
When converting from natural gas to propane you have to switch the regulator to propane. then on most modern stoves you have to turn the orifice hoods down to adjust for the higher pressure of propane. there are some stoves that you have to purchase a propane conversion kit with different orifices for the burners and oven burners.
Oct 01, 2015 | Kitchen Ranges
I have propane. Is my range set up fpr natural gas or propane and do i need to change. I'm having issues with my oven
without knowing your model number or mfg it's tough to say 4 sure but i can say that most common mfg do offer a propane conversion kit to use there gas stoves on bottle gas , most often it's a new regulator to install
Jan 08, 2015 | Kitchen Ranges
How do I know if my Caloric Heritage gas range is propane or natural gas? It is a used stove that was given to us
Stoves are usually sent from the factory set for natural gas. they have to be converted to Propane. If it is set for propane the flame will be very low on natural gas. If set for natural gas on propane the flame will be very large. The orifices for natural gas are much larger than propane orifices. and the regulator is converted acordingly.
Nov 10, 2014 | Kitchen Ranges
I have a Frigidaire Stove, Model # FGF316ASA. It was changed from propane to natural gas. The oven works well. The burners, however, will only burn a low flame. Is there a solution for this?
When converting an appliance from propane gas to natural sometimes a technician will drill the orifice to a larger size rather than replace the orifices. Either way is fine, but sometimes the orifices don't get drilled to the correct size. The regulator must be on the propane setting if it is a convertible regulator. If your oven is working fine.... the top burner orifices probably need to be checked that they are the correct size. A simple fix.
Tom
Aug 11, 2010 | Frigidaire FGF316 Gas Kitchen Range
My new gas stove (propane) is releasing black soothe when lit. All the pots are covered in this black powdery like substance. Whats the problem and how can i fix it. It's really costing me a lot to clean .
All gas stoves are set up for natural gas. Before using on propane, the oven and burners need to be converted for propane operation. Refer to the installation manual for conversion requirements for your particular stove.
Dec 25, 2008 | Kitchen Ranges
CONVERTING TO PROPANE FROM NATRURAL GAS
just need to change out orifices in gas line natural gas company should have new ones in stock
Aug 23, 2008 | Tappan TGFS_63 Gas Kitchen Range
Propane coversion of kenmore 790 gas range
Most gas stoves are shipped for natural gas .You need to check the orifice on each burner to see if they are for natural gas or propane.If you ordered propane the stove should have been shipped with the orifices.They may be in a bag with your stove documents.
tk46
Jul 13, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
GAS RANGE
Msmaytag it sounds like the oven wasn't converted properly if at all to propane. If you look at the bake burner while the oven is on you should see very little yellow on the flame. If you see mostly yellow, try adjusting the air to more open. This will changed the air/fuel and may resolve the issue. If not, follow the directions for converting to propane and see if the orfice hood was either replaced or tightened down. I am not quite as familiar with the maytag is why I ask you to follow the directions. The issue with propane is that it runs at 10wc instead of the 5wc of natural gas. So double the pressure, you need more air to thin the fuel. Hope this helps.
Jun 13, 2008 | Kitchen Ranges
Converting GE XL 44 Gas range from propane to natuiral gas
I needed parts for my GE XL44 propane converted stove. This site was very helpful. I found the part and there is online live help or toll free help. Go to: AppliancePartsPros.com
Thanks,
nnb704
May 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Hotpoint RGB528 Gas Kitchen Range Logo
66 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
