Question about Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive
Want to reformat for another user - Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive
Shiela65 Is correct on thesolution other than the last sentence...Formatting doesn't reduce the life of a hard drive any more than any other writing operation. A format erases critical areas, such as the boot sector and partition table. This gives the appearance of an empty disk to the operating system, making any existing contents unavailable by normal methods.
Posted on Jun 16, 2010
  • 2,973 Answers
Firstly why should you want to reformat the HDD is not clear to me. Anyway, since you want to do it well read on. Go to Start->Control Panel->Admin Tools->Computer Management->Disk Management. here you will get an option to manage your disks whether fixed or removable. Select Removable and select your external disk. From the right pane select the disk that you want to format and right click on it. If it is formatable (which your disk is) it will give an option og formatting. Select and follow the advice. If it does not show then select properties and there you will be able to format for sure. But remember that unless you format the HDD very many times, one can come to know that the HDD is a used one and can even retrieve the data from it. And if you format it so many times then you are reducing the life of the HDD. So the choice is yours.
Posted on Nov 20, 2009
Wd my book re format for mac
from pg 68 of the user guide.
Reformatting the Drive
Go to
http://support.wd.com
and refer to Knowledge Base answer ID 3865 for
information about reformatting the drive.
See "Troubleshooting" on page 66 for more information about reformatting a drive.
Restoring the WD
Software and Disk Image
After you have reformatted your drive for use on Mac computers, go to
and see Knowledge Base answer ID 7 for information about
downloading and restoring the
Mac versions of the WD Driv
e Utilities and WD Security
software and disk image.
The WD SmartWare software is not available
for Mac computers with this drive model.
Jul 05, 2014 | Western Digital My Book Essential Edition...
Forgot my password
Lost Windows password:
  • Log in as Administrator (try safe mode if you don't see Administrator).
  • Login as other user (if other user is availible) and manage users.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
Aug 31, 2012 | Computers & Internet
I need to fix my gateway password
  • Log in as Administrator (Try safe mode if you don't see Administator).
Aug 29, 2012 | Gateway MX Computers & Internet
I forgot my password to open this jump drive.My computer will not let me gain access to any of my files on the disk. What can I do to access it again?
Retrieving a forgotten password on a Cruzer Enterprise drive How do I recover the password on my Cruzer Enterprise drive? Password hint
If you set a hint when you enabled the password protection, click Hint in the log in window to display the hint you entered. If you did not set a hint or still can not remember your password, you can click Forgot Password on the logon window and choose a new password. This will reformat the drive.
Reformatting will delete all files and applications in the user-accessible removable partition.
Password attempts
There is a limit of 10 attempts (default) before the drive is locked and no further access is possible. During this process, you MUST change the password and reformat the drive. This is an important security feature, protecting data in lost devices from brute force hacking attempts.
Cruzer Enterprise drive managed by CMC (Central Management and Control)
A drive managed by the Cruzer Enterprise CMC software can be unlocked remotely by the System Administrator when it is inserted into an online computer. The System Administrator can unlock the drive remotely even after the maximum failed password attempts has been reached. The user must then choose a new password. Data stored in the removable partition will be preserved.
If the device is managed but in an offline computer, the System Administrator can send the user a one-time unlock code. The user must enter the code then choose a new password. The existing data on the removable partition will be preserved.
hope this helps
Feb 27, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I formated my phone but when i tried to format it agin it dnt work
Hi there, I would suggest removing the battery and the memory card, then putting them back in. Once it recognizes the memory card again, try reformatting again. If it still isn`t reformatting, it`s likely because you just reformatted it and there`s nothing to reformat. Unless I am confused.
You can also refer to the user manual here: http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones/Sidekick%20Slide%20(Q700)%20-%20USA/US-EN/_Documents/Static%20Files/SidekickSlide_UG.pdf
Jan 20, 2011 | Motorola Mobility SIDEKICK SLIDE Cell...
To reset and reformat my blackberry 8310
try this
To delete all user information go to:
Options > Security Options > General Settings > press Menu key > Wipe Handheld .
Aug 11, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
HP wont reformat due to no user partition?
it often ask for a petition size make sure you select one smaller that the available disk space.
Jul 18, 2009 | Gateway MX6920 Notebook
Removing old user's data
The best and safest solution is to reformat the machine, and reinstall. You don't know where or what the previous user had on their system and that would be the safest thing to do. Alternatively, you can go through the registry and replace each instance of their user name with yours, but this takes a long time and it's not a 100% guarantee.
Thanks and please take a moment to rate as fixya.
Nov 10, 2008 | Toshiba Satellite P105-S6024 Notebook
I have just got this com but it wont let me log on how do i reformat it please
You will need an operating system disc in order to reformat the hard drive. Reformatting will wipe the drive and a new operating system will have to be installed. If this machine won't let you log into Windows, then try starting it up in safe mode by pressing F8 at start up, log in as administrator, from here you can clear any user passwords that keep you from logging into Windows.
Jul 21, 2008 | Panasonic CF-25 166MMX Notebook
Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive Logo
53 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
