Question about GE Kitchen Ranges
GE Range M# jsp34ww3ww
I need to know the correct wiring hookup for the door lock motor. there are 2 yellow wires that i believe is common and hook up on the com terminal of the micro switches. I need to know what color wire goes to the terminal of the top and bottom micro switches. I think the 2 extra wires are blue and red
  • 3587 Answers
SOURCE: ge spectra jbp78wxb4ww
GE parts folks says that the wiring diagram is either taped inside the back control panel, or someplace else inconvenient. Try that first, and then perhaps you'll find the information. Nada on the net.
Posted on Feb 10, 2008
  • 1314 Answers
SOURCE: Bought a GE counter top
blk to blk blk to red and copper to aluminum
Posted on May 22, 2008
SOURCE: JBP66G W1AD Oven won't get hot enough
the yellow may be the oven temp sensor?
Posted on Jul 01, 2008
  • 182 Answers
SOURCE: replacing the thermostat, took the
the normal wiring for stats is white=w=heat,red=r=24volts,green=g=fan,blue=c=common,yellow=y=cooling.
see what ties into your furnace board and match the terminals.
Posted on Aug 12, 2008
SOURCE: replacing thermostat
Posted on Sep 12, 2008
Blower motor installation
just check the wiring diagram and connect the two wires for the desired speed and put a wire nut one the third one.
Aug 08, 2014 | Emerson NEW A/C Fan MOTOR 1/4 1/6 1/8 HP,...
I need to wire up a 3 phase compresser motor, 9 wires wired 480, to change to 240 volt hookup. right now it is wired 3 motor wires to each hot, no nameplate or wiring diagram.
Please verify the existing connections to determine if they fit the "High Voltage" configuration listed below. If they do (and they should), the "Low Voltage" configuration below is then correct for 240.
Low voltage ...
High voltage ...
L1---1 4--7
L2---2 5--8
L3---3 6--9
Dec 04, 2013 | Gb Electrical 100 Amp GE Load Center
How do you hookup a universal hvac condeser motor the old one had a black wire,red and a brown wire plus the green&yellow ground the new one has a black wire a yellow then it has back connetor thats...
WHAT??? Did the new motor come with a wiring diagram? Typically you will either be using a "3 wire" connection or a "4 wire" connection. 3 wire is for using the existing capacitor (provided it's the right size), 4 wire is for using a separate capacitor. You should have 5 total wires on new motor HIGH/LOW/COMMON/CAP & CAP. Then possibly some separate wires for ground and rotation. The ground goes right where you mount the motor, rotation...make sure its blown up and out of the machine. 3 wires would be...1 SPEED 1 COMMON 1 CAP. 4 wire would be 1 SPEED 1 COMMON 2 CAPACITOR WIRES. Good Luck!!
Apr 10, 2017 | Heating & Cooling
I have a GE range in which the baking element cracked in one place and needed replaced. I removed the old baking element and was getting ready to install the new one when I noticed that there were not 2...
Hello, welcome to Fixya.
I understand you are replacing your bake element and are uncertain of wire placement, correct ? My first suggestion would be to locate the tech sheet/wiring diagram, or tracing the yellow wire. I suspect the 2 black are "hot" and the yellow (maybe with a green tracer on it?) is ground/earth...though I don't have a diagram either. Let me know what you find and I'll try to help you going forward. Good luck and thanks for choosing FixYa today.
Macmarkus :)
Jul 09, 2011 | GE JBP65 Electric Kitchen Range
Error 43Our Bosch range will not open after setting to self clean
Error Code: F43 Cause: Upper (or single) oven motorized latch will not unlock; Defective or jammed upper oven door or latch switches; Defective latch motor or its wiring. Corrective Action: 1. Check P24 connector on the power board. 2. Ensure door latch switches are operating properly. 3. Check that neither latch switch nor common wires are
pinched to the appliance chassis. 4. Check P10 connector and check if latch motor wire is pinched to the appliance chassis. 5. If F43 persists, replace power board
Apr 30, 2010 | Kitchen Ranges
Error when self-cleaning - oven locked
Here is the error code and things to check on your oven.
Error Code: F41 Cause: Upper (or single) oven motorized latch will not lock; defective or jammed upper (or single) oven door or latch switches; Defective latch motor or its wiring. Corrective Action: 1. Check P24 connector on the power board. 2. Ensure door latch switches are operating properly. 3. Check that neither latch switch nor common wires are
pinched to the appliance chassis. 4. Check that the solder joints in header P24 on the power board are not broken. 5. Check P10 connector and check if latch motor wire is
Alan Hood
Dec 04, 2009 | Bosch HES5042US / HES5052US Electric...
I need to wire a 2HP 110V ge motor to 220V
I think the only place you will get this info is from GE -- and good luck with that.
Apr 29, 2009 | Dryers
Problems with low voltage control wiring turning on cond. unit
Only 2 wires going outside.
Yellow from the thermostat and the common wire from the lv side of the transformer.
Apr 28, 2009 | Heating & Cooling
Wiring hookup for a replacement part
hopefull yyou havent disconnect old switch yet. whirpool and kit aid are same Co. same parts used. assuming the correct part was sent for the corrrect burner. diffrerent element will require different rated swties(ie. small , large, dual and so forth.), the indivudal switches are labeled, on the swithc itself ( L1,L2,H1 H2, P1 andso forth, so although the switches looke differnet they should stil have the same lettered terminal to plug into .
Mar 15, 2008 | KitchenAid KESC307 Electric Kitchen Range
Our GE Profile JTP18 keeps flashing "door lock" since we ran a self clean
most of the time a simple fix....
you have to trick the door lock mech into cycling through the cleaning process (takes about 20 seconds)
Print Range - “LOCKED DOOR” flashes in the display
If “LOCKED DOOR” is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
If the above does not correct the situation, a service technician will need to check your cooking product. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Sep 14, 2007 | GE Profile JTP18 Electric Single Oven
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
