Question about Broan-NuTone Dryers
Light above shower makes crackling sound - Broan-NuTone Dryers
  • justformail Nov 21, 2009
    The lights do not flicker, and the sound of the fan remains the same.
  • 576 Answers
If the light is flickering with the crackling, it's probably the sound of electricity arcing that you're hearing. This needs immediate attention by someone who knows electricity as it could be a fire hazard.
Posted on Nov 20, 2009
Crackling subs
After crackling sound they stop and the light on overoald
Dec 29, 2013 | Legacy 12 500 watt l series woofers,...
HP Laptop light crackling?
If that is the hard drive light, you are hearng the hard drive reading/writing and quite normal.
Dec 14, 2013 | HP Pavilion dv6000z Notebook
My dell pc fan make a loud noice
There are 13 possible noise on hardware issues
1) Power supply crackling sound
2) Fan sound that sounds like a motor noise dragging
3) Harddisk clicking sound
4) CD rom spinning sound
5) Modem noise pinging sound
6) Application software resident in memory
7) Technician Neighbour drilling holes from your ceiling to do
special wirings late at night, installing transformers
8) Ceiling fan with unstable modified electricity makes noise
on motor issue
9) Sound that comes from switchboxes and transformer
upstairs lighting up free electricity from your fan wires
in your apartment unknown to you tapped by upstairs
residents
10) Voltage regulator malfunction noise issue
11) Monitor crackling sound issue
12) Wirings crackling sound issues
13) Power socket crackling sound issues
Be sure you know where the source comes from, call PC vendor if you are uncertain, you will have to dismantle your
hardware device in vendor's place to find out. Vendor will test one by one.
If computer fan is your issue, it is just a small issue
there are many replacement at PC vendors based on quality
corresponding to the price you pay
Nov 01, 2012 | Computers & Internet
Starting to get some crackling in the upper portion of the volume sweep. What's the best course of action please? Regards, T.E.
If you can access the potetiometer, lube it with CRC226 available at Home Depot in the electrical dept. Blue can about $2.70. Make sure it is the 226 as there are other CRC products there and they are unsuitable. NEVER use DeOxit or Blue Shower in potentiometers!!!!!
Dec 19, 2010 | Visual Sound Visual Volume 10th...
Hard drive powers up, light comes on makes a crackling sound then goes off.
Crackling sounds are usually electrical. Does the unit smell burnt?
If the sound is actually a ticking sound, then the heads inside the hard drive are banging and the drive needs to be replaced.
Data retrieval for drives making clicking sounds are very costly and require a data retrieval company.
Jan 23, 2010 | Buffalo Technology Computers & Internet
PROBLEM WITH THE AUDIO OUT CHANNEL
It sounds like you may have a bad cable. The most common place for a small gauge cable (such as RCA, TPS, XLR, etc) with metal connectors to fail is in the stain relief which often fails to live up to its name. An easy way to check this is to grab the cable near the connector and wiggle it. If the sound crackles and changes volume levels suddenly then you may want to try a replacement cable. If the replacement doesn't help, you should use a contact cleaner such as "Blue Shower 2" that is approved for electronics use. Make sure your mixer is switched off and disconnected from its power source before using any cleaners to avoid any risk of electric shock. Apply the cleaner to all exposed output connectors on the mixer. Hope this cleans up your output prolems
Jan 19, 2010 | Pioneer DJM-600 Silver Professional DJ...
Speakers work but crackle when in use with my dell 8300
Most likely this is because of a loose socket. Check to see if there's any dust or debris inside the audio socket(s). If cleaning it/them out doesn't work, then the socket is loose and the only way to fix the problem would be to get the sound-card repaired or buy a new sound-card.
It's my opinion that buying a new sound-card would be cheaper. You can find a good amount of them at this website. Simply navigate to Computer Hardware>Input Devices. Now on the left click, "Sound Cards." Watch out, though. There's a link labeled, "Sound Card Accessories." However, it doesn't lead you to the same page.
Let me know if I can assist you further or if I need to explain anything mentioned above in more detail.
Mar 23, 2009 | Dell Dimension 8300 PC Desktop
Nokia N73 speaker fault?
try cleaning the mic first before replacing it..this usually does the trick..theres probably dust on the mic.
Jan 24, 2008 | Nokia N73 Cellular Phone
Snap, crackle sound from Sanyo TV
It sounds to me as if possibly ya Main IC Amp Chip & OR the Output Capacitors are failing... Sometimes it is a sign of a power supply on it's way out... Either way it's time for a repair shop quote. Either that or it may be the speakers crossovers... to check this, if you can, try another set of speaker... see if problem is still there. If it IS, then it IS most probably as I said above.. If NOT then it may be one or both of the "Crossover Network" in each speaker...
Sep 01, 2007 | Sanyo AVM-3659S 36" TV
Dryers Logo
275 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
Craig Dupler
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
