Question about Polaroid FLM-323B Television
Green screen the screen is a green screen and there is not a clear picture in video or regular cable settings.
  • 834 Answers
Your T-con board has failed youe need a tech to replace it not very expensive
Posted on Nov 20, 2009
Just bought a new Series 5 Samsung 40" LED TV and we hooked up the DVD and the picture isn't clear. The midrange colours appear halftone dots like in a newspaper
do you have it hooked up through regular video? yellow cables or do you have a HD connection (HDMI, or composite cable, blue green and red) if not upgrade and you will see an outstanding difference.
Mar 29, 2011 | Samsung Televison & Video
Mitsibishi 50707
Replace vertical output IC and check capacitors in vertical
power supply....requires chassis pull and above average skill....
Nov 17, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Camera timer factor; wish to clear settings
Make sure you have the dial set on 'P' not green suare, then when you go to Clear settings, go up to the clear all cameras ettings, and that will res\et camera for you. Failing that, just turn the delay timmer off with the circular button 2nd from top, LHS of the LCD.
Jun 08, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Colours on tv screen have gone green in colour
If you have used the red, green and blue video cables, the your red is either damaged or loose. If yuo used the regular red, white and yellow AV cables, the yellow is loose or damaged, In either case, if the cable is not loose, you'll need a new set of AV cables
Nov 27, 2009 | Nintendo Wii Console
I hear the volume but have no picture on the screen
The video may be plugged into input 1 and the audio into input 2. This could be a million different things.
If using Component video (green, blue, red, RCA cables) check to be sure the Green cable is set all the way on both sides. The green cable sends the sync and without it you will have NO picture.
Nov 25, 2009 | Fujitsu Televison & Video
My JVC HD-56G786 will not work with HDMI cable. when I connect the HDMI cable I get a green screen. Any ideas would be great.
I had the same problem with my JVC projection tv. It would flash green, then go to regular picture then back to green flashes. Not sure if this is the solution you were looking for, but I was able to get a good crisp picture using composite cables instead of the HDMI cable.
Aug 26, 2009 | JVC HD-52G886 52" Rear Projection HDTV
Monitor screen changes from regular color to a green tinted screen?
Is the cable connected securely? You may need to check your video card also. You may be able to disconnect the cable and get a red, green, blue icon on the screen. If that appears normal then there is nothing wrong with the monitor itself, it may be the cord or the video card.
Hope this helps!
May 31, 2008 | Dell 1503FP 15" LCD Monitor
Blue screen with Green Star-burst image in center?
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 19, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Picture is of poor quality (wavy)
This may indicate a problem with the RF tuner. When you are using the DVD player is the output of the DVD using the F (RF Coax) Conncetor or is the DVD connect to the TV using the Video/Audio cables (either Composite (Red, White, Yellow) or Component (Red, Green, Blue)). I am do however believe this to be a RF tuner problem. Make sure that the TV is set to channel 3 and the cable box is connected to the TV (set to channel 3). What you could also do is get digital cable and use the video output jack as the input to the TV on one of your aux positions.
I would first make sure the tunner is on channel 3 when using the regular cable box, or if you are using the TV's cable ready features make sure the tunner is working correctly, this might have to be done by a qualifide TV repair person.
I hope this helps
Thank you,
Shuttle83
Nov 15, 2007 | Toshiba 57HX81 57" Rear Projection...
MY TV!!
try using AV im puts with dvd or vcr if this work your tuner is bad new cost aruond $90 to 120 if available but next year you wont have use for it
Sep 25, 2007 | JVC AV-48WP74 48" Rear Projection...
Polaroid FLM-323B Television Logo
89 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
