Question about HP DeskJet 1220c InkJet Printer
Heavy weight paper
I have a 1220c that operates perfectly except in a single situation: When I attempt to print brochures with a heavyweight paper, the printer cannot seem to pull the paper into itself on a reliable, consistant basis resulting in the printing usually beginning off the page and ending 3/4 of the way through the page. Doesn't matter if manual fed or auto. Doesn't matter if 1 page of paper or stack. Any help would be appreciated!
  • 3 more comments
  • Steviewunda Mar 13, 2008
    I have this problem when trying to print on HP A4 Premium plus paper (280 g/sm) but find it works ok if I kid the machine that I'm using A3 paper
    In other words, I feed an A4 sheet in widthways rather than lengthways and print on "half" of the A3 format - make sure you setup to print to an edge (or small border) rather than centre the image
  • ShootingPadr May 15, 2008
    I cannot feed any paper heavier than 24 lb. Bond, and I can't figure out how to make the paper feed flat from the back of the printer.
  • Anonymous Aug 04, 2008
    My printer can only print one page at a time, then i have a flash light in order for me to continue i have to press the flashing light button, then it will continue, my printer is alway unistall itself and i alway have to reinstall.My printer also freeze my computer, so i repalced it will laptop but i am have the same problem with freezing.
  • speppa Aug 13, 2008
    Any paper heavier than 20 lb fails to feed into printer. Doesn't matter if hand fed, fed from the back...even prayer doesn't work. Also, of late the paper feed function may grab more than one sheet of paper and then proceeds to print on both sheets.
  • Anonymous Feb 02, 2009
    I have same problem.Trying to print on 160gm and 200gm but feeder will not take at all.Anyone managrd to solve this yet?
  • 3 Answers
The 1220c does print heavy stock although if you look in the back you will see the slot where you put the heavy sheet into, sucks but thats the only way, at least to print perf card and heavy stock. hope this helps.
Posted on Feb 10, 2009
Try cleaning the rollers with auto belt dressing.
Posted on Mar 08, 2008
This 1220 C printer is designed to print on greeting card paper and heavy photo glossy paper. I have the same problem and think it is a pickup roller. I dont know how to change the roller.
Posted on Feb 14, 2008
  • 417 Answers
Hi it would appear that the paper is too heavy for the machine check the manual as it will have the spec on what paper can be used and also how heavy the paper could be.
Sorry I cannot be anymore help but try using a paper that is about 10-20 gsm lighter.
Thanks J
Posted on Jan 13, 2008
Sharp mx-3640 printing patches on heavy media
it might be too heavy. take a look at the back of the brochure to make sure your paper weight is within the specs of the machine.
http://equipmybiz.com/wp-content/uploads/2015/08/MX2640_3140_3640N_Brochure.pdf
Apr 12, 2016 | Sharp Office Equipment & Supplies
Heavyweight paper
First tell me the paper weight , so that we can check if it is supported.
Oct 26, 2008 | HP PSC 2355v All-In-One InkJet Printer
How do I print cardstock with Samsung ML-2510?
Hi
I found a manual for your printer here:
http://downloadcenter.samsung.com/content/MM/200605/20060510151657234/um_ml-2570_manual_eng_060328.pdf
and under print media, it suggests limits of 60 to 163 g/m2 for the 2 trays. If you get some 160 g/sm2 card which is quite readily available, I think you will find it much lighter than the Avery business cards card, which from memory come in around the 200 - 220 g/sm2 level.
Even Avery quote this card as "heavyweight card stock", and although the say will print on all laser printers, it's my experience that they do not. Only on a laser with a flat paper path.
Cheers
Mar 02, 2015 | Avery 5376 Perforated Business Card
Blue smudge marks are printing on the edge of the paper
These defects normally occur when printing is attempted on unsupported media or when the printer is set up for a different type of media than the media that is actually loaded into the machine.
Check your media and ensure that it is suitable for use in the printer. Refer to the printer's user manual for information on supported media types and weights. Is the media you are printing on supported in the printer?
Ensure that the paper type is set accurately on the printer operator panel (go to Menu/Paper Menu/Size-Type/Tray1/Type). Is the paper type set correctly on the printer operator panel?
Change the paper weight setting to heavy on the printer operator panel (go to Menu/Paper Menu/Size-Type/Tray1/Type/Heavy Paper/Check button). Try printing your document again. Did the error return? If the error returns, please contact Lexmark Technical Support for further assistance.
Jul 12, 2011 | Lexmark C532n Color Laser Printer
Can this printer print on heavyweight cardstock?
No don't ever do that. A heavy weight card stock is very thick. It can cause damage to your printer.
Oct 31, 2009 | HP PhotoSmart C4280 Laser Printer
Can't print photos onto photo paper from computer
hii
you must check the setting of your printer and then restart the printer.
Jun 22, 2009 | Computers & Internet
Printing heavy weight invitation stock on Epson R200
The card is probably too thick. Try cleaning the feed roller in the Sheet feeder to improve its grip. Check the GSM of the paper is within the spec of the printer.
Nov 03, 2008 | Epson Stylus Photo R220 InkJet Printer
Troubles printing on photo paper
it might be check your printer manual for the exact paper weight
Mar 18, 2008 | HP DeskJet 1220c InkJet Printer
Won't feed paper
when you say ''heavy weight'' do you mean thin card etc.
Most printers dont like to use thicker paper. does it make a noise. like gears slipping or crunching when it is trying to feed. if this is the case, then the feed gears maybe worn.
Feb 04, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Ink not sticking to paper on textweight, possible fuser problem?
Have you properly make setting for media attributes ? plain -normal paper.
Nov 05, 2007 | Xerox DocuColor 12 Printer
HP DeskJet 1220c InkJet Printer Logo
390 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
