Question about Sony Ericsson Walkman W705 Cell Phone
Frequently jams and locks me out my media, and I have to turn it off and on to get it back again. Happens with texts, sometimes movements, but is happening more and more for no reason at all
I am driving Honda balade 1989 model it seems the air lock doesn't allow petrol to go through to the tank whats the problem
It is spring loaded and sometimes they jam up and get stuck (maybe a little rusty) I would suggest pushing it open repeatedly making sure it is not stuck and spray some WD-40 in the direction of the hing until it gets back a free movement again .
Sep 26, 2017 | Honda Cars & Trucks
Elextrolux EWF168540 W TimeManager 8kg stopping mid program without any error message
The recurrent problem may be due to a defect in the Time Manager.
Feb 01, 2017 | Washing Machines
Hp probook keyboard
most likley a loose cable or "ghosting" go to your local pc shop for help
Mar 08, 2014 | Computers & Internet
Nokia 5800 always restart (insert SIM Card)
yes this is a proven fault with the phone take it back to the dealer and they should repair it
Jan 05, 2010 | Nokia 5800 XpressMusic Smartphone
My 2004 Mini Cooper's driver side window doesn't always go up or down. Almost sounds like something is blocking the movement. Happens more frequently after rain. Please if you have any ideas let me know.
IF IT HAPPENS AGAIN POP THE DOOR PANEL WITH THE BACK OF YOUR FIST A COUPLE TIMES THAN TRY THE WINDOW AGAIN. IF IT WORKS HEAD TO THE DEALER FOR A NEW WINDOW REGULATOR
Nov 29, 2009 | 2004 Mini Cooper
My zipy coyote mp4 wont play the musics!
You probably have the Hold on! (: It's the button on the side of the mp4 that says HOLD. If it's down, it's locked. Try pushing it up and turning on your mp4. If the lock still appears, try switching the button again down and up, that happens sometimes with my zipy too. Hope I helped in some way!
May 14, 2009 | Audio Players & Recorders
Hellow!!!! everyone!!!!!!!
I have found that when this happens the cartridge is not aligning with the micro switch and so take it back out and as straight as you can push it in until it is locked and try again. It will stay red a bit before trying to reset. Even if you turn the power off it will sometimes take about 15 seconds to attempt to start.
I have found when this happens sometimes 5 attempts will get it to work. Easy to replace the cartridge as it is NOT the printer but the cartridge in most cases.
Streak www.streak.asia
May 08, 2009 | Samsung ML 2010 Laser Printer
Fault with Samsung PS42S5H
sounds like the lower y-sus buffer! take off the back and give me the pcb number should start with Lj92
Nov 03, 2008 | Samsung PS42S5H 42 in. HD-Ready Plasma...
Sometimes when i text the recipient never gets it! where did my text message go?
sometimes it happens due to network problem..at times the network gets jammed..during these times the message does not reach th recipient
Oct 14, 2008 | Cell Phones
Earphone Connection
If you feel comfortable taking apart micr electronics then you can take off the case ans disassemble the chassis and see if its just the solder connections on the pcb. but be carefull sometimes they use flex pc boards and too much heat will burn up the board and then your dead in the water. Also it could be that the solder trace could have broken off the pcb. if this happens your gonna need to solder on a piece of small solid copper wire like phone cable (cat three type 26 guage)and run the other end to another solder connectionon the same trace. Them what I do is epoxie the connections and the jack so that its secure. Good Luck
Apr 27, 2006 | Creative Labs Zen Micro MP3 Player
Sony Ericsson Walkman W705 Cell Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
