Question about HP Deskjet 3845 InkJet Printer
How do you put the paper in - HP Deskjet 3845 InkJet Printer
    President:
  • 1,901 Answers
Refer to this Setup Poster that shows paper loading in Step 3:
http://h10032.www1.hp.com/ctg/Manual/c00257686.pdf
Thanks for using Fixya.
Posted on Nov 20, 2009
Paper jam in this position
Open the machine as if you were putting in a new cartridge and remove the jammed paper. You may have to remove the paper tray or duplexer to find more paper.
Reassemble, don't put so much paper into the tray, make sure the paper isn't curled badly. Generally I put the paper in concave down...it will flatten over time.
Perhaps your paper is curled somewhat and is concave up which is causing the jam.
Jun 25, 2015 | Office Equipment & Supplies
Tip
PROBLEM - OUT OF PAPER
If many people are waiting for printouts, and nothing is actually being printed, the printer may be out of paper; the printer will indicate this on its display. To load paper into the N4525 printer, simply pull out the tray #1 or #2 located at the bottom of the printer in the front, and put the paper in the bin. Put the tray back into the printer. To load paper into the N24 printer, locate the tray in the front of the printer. <br />Pull the tray out, and locate the bin indicated by the large arrow in the lower left-hand corner. This is the side where you put the paper. Then, push tray 4 back in to the printer<br />.Make sure you put the paper on the correct side of the tray. This is the most common error. There are usually diagrams on the inside of the trays indicating how to put in the paper.
on Jan 06, 2011 | Office Equipment & Supplies
How to load evelopes HL 2140
Brother Hl 2140 Printing on thick paper, labels and envelopes 2
When the back output tray is pulled down, the printer has a straight paper path from the manual feed slot through to the back of the printer. Use this paper feed and output method when you want to print on thick paper, labels or envelopes.
Open the back cover
Open the manual feed slot cover.
Using both hands, slide the manual feed slot paper guides to the width of the paper that you are going to use.
Using both hands, put one piece of paper or one envelope in the manual feed slot until the front edge of the paper or envelope touches the paper feed roller. When you feel the machine pull in the paper, let go.
• Put the paper into the manual feed slot with the side to be printed face up.
• Make sure that the paper or envelope is straight and in the proper position on the manual feed slot. If it is not, the paper or the envelope may not be fed properly, resulting in a skewed printout or a paper jam.
• Do not put more than one piece of paper in the manual feed slot at any one time, as it may cause a jam.
• If you put any Media (paper, envelope and so on) in the manual feed slot before the printer is in the Ready state, the media may be ejected without being printed on.
Jul 18, 2011 | Brother HL 2140 Laser Printer
Online/error light is red
When you pull the paper out, that affect paper loading switch inside(or paper status monitering switch)
pull all the paper out, check switch inside near Loding roller
put you paper back and Put the tonner cartridge back, close the door and try agian ( i solved my problem this way)
Mar 25, 2009 | Samsung ML 2010 Laser Printer
I never Used A Fax Machine. I was Given A ''Brother IntelliFaxMC''
if you look at the area where you put your paper to seend ( that is the document feeder ) there should be a diagram of a pice of paper with a corner turned over, if lines are on the top part put paper in dac feeder face up. if lines are on the little corner pice put the paper face down,
if not sher put one pice of paper with lettering in doc feeder press copie of it comes out you got it right. hope this helps
C.W.H. ( typboy)
Jan 23, 2009 | Office Equipment & Supplies
Paper feed
Make sure you fan the paper before putting it in. 20 sheets is usually about right for these printers.
If you put labels in the printer. Only put a few sheet in at a time and put paper stock below them.
May 22, 2008 | HP DeskJet 820Cse Printer
Brother dcp 7010 How to print envelopes
Use the manual feed slot to print or copy on labels,
envelopes or thicker paper.
Slide the paper guides to fit the paper
size.
Using both hands put the one sheet of
paper in the manual feed slot until you
feel the front edge of the paper touch the
paper feed roller.
Let go of the paper
when you feel the machine feed the
paper in a short distance.
May 16, 2008 | Office Equipment & Supplies
Fax does not know paper is loaded. says load paper
When you load your paper, you must press the Stop/Reset button for it to reconize you have loaded paper.
Nov 17, 2007 | Canon FAXPHONE L80 Laser
Check paper light is blinking, there is no paper in the feed, checked to see if there was a jam, nothing.... The 'copies' constantly shows an E?
put the paper in paper try properly like put deep inside and stop it when you feel littel bit of resistent put slowly inside the paper.
Sep 05, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP Deskjet 3845 InkJet Printer Logo
57 people viewed this question
Ben Johnson
