Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Powering off changed flyback transformer and chip. Everyone says i have a bad capacitor.Even my sister in law has same tv put in in shop and changed cap. I just dont know which one to check they said 2200 micro farrad 50v was changed i cant find one that value i figured they changed one close to that value that they had in stock.
  • stacie ramsey Jan 12, 2008
    ill fix this one my self it is cap cp150 replace it is onthe same board the fyback is on .I han replaced flyback and a chip. then when i changed the cap tv works fine hope this helps someone.
  • RCA Master
  • 5,138 Answers
If you have convergence problem replace FL231 400ma in front of flyback.
Posted on Jan 17, 2008
Rca projection televisions HD52W68YX39 CONVERSION CHIP
This set does not use a convergence chip. All discrete parts.
Two things to check--Is the convergence option still seen in the menu?
If not there is a kit for that with 3 parts to change. And if convergence was going in and out before this---the set is prone to bad solder connections under the high voltage transformer where the 3 part kit is located also.
The board with the transformer is would have to be removed to look for the bad connections.
Transformer is also called a Flyback.
Jun 01, 2012 | RCA P56812BL 56" Rear Projection...
Cannot Find Flyback Transformer 60PP9202/17F
Contact Philips directly. They should be able to get you the part, even if they have to get it from another repair shops. Many repair shops purchase their parts from factory authorized distributors, not from the manufacturer. The flyback transformer powers the tube-it can be extremely dangerous to work on-EVEN with the tv off, they contain a lot of power somethjing like 50,000 to 150,00 volts. It is not fun getting shocked by one of these as many techs have been knocked unconcious by them. If you do not know the proper procedure to discharge a flyback then leave it alone!
Dec 22, 2009 | Philips 60PP9202 60" Rear Projection...
Wont stay on
You probably got a bad capacitor somewhere in the power supply this happends because of heat and other operating conditions this can be fixed and repaired by a Tv shop in your area but at least you got a idea what it could be. also keep in mind you flyback transformer may also be culprit.
I hope this was Very Helpful information for you.
Dec 10, 2009 | Panasonic PV-DF2704 27 in. TV/VCR/DVD...
I replaced all 3 convergence chips, check every
If it had line stright acoss screen thats Vertical IC and Capacitors 100uf 35v ,1uf 50v, 2.2uf 50v Check by hori output Blue capacitor c556 561pf 2kv
Sep 30, 2009 | Mitsubishi VS-60621 60" Rear Projection...
Power ligt blinks twice no high voltage
CK capacitors cp150 cp114 cp120 if cp150 is puffed up on top it is bad so replace all 3 caps.2200uf 16v and two 220uf 35v
Jan 16, 2009 | RCA D52W23 52" HDTV CRT TV
Panasonic television
This is not something that you can fix, the sound is the high voltage section with the horizontal output transformer. The reason is a possible flyback transformer failure or the high voltage diode is bad. Most electronic shops can fix it.
Nov 26, 2017 | Panasonic TX-28CK1 28" TV
Tv wont come on
Most times when you hear this kind of sound on a TV it is because the flyback transformer is bad (from what I can remember anyway!). Its been a while since I repaired TV's, so hopefully someone can verify my info. The flyback transformer steps up the voltage very high which powers the color tubes. If that is bad, you will get the thunk sound. Also, if memory serves me well, there is a high power output chip that could be bad as well. Please, anyone who knows TV's, please verify for me. It has been years for me!
Apr 13, 2008 | RCA R52WM24 52" HDTV Projection Television
Tv dead
no problem
replace by same number.
but remember before you replace check the following.
  1. check for normal output from power supply.
  2. check components connected to flyback transformer.like capacitors & diodes.
  3. check for print short.
  4. while replacing h/output be careful to check heat sink compound & mica sheet normal.
  5. put on the set
  6. if still it blows then flyback transformer is faulty.
  7. hope this will help.
  8. good luck.
Oct 11, 2007 | RCA HD56W58 56" TV
TV PROBLEM
Resoldering all the pins on the flyback transformer will fix this. Common problem.
Sep 08, 2007 | Disney DTD1363-CAR 13" TV/DVD
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
