Question about Apple iPhone Smartphone
The phone dont turn on theres no sign that its charging
  • 159 Answers
Ignore the SPAM post on this question
Make sure it fully charged and then try holding down the home button and the power button together for about 10 secs
That might get it to start
Posted on Dec 17, 2009
I just dont know :/
That should not be too difficult to find out. Plug the phone in the charger and the charger to the wall socket. The phone should say Charging. Even if your particular phone does not say charging, leave the devices connected to the charger. After a few hours, unplug th phone and turn it on. If it does not stay on there is no charge. If it stays on, use your phone and see how long the charge lasts. If it lasts the same amount of time as it used to, then the charging occurs normally. If the charge does not hold, then there is incomplete charging or no charging at all.
Jan 14, 2012 | Computers & Internet
Blackberry curve phone wont turn on
hi there!
there are several reasons why it wont turn on, if you could post back with what happened to it before we can probably help you more. but you can try checking your charger first, if its working with other phones then charge your blackberry (dont turn it on) for 5-10mins, check if the battery sign is shown on the screen. it can also be a problem with the power button, if its not pressed down enough, try long pressing the power button too. or post back with more info =)
Apr 07, 2011 | Cell Phones
How can I turn up the voice volume on this phone?
On the left side just below the charging port there is a switch with a + and - sign. While talking push the + sign for louder or - sign for less volume.
Dec 16, 2010 | Pantech breEZeTM Cellular Phone
There are 3 signs on my cell while charging.
firmware issue. kindly download 3.1.2 firmware and and jail break it using blackrain.
to download firmware visit www.redmondpie.com for blackrain : www.blackra1n.com
use itunes to update the phone to select the firmware keep pressing SHIFT button n then press restore n browse n select the firmware file.
Feb 28, 2010 | Apple iPhone Smartphone
The phone is only 4 months old and it just died. It will not turn on. have charged it.....no signs of life. Taken the battery out and put it back in.....still dead. It was fully charged when it died.
before this thing happen, is there any sign or pop message coming out your phone, "memory full, delete some data"
try to remove your memory card first then try to ope it again
Nov 02, 2009 | Motorola Mobility Rival A455 Cell Phone
Cant charge my htc p3300 phone
you must have disabled that option, go to settings select power and there will be an option ie. "when device is turned on" deselect it.
Aug 03, 2009 | HTC Touch Viva Cell Phone
Black screen/no signs of life
NO THE PHONE SHOULD POWER RIGHT UP... THERE IS NO SPECIAL PROCEDURE TO GET THE PHONE TO TURN ON....... AS LONG AS THE PHONE HAS A CHARGED BATT THEN YOU SHOULD BE ABLE TO TURN IT ON... I WOULD SAY THAT YOU HAVE A DAMAGED PHONE AND IF AT ALL POSSIBLE I WOULD SEND IT BACK TO WHERE I GOT IT IF ITS A REFURB MOD...THANKS
May 24, 2009 | LG VX6100 Cellular Phone
E sign on the phone
usually E sign appears when you can make only emergency calls from your mobile...it happens when there is no signal from your network
Dec 16, 2008 | Nokia 6233 Cellular Phone
Sidekcik Lx will not charge.
alright..my sidekick does he same thing but i fund a temp fix....the guy at the store says its the charging port..idk.....first plug it in....let it charge 4 ten min....then try to put in on...it will say the low battery sign...dont worry...then t8 sumting pointy and push it in the little reset hole behind the screen as you swivel it...as soon as you see the little box with the circles in it you press and hold the space button... hopeully it will start by showing the four butttons....if it does start and cuts off at the tmoblie sign jus let it charge longer and do it agian....hopefully it will work on yours it worked on mine....gud luk
Jul 02, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My phone dosent turn on or nothinq
When the battery is totally depleted, you will need to use a charger that came with the phone. Sometimes it will take a few mintues (give it 10) for the battery/charging circuit to come on.
Sometimes you can charge from other sources than the charger that came with the phone. You generally will need enough charge on the battery to start the phone.
Example: If I have enough battery to where the boots and turns off, I can generally get it to charge from USB or my car adapter. You will need to get the phone to turn on and boot most of the way up before it will take a low current charge. If my phone is so dead it will not even turn on, I must plug it into the AC adapter. Sometimes even then the light does not turn on right away.
The problem is probably due to the number of amps provided by the charger. When the battery is totally dead, the charging circuit is drawing so many amps that it will prevent low amp chargers from being able to do the job. That's why these phones have such heavy duty AC adapters.
Apr 28, 2006 | T-Mobile Sidekick II
Apple iPhone Smartphone Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
