Question about Philips CDR765 2-Disc CD Recorder
It wont record all my cd tracks, its starts
My philips 765 cd recorder it wont record all my cd tracks, its starts recording and then in the 20 second it stops
    Brigadier General:
  • 8,546 Answers
Sounds more like it won't record ANY of your CD tracks. Is there any indication why? Are you sure it has audio coming in? Many CD recorders will automatically stop recording if they sense extended silence.
Posted on Nov 20, 2009
  • jeromy young
    jeromy young Dec 01, 2013
    yes it shows sound going into the mixer that we use at church
I have a de recorder 4050 when I try to put a track of a vinylalbum on cd, it stops after 20 seconds what can I do about it?
YOU mean "CD" recorder, right? A recorder will typically stop recording in the extended absence of audio.
And the track that is recorded - what does it sound like? If it's silence then you need to track your source back to its origin through the undefined electronics and find out why the signal isn't getting through to the recorder.
Jul 27, 2011 | Marantz DR-4050 2-Disc CD Recorder
I have connected my phillips cdr785 recorder the proper way to record from an external source and I get the message "start source" on the cdr side when trying to record. And it never starts...
If you're recording an analog source the recorder won't automatically start. You have to start it in sync with the playback.
If you're trying a synchronized digital recording...
Page 28 of the manual says
Start playback on the selected source.
The CD recorder starts to record simultaneously and recording in progress is shown. The remaining recording time left of the CDR(W) is displayed.
Note: If you start playback on the selected source within a track, recording starts at the beginning of the next track or after 2.7 seconds of silence in analogue recordings.
Mar 05, 2011 | Philips CDR785 3-Disc CD Recorder
I have a Phillips CDR 775 2 -disc cd recorder and my track time is automatically set to 20 seconds. How do I increase this time per track? Also, I cannot seem to get the auto track to work when...
It's all in the manual...
20 seconds is the amount of digital 'silence' the machine will let pass during recording before it marks a new track. t will Pause and wait one minute for a digital signal to resume. (Page 21)
On digital copying it will automatically increment track numbers as the source advances.
For analog sources you should switch Auto Track to OFF and manually press Track as applicable. (Page 28)
Jan 21, 2011 | Philips CDR775 2-Disc CD Recorder
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
Tascam cd-rw750 - while recording from another CD player (using digital coax connection), machine records for some time and then just "jumps out of record mode" and goes back to the beginning like nothing...
1. First problem: "like nothing is recorded". IS something recorded or has it been left in Pause Mode so long (instead of Recording) that it just got impatient and time out?
2. Get yourself a couple of CD-RW Digital Audio discs to play with until you're past this learning curve/problem scenario. That way you can always erase them and start over without having to discard the disc.
3. Dropouts on playback. Are they repeatable - always at the same place, even on different CD players? If so, the data is bad on the disc. If not, the data is probably marginal.
4. If you have a DVD player, try to play the failed recordings in it. Some DVD players can play back unfinalized CDR's. You may be able to recover the data by copying it back to the CD Recorder from the DVD player. Just be advised that an unfinalized CD-RW may not have 'silence' following the last recorded track due to old data remaining from a previous session, so be ready to pause or stop the recorder when the last track finishes.
5. "Scratches near the outside of the CD". Were these NOT present prior to entering the CD Recorder? Do they seem to coincide with about where the recording may have failed?
6. 20 vs 19 tracks: Is this a constant problem or only when there is a failure during CD creation? If the latter, it would make sense as the last track in isn't technically completed.
Apr 09, 2010 | Tascam CD-RW750 CD Recorder
Im trying to records mix cd but isnt changing
• To switch off the Auto Track function you have to enter
Menu mode.
If you wish to increase track numbers manually, press
TRACK INCR(ement) on the remote control. For further
instructions see Menu mode.
ON (AUTO): The track increments are automatically taken over
from the digital source material or after 2.7
seconds silence during analog recording.
OFF (MANUAL): While recording track numbers can be
incremented manually by pressing TRACK
(Minimum track length is 4 sec.) (This can
also be done in Auto track ON mode.)
May 01, 2009 | Philips CDR770 CD Recorder
My philips cd recorder is not recording
the recorder philips cdr-778 put my 80 min sony cd-r audio in it start recording 20 second on track 1 go to track 2 for 20 second then stops goes to update some times it reads no disc when installing the disc we have been recording at the Church for the past 2 years
from clyde
Mar 02, 2009 | Philips CDR778 2-Disc CD Recorder
Recording Errors
Hi. I did a google search to see how to fix mine. It's doing the same exact thing. I wonder if the CD's are the problem. I hadnt'had problems in the past, but I'm thinking maybe the companies are making their cds's a little different with the speed. I use the audio cdr's but I have had this problem.
Sep 25, 2007 | Philips CDR770 CD Recorder
Record mode
Hi everyone! In reply to my own question.The answer was operator error,not knowing the operation of the unit.It was due to the incorrect timing of the input source to be recorded.Everything ok now.
Mar 05, 2007 | Philips CDR778 2-Disc CD Recorder
Philips CDR765 2-Disc CD Recorder Logo
280 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
