Question about Hobart A200 Stand Mixer
Hobart A200 Hello, I have a Hobart A200. First gear is not working. When turned on in first it turns at the second gear speed. Second and third gear work. A small amount of oil is also dripping. Any assitance/advice would be great. Thank you ! Amy
  • 1 more comment
  • Katielewis Jan 13, 2008
    Thank you.....
    We actually had tigtened the nuts too much.... Once loosening them the first gear speed worked properly.
    We loosened them to just finger tight is it ok to run the machine like that, or should they be able to be tightend harder without this first gear problem happening...
    The reason we were tinkering with the nuts to begin with is that there was a small amount of oil dripping from this area. We had recently moved the mixer up on to a table (tilted the machine forward and down to lift)... would that cause it to drip for a period of time or is it an indication of another problem ?
    Thank you so much !
    Amy
  • Anonymous Jan 28, 2008
    i think all oil has leaked out for my 20 quart please help me in knowing the best way to replace. i will try to loosen the bolt and see if my mixer will start in slow thanks so much
    paul
  • Anonymous Mar 25, 2014
    slippes in all gears
  • 640 Answers
Amy, depending on how old your mixer is there are 2 types of clutches for 1st gear.these could be your problems--a key is sheared on the shaft--shaft/gear is broken.the bottom part of the mixer where you put on the attachements is called the planetary,does it look like it has moved down?you could tell if the dough hook,wire whip,ect,ect is hitting the bottom of the bowl.if this is the case its just simply tightening the 2 nuts next to the beater shaft.if this is not the case you would have to dissasemble the transmission.let me know.
Posted on Jan 12, 2008
  • anthony james
    anthony james Jan 13, 2008
    amy,you found your problem,just make sure there tighter than finger tight.the gears werent meshing correctly and oil/grease will leak.im a hobart service tech and repair these mixers often.if you need any ? answered in the future let me know.
Slowspeeds
Please submit more information of the actual problem.
One issue could be that 1st and 2nd are the same speed, but third is faster.That is caused by having the two nuts in the bottom of the planetary too tight. This pinches the bushings in the second speed gear which drives by friction faster than the gears of 1st causing 1st to slip. Back off the acorn nut and thin lock nut perhaps a half to a full turn. Hold the lock nut and tighten the acorn nut to it. You can tes the setting by pushing up on he planetary. You should see about a 1/16" movement.
If you only have one speed in all gears, either the internal gear selector is broken, or a key is sheared between a gear and shaft.
Mar 05, 2014 | Hobart A200 Stand Mixer
Hobart a200 first gear not working
slacken the big acorn nut away from the bottom of the planetary and then tighten the lock nut to the acorn nut. When adjusted and secured, the planetary should have a little vertical play, maybe 1/16".
That will stop the second gear driving from friction from being too tight.
Feb 27, 2014 | Hobart A200 Stand Mixer
1949 hobart a200 rebuild problem
Google Hobart --utube-ebay has 300 4sale somebody might know something--waiting on the chocolate chip cookies
Aug 02, 2017 | Food Mixers
Our Hobart A200 Mixer only turns on for a few seconds. It has a lot of saftey features that were not familiar with. How do i get to work properly.
It sounds like you get a degrading or bad start capacitor (locate right behind motor cover (see fig 22, page 12 of part catalog, cost $13). Here how you can check if your machine still work properly: 1- Rotate the agitator shaft manually to check for any binding. 2- remove two wires from the capacitor. 3- Use a small jumper, connect one end jumper to one wire and touch the other end jumper to second wire 4- As soon as motor start, remove the jumper. Good luck, If your ,machine have never have preventive mainternance it is a time to do so. (atva)
Apr 19, 2010 | Hobart A200 Stand Mixer
Hobart A200 mixer 1st speed doesn't work 2nd and 3rd work fine
Could be that a gear is missing (broken) on the shaft that works the 1st gear. Check out the schematic at
http://www.food-equipment.com/parts_Hobart_mixers.htm
It could be the gear HM2-748
Feb 22, 2010 | Hobart A200 Stand Mixer
Hobart D340 mixer will not hit 3rd gear
Check that the gear on the shaft that the clutch gear engages with does nort have a sheared key.
Feb 12, 2010 | Hobart D340-6007 Mixer
Hobart A-200 First Gear is Having Trouble
If the mixers are older the dive key shaft,spring or key are broken,if they are newer the key is sheared.Also check the nuts near the beater shaft and make sure there not too tight.
Nov 13, 2008 | Hobart A200 Stand Mixer
Sound like bearings
Ist check your agitator shaft for looseness. the shaft you put the beater on. wiggle side to side. if tight no play. If in first its quiet but you can here a grumble under load but second gets louder. and third even louder. If the shaft is tight. your gears down there are warn. you can take that all off with the two nuts underneath. and check the grease on the gears but even with new grease on them it most likely stay loud. grease it with hobart grease from your loacal hobart for the A-200 planitary not the transmision they also fve grease for Trans. if you can take the noise run it that way if not decide which arm & leg you want to give hobart for new gears.
Sep 10, 2008 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
453 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
