Question about Motorola Spirit GT Pro (2 Channels) 2-Way Radio
How do you change the frequence on the motorola spirit gt
  • Motorola Master
  • 1,654 Answers
Here is a link to the operator's manual for the Spirit GT: http://www.motorola.com/mdirect/manuals/Spirit_GT_User_Manual_E.pdf
You will find programming instructions on pages 12-13.
Best regards.
Posted on Nov 20, 2009
What motorola radios are compatible with mu21cv, mu22cv and mu24cv
Any Uhf Motorola business radio can be programmed to match. None of the toy radios will ever work. (GMRS/FRS)
Easiest to self program will be the the XTN, also called CP100, and RD (RDU) and even older Spirit and SP10 are possible, but harder. RD's are really hard without the programming cable, available from a dealer.
Sep 08, 2015 | Motorola Radio Communications
Cp150 frequency change
This is a programmable radio. Using Motorola proprietary software, programming cable and radio interface box (RIB) the radio can be reprogrammed to another frequency/PL Code. This can be done by your Motorola dealer.
Feb 12, 2014 | Motorola Radio Communications
Frequency for Motorola MU24CVS UHF (4 Channels) 2-Way Radio
This radio has several available frequencies built into the unit:
1 - 464.5000
2 - 464.5500
3 - 467.7625 *
4 - 467.8125 *
5 - 467.8500
6 - 467.8750
7 - 467.9000
8 - 467.9250
You would need to read out each channel to determine what each of the 4 channels is programmed to. Reading out is easy on this unit. With the radio turned off, select the channel with the channel knob, then hold in the PTT button while turning the radio on, immediately it will tell you the frequency number, (if you want to change the freq you can use the PTT button to walk your way up through the numbers to the number you'd like), then if you press the monitor button it will lock in your chosen frequency and it will tell you the private line code (if zero it is turned off), then press the monitor button again to lock everything in. Do this on each channel and you will know how your 4 channel radio is programmed.
Note: This radio is a wideband radio and only a few were produced with narrowband capability. After Jan. 2013 you are required to use narrowband only in the USA. If your MU24 radio has two RED dots above the word Spirit it is narrowband on only frequencies 3 and 4. If your radio has no red dots on the label your radio is wideband only.
Best regards.
Dec 08, 2013 | Motorola MU24CVS UHF (4 Channels) 2-Way...
I have a Motorola Axu4100 , I want to change the frequence that I currently have on this radio to a Motorola CP-200...just wondeing if these two radio can work together....
Hi
Motorola CP-200 have frequency range
VHF: 136–162, 146–174MHz;
UHF: 403–440, 438–470, 465–495MHz depending on the model
Motorola AXU4100 have frequency range 435 - 480 Mhz
The first model has a wider frequency range so it is best to include transmitter Motorola Axu4100 to transfer and try to receive signal to Motorola CP-200
Sep 03, 2010 | Motorola AXU4100 (10 Channels) 2-Way Radio
XU2100 (1 Channel) 2-Way Radio: How do I change frequency on a motorola xu2100...
Hello, I just purchased 3 of the discontinued XU2100 radio's, Can someone help me to change the frequency on them? My email address is cubnboy@yahoo.com. Thank u for your time...
May 16, 2010 | Motorola XU2100 (1 Channel) 2-Way Radio
We just purchased these radios for our Dental office and they seem to have alot of interference, they have alot of static, We have them on channel 1, Frequency 8, I believe, seems to be kinda complicated...
We agree, it does take some patience to program this model of radio. However, it is do-able. You need to program both the Frequency and the Code. If you set your code (the smaller number), it should eliminate interference from other users. If not, switch to a different set of numbers until you find a clear frequency in your area. Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5XXX_User_Manual_E.pdf
On the issue of static. Static is usally caused by using a bad, defective or poorly charged battery. This model of radio has not been offered for several years. It is likely you have batteries which need replaced. Your local Motorola dealer should be able to get the batteries for you. Or purchase from an online Motorola vendor.
Best regards.
Nov 03, 2009 | Motorola Spirit GT Pro (2 Channels) 2-Way...
How to change channel
Spirit GT: Programming a Frequency to a
Selected Channel:
1. Press and hold down the Push-To-Talk
button while turning the radio on, wait for
approximately 5 seconds then release the
Push-To-Talk button.
2. Use Scroll button to select one of the 8
frequencies.
3. On a Spirit GT+, press the Monitor button.
4. The current channel will flash, press scroll
button to change channel.
5. After the second channel is selected, press Monitor button again, current
frequency for second channel will flash. Figure 16.
6. Use Scroll button to select new frequency.
Exit Programming Mode - 3 Ways
1. Press Push-To-Talk to exit completely.
2. Allow the Menu time to expire (10 seconds).
3. Press Menu button to go to code programming.
Here is a link to the user manual: http://www.motorola.com/mdirect/manuals/Spirit_GT_User_Manual_E.pdf
Jul 17, 2009 | Motorola Spirit GT Pro (2 Channels) 2-Way...
How do i change the channel?
Selected Channel:
frequencies. Figure 16.
Jun 25, 2009 | Motorola Spirit GT Pro (2 Channels) 2-Way...
I unlocked my phone to use another carriers sim. Its unlocked but there is no signal
frm where u get tht phone usa or uk
check out the frequency :) in settings >network > netwark setup > frequency > 900/1800 or 850/1900
check it n reply
Jun 14, 2009 | Motorola Mobility RAZR V3
Motorola Spirit GT Pro (2 Channels) 2-Way Radio Logo
225 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
