Question about Whirlpool RF368 Electric Kitchen Range
Cakes don't get done in the middle. The time and temp is correct and they look done but when you get to the middle it's still goopy.
Why don't cakes rise?
Taras, Check the attached links,instruction and guides on cake baking strategies. Good luck .
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.instantanswer.org/why-did-my-cake-not-rise_608.html
Reasons for Cakes Not to Rise LIVESTRONG COM
http://www.mumsnet.com/Talk/food_and_recipes/895729-Why-don-39-t-my-cakes-rise
Why Don My Cakes Rise High Enough
Apr 08, 2016 | Frigidaire Kitchen Ranges
What temp do you cook cakes in if you do not have a fan forced oven
Different kinds of cakes require different temperatures. Most cookbooks tell you what temp to use for each recipe. Same goes for cake mixes. The instructions on the box are way smarter than me.
Mar 16, 2015 | Ovens
Suddenly burned cakes
Could be temperature control failure
May 25, 2017 | Smeg Ovens
Think oven getting too hot and my cakes sag in middle
Get a cheap oven thermometer at your grocery store and check the temp before you put a cake in. Regardless of the kind of oven, this is the best way to be sure your temperature is correct before baking. I use one every time I bake, and I never have issues due to incorrect temp. I might have issues due to OTHER screw ups on my part, but it's not because the temp is wrong. You can buy an oven thermometer for a few dollars.
Aug 26, 2011 | Neff B1421 Electric Single Oven
Why do cakes sometimes collapse while baking?
helllo dis.... There are many things that can cause cakes to fall in the middle.... Jumping, etc., around the baking area is unlikely to be a problem except with very delicate sponge or angel food cakes. More likely, cakes fall when the crust appears to be done, but the batter is not baked through the middle. An uneven baking temperature is a frequent culprit; check the temperature of your oven with a separate baking thermometer, and be certain that your oven holds a steady heat through the entire baking period. Some older ovens preheat properly, then cycle off and drop the temperature after 15 or 20 minutes, which causes the uncooked portion of the cake to fall.
Less likely but possible problems could be inaccurate proportions of baking powder or baking soda if the cake is made from scratch. This could occur with cake mixes if sour milk or buttermilk is used instead of regular milk; the additional acid in sour milk requires additional baking soda to rise properly. Eggs that are not beaten properly, or perhaps beaten too much for the type of cake being made, might also cause problems. Joe
Mar 12, 2011 | Tecnik Ovens
Things bake unevenly. Cakes get brown on edges
first make sure you are not blocking a rack.air needs to circulate from the bottom to the top.never cover a rack with tin foil or a large pan. if alls good you may have a temperature problem.check temp if its off raise oven temp as high as it goes hold bake button untill it beeps it will display 0 go up to raise temp up down to lower you can only adjust 35 deg.Good luck!
ERIC
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 21, 2010 | Kitchen Ranges
OVEN NOT BROWNING CAKES
put dynamite in container. if it blows up, too bad
Apr 12, 2009 | Jenn-Air JGW8130A Electric Single Oven
Items are not baked all the way through
Put a thermometer in the oven to see how the temp is vs what you set it at. If temp is off by more than 25 degrees replace the oven sensor. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | GE Spectra JBP78 Electric Kitchen Range
Trouble baking
Sounds like it's running too hot. Check temps. May have a stuck relay on board. Run oven and check to see if bake element is cycling off when it reaches temps. It should stop glowing within
15 minutes from start. If it doesn't you need a relay board most likely.
Nov 04, 2007 | Jenn-Air JJW8330D Electric Single Oven
GE electric oven
If this is a fan oven, make sure the fan has not become clogged or has stopped rotating.
Oct 07, 2007 | GE JSP26 Electric Kitchen Range
Whirlpool RF368 Electric Kitchen Range Logo
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
