Microsoft Windows XP Professional Logo
Anonymous Posted on Nov 20, 2009
Enterprise suite removal Anyone know how to kill this without formatting?
Anonymous
Level 2:
Sniper:
  • Expert 50 Answers
  • Posted on Nov 20, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
50
Questions
0
Helped
24699
Points
121
Yes you can remove it without formatting just go on start, than run a command (appwiz.cpl) after running this command Add or remove programs windows is open
In this window you can remove it.
Thanks & Regard
Abhay Singh
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
2005
Points
12
Which RAM has the best suited for enterprise applications where processing-intensive work?
You are immensely searching for a RAM that is suited for all enterprise application in intensive work. If you want to know about my preferences, then it is sas 3gbps, sas 3gbps ssd. It is mentionable here that fewer moving components make the SAS 3Gbps your ideal choice for efficient and faster performance, even in the mission-critical application and rigorous 24/7 environments. SSDs do not need to move a platter and align it to the correct position to read or write data.
Cannot get in touch with ellis enterprises
The contacts are on ites site
MAIL
Ellis Enterprises Inc.
5100 N. Brookline Ave. Suite 465
Oklahoma City, OK 73112
PHONE
Tech Support (405) 948-1766
Sales (800) 729-9500
FAX (405)917-2250
WEB SITES
BibleLibrary.com
Ellis Clinic.com
EMAIL
[email protected]
I have an Ml 110 G5 Server, But i could not find the VGA driver for the Win Xp , kindly assist thanks Justin
Hi, I m really sorry to say that but you have a Server Product and its built to run Windows Server Series on it (or Linux / Novell Netware).
This is the list of compatible Server list
Microsoft Windows Server 2003 Microsoft Windows Server 2003 for 64-bit Extended Systems Microsoft Windows Server 2008 Essential Business Microsoft Windows Server 2008 Foundation Edition Microsoft Windows Server 2008 R2 Microsoft Windows Server 2008 Small Business Microsoft Windows Server 2008 W32 Microsoft Windows Server 2008 x64 Novell NetWare 6.5 Red Hat Enterprise Linux 4 (AMD64/EM64T) Red Hat Enterprise Linux 4 (x86) Red Hat Enterprise Linux 5 Server (x86) Red Hat Enterprise Linux 5 Server (x86-64) SUSE Linux Enterprise Server 10 (AMD64/EM64T) SUSE Linux Enterprise Server 10 (x86) SUSE Linux Enterprise Server 9 (AMD64/EM64T) SUSE Linux Enterprise Server 9 (x86)
Here is the link for Drivers
Try to use the Driver for Windows 2003.
It has a Matrox VGA as I know. If you know which Matrox series you have, then Browse here for the Drives: Matrox Graphics Support. Make sure that you choose the Exact Driver software which suites the System.
Note: Not every product has the Driver Software for Windows XP.
Please rate the answer! Thanks for contacting Fixya!
3answers
I can?t get Microsoft Office to accept my product key
if you buy the original one.. as you said you cn always ask for a support from microsoft.. just provide details of payment and your problem..
Wifi removed how to reinstall wifi
I have not seen any other cases of complete Wifi connection removal - there would be no point in knobling a cost-saving, valuable capability. More likely it has simply been disabled, and can be re-enabled, and you can add profiles for the wifi spots that are active at work/home. see http://www.blackberry.com/newsletters/connection/business/i508/tips-tricks.shtml
My phone doesnt conect to my PC.
1. Make sure that the theme that you have downloaded is compatible with Nokia 5310.
2. Yes, there's a way to connect the phone to the PC without using the PC Suite. Follow the steps below:
* On your phone, go to Menu and then go to Settings.
* Go to Connectivity and then select 'USB data cable'
* Then connect your phone to the computer
NOTE: The computer should recognize the phone as Mass Storage Device. You may now save any file to your phone and it will be saved directly to the memory card.
Have a great day!
I have office 2007 enterprise. it's loaded on
try to default your office option..if no mettr appear..reinstal your office.
1helpful
5310 Nokia expressmusic phone unlock code???
The e-mail solution posted by Nokia below to unlock the media licence keys after firmware update worked and is thus (Note all your phone music will be wiped so will need to upload again from your PC):
1. Connect your phone to Nokia PC Suite in "PC Suite" mode. Launch PC Suite.
2. Use PC Suite Content Copier to back up the contents of the memory card onto the PC.
3. Disconnect the phone and format the memory card:
Menu > Gallery > (the memory card folder) > Options > Format memory card > Yes.
4. Re-connect your phone to PC Suite and restore the backed up data to the memory card.
3helpful
2answers
MS Office 2007 Enterprise installation setup error
Hi, this may not help you because I do not have the exact error you described. But here is some text from the MS website:The installation of the 2007 Microsoft Office suite Service Pack 1 (SP1) fails with error 1935 or with error 78F. This failure occurs when the Windows Installer encounters a reference either to a drive that no longer exists or to a removable media device that contains no readable media. For example, this failure may occur when the Windows Installer encounters a reference to an empty DVD drive or to an empty CD drive. The issue is not caused by the update design of the 2007 Microsoft Office suite Service Pack 1 (SP1). RESOLUTION loadTOCNode(1, 'resolution'); This issue is resolved by update 946691 for the 2007 Office system. Update 946691 is provided to resolve the problem that you may experience when you install the 2007 Microsoft Office suite Service Pack 1. You must install update 946691 on you computer before you install 2007 Microsoft Office suite SP1.
The following file is available for download from the Microsoft Download Center:
download.gifDownload the Office2007-kb946691-fullfile-x86-glb.exe package now. (http://www.microsoft.com/downloads/details.aspx?FamilyId=697BA2AA-0757-42C8-A530-5BD5566A54AD&displaylang=en)
So, here is what they say to do:
Remove the 2007 Office suite loadTOCNode(3, 'workaround');
  1. Exit all programs.
  2. Click Start, and then click Control Panel.
  3. Double-click Add or Remove Programs.
    Note In Windows Vista, click Uninstall a Program or Programs and Features.
  4. In the Programs list, click Microsoft Office Edition 2007, and then click Remove. In this item, Edition is a placeholder for the edition of Office that you installed.
    Note In Windows Vista, click Uninstall.
  5. Click Yes when you receive the following message: Are you sure you want to remove Microsoft Office Edition 2007?
  6. When the removal operation is complete, click Close.
Reinstall the 2007 Office suite loadTOCNode(3, 'workaround');
  1. Insert a 2007 Office installation CD into the drive.
    Note If your version of the 2007 Office suite is a preinstalled version, the installation CD is packaged in the white box that was included with your computer.
    Collapse this imageExpand this imagesecurityshield.jpg If you are prompted for an administrator password or for confirmation in the User Account Control dialog box, click OK, or click Continue.
  2. Enter the product key.
    Note If your version of the 2007 Office suite is a preinstalled version, the product key is located on the back of the CD case.
  3. Read the Microsoft Software License Terms, click to select the I accept the terms of this agreement check box, and then click Next.
  4. Select the type of installation that you want, and then start the installation process.
  5. When the installation process is complete, click Finish.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
