Question about FIC IC-VG61 (IC-VG61 (ICE-CUBE)) PC Desktop
Will the motherboard support both ATA100 and ATA133 IDE hard drives?
    Problem Solver:
  • 11 Answers
Depends on the motherboard and power supply but i would say yes because theres very little power requirement difference between them
Posted on Nov 20, 2009
Hard drive Compatabilaty
That would depend on the motherboard. But, if you computer was made for windows XP then I would say that should be fine. To be sure, just put the part number of the old one into your search engine and it will tell you the drive interface you need. The ATA 100 is the most likely interface you need.
Apr 30, 2013 | Computers & Internet
What hard drive do i need ? sata/pata?
you need an IDE harddrive UDMA ATA133/100/66
Feb 08, 2011 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
I formatted my secondary Hard drive and now it disappeared from "My Computer" and from "Disk -Management" . -But it still shows in the "Bios" and "Device Management" . I don't have access to it, what...
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
hope this helps
Sep 20, 2010 | Western Digital Caviar WD600JB Special...
What is the largest hard drive my Intel D845GBV Motherboard can handle?
The latest available in my country is 500GB
Check to your shop hard disks with protocol IDE ATAPI or ATA100
before buying
Jan 12, 2010 | Intel D845GBV (BOXD845GBVL) Motherboard
Need information please
This mainboard supports UltraDMA 66/100. UDMA is a technology that accel-erates the performance of devices in the IDE channel. To maximize performance, install IDE devices that support UDMA and use 80-pin IDE ca-bles that support UDMA 66/100.
Feb 25, 2008 | EliteGroup K7S5A Pro Motherboard
ASUS VIA KT133
Your motherboard does NOT support SATA drives, without an added SATA controller. It does support PATA drives, such as the Samsung SP2514N and the Seagate PATA drive you listed, as well as any other PATA drive. A PATA drive may be referred to as PATA, IDE, ATA100, ATA133, or even ATA66, but not SCSI, Ultra320, U320, or SATA, SATA II, SATA100, SATA300, etc.
The Seagate drives are easy to identify, their model number ends in AS if it is a SATA drive, and just A if it is a PATA drive.
Dec 05, 2007 | ASUS VIA KT133 Chipset A7V133 Motherboard
Hp compaq dc7600sff
750GB Seagate Hard Disk Drive IDE ATA100 7200rpm 16MB
available at http://www.microdirect.co.uk/(17679)750GB-Seagate-Hard-Disk-Drive-IDE-ATA100.aspx
1TB (1000 GB) Seagate Barracuda SATA II 300 32MB cache
also available at http://www.microdirect.co.uk/(23250)1TB-1000-GB-Seagate-Barracuda-SATA-II-300.aspx
Both HDD`s are what i consider to be best in there range and very good value for money
Nov 19, 2007 | Computers & Internet
ATA133 refusing to be accepted
Obviously mobo error, have you tried re setting bios from 'JBAT1' terminal, jumper from pins 1-2 to pins 2-3 then back on 1-2. Start up again and set time and select the auto detect HDD in standard bios settings see if correctly identified. save settings and restart pc
Jan 15, 2007 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
Can't find the cause for clicking noise and BSOD
From what I've read, the "clicking" is a sign that the hard drive is about to fail. The cause is using two devices (hard drives, CD-ROM drives, etc.) with different read/write speeds on the same IDE cable. For instance, you MUST not have an ATA100, ATA66, or ATA33 hard drive or CD-ROM drive on the same IDE cable as a faster ATA133 hard drive. Hope this helps
Mar 16, 2006 | Maxtor MaXLine Plus II 250 GB Hard Drive
FIC IC-VG61 (IC-VG61 (ICE-CUBE)) PC Desktop Logo
Top FIC Computers & Internet Experts
David
David
John Anderson
John Anderson
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
