Question about American Standard Cambridge 5' Americast Bathtub w/ Grab Bar Drillings & Le
Tub has huge dip in center - American Standard Cambridge 5' Americast Bathtub w/ Grab Bar Drillings & Le
  • 36069 May 11, 2010
    Is this a new install? Was it installed by a plumber? Is it spongy when you step in it?
  • 3 Answers
Yes, thats for you to sit in!!!!!!! dont 4get to fill it up with water first!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
Posted on Dec 14, 2009
What's your question?my Isuzu 4ja1 engine .my problem is the oil comes from deep stick
i think you mean
when running the engine
the DIP STICK seal as it fits the dip stick tube end. leaks oil
this a bad PCV valve.
excess crank case pressures.... cause by not doing service on car.
or worse a very worn out engine with huge blow by gassed.
is engine miles high? over 300k? miles?
or the dips stick seal there is bad.... looking at it tells you that.
Sep 20, 2015 | Isuzu Cars & Trucks
I just had a Maax Living tub installed but did not receive a manual. I searched the Maax website but could not find the answer I need: if I accidently push the drain, the water starts draining but I cannot...
The drain may have been installed incorrectly. It should not be that easy to "pop" open. In normal operation, you push it down until it latches in the closed position. Afterwards, you push it down to unlatch it and start draining.
Feb 08, 2015 | Maax Plumbing
Shakes like crazy spin
Your maytag washer tub and basket assembly sits on a base counter balanced by 6 springs. Is is possible to move the tub around by hand. The best test is to start a spin with the unit empty of cloths, allow the tub to reach speed for a few seconds, lift the lid and check the tub position after it stops, if the tub is off center with the lid opening, re center the tub and run spin again. If your tub returns to an off center stopped position you most likely will need the base kit replaced. The base kit replaces the entire bottom of the unit along with new springs, and snubber, if so packaged per your application. Maytag experienced a defective stamping dye when these bases were stamped, thus they were stamped crooked. This test is performed with the machine it's self relatively level on the floor. If the tub assy leans and favors any one direction while you are trying to center it with the lid open, you may have a rusted or broken counter spring in side the unit. Pleazer Appliance...
Apr 11, 2014 | Maytag Washing Machines
Tub center rusted out
Dawn, Try http://www.cottagecraftworks.com/ice-cream-frz-parts-white-mountain-freezer-tub-center-p-1613.html. There is a plastic center listed on their page.
Jan 30, 2014 | White Mountain F69206X 6 Quart Ice Cream...
Shortage of hot water
If you will make contact with George at M-One-Specialites he can track that down for you and help you get that fixed.
He has a very extensive list of repair parts for faucets.
Rod
US Parts Center
Jan 29, 2013 | Delta Faucet Closeout T17440 17 Series...
I am getting a huge clunk in the front end of my 1997 Ford F-250 when turning into a driveway with any type of dip to it.
That would be the frame rivets creaking and poking. You need the dealer to address this properly.
Jun 05, 2012 | Cars & Trucks
How can i check my transmission fliud level of my 2000 olds alero have no dip stick
there is no transmission dip stick on this car. It has a sealed system and you need to take it to the dealer or a repair shop who can work on this car.
May 27, 2010 | 2000 Oldsmobile Alero
Dip stick
the engine dipstick is in frt center of eng./the trans dip stick is yellow and on drivers side front of eng at the very bottom (you must look hard and move hoses and wires to get to it
Oct 19, 2008 | 2001 Volvo S60
Changing front loader seal
easy.isolate from mains. take top off.remove clamp that holds seal to cabinet and unpeal seal from cabinet. seal is held to tub by a clamp (like a huge jubilee clip) undo and peel seal from tub. when fixing new seal, lubricate with washing=up fluid
Dec 11, 2006 | Hotpoint WMA58 Front Load Washer
American Standard Cambridge 5' Americast Bathtub w/ Grab Bar Drillings & Le Logo
109 people viewed this question
Top American Standard Plumbing Experts
john h
Steve Wood Plumbing...
Level 1 Expert
Mike
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
