DOES THE STAND COME OFF THE TV IF YOU DECIDE TO HANG OFF THE WALL
SOURCE: Can not remove the stand to mount it on the wall
If the Aquos 46 is anything like the Aquos 42, the monitor is attached to the base with machine screws (bolts). They are located in the lower back portion of the monitor, probably need an Allen wrench to loosen and remove. Once that is done, the base can be removed from the monitor. Best way is to lay the monitor face down on a tabletop padded with foam, a quilt or blanket, etc to protect the screen as you work. Remove the stand from the monitor, not the monitor from the stand; it is easier and safer that way.
Posted on Jan 24, 2009
  • 23 Answers
SOURCE: Can't stand my tv straight up.
easy, order a new Base for the television, or get a stand that has back mounts, they cost about 200-400 bucks. goto costco and you may find a cheaper one.
Trust me i am the flat pannel guru.
Posted on May 02, 2009
westytech
  • 120 Answers
SOURCE: how do i remove the base of my westinghouse 42
You need to remove two screws in the lower back of the unit, you will then have to remove the DVD cover plate and finally 4 screws that are uncovered after you remove the cover plate. Hope this information has been usefull.
Posted on Jan 25, 2010
SOURCE: Took 6 screws out of back of stand on my Olevia
I just wrestled with this problem. The screws were backed all the way out but I could not remove the stand. I had to remove the screws completely from the holes, then the stand can be pulled down then off.
Posted on Oct 30, 2010
  • 39 Answers
SOURCE: How do you remove the bottom stand from the TV set
Most flat TV's actually have the stand held on by 4 screws on the back of the TV, not the bottom. Look closely and you should see them down 4 small holes. These hold the stand on. I think what you may have done is taken the bottom plate of the stand.
Hope this helps
TV_Doctors
Posted on Jan 06, 2011
I have a 50 inch sceptre x505bvf i need the screws for the back to hand tv on tv stand
When you purchase your stand or hang on wall, they come with universal screws to hang untit.
If not go to sceptre.com and request or purchase missing screws.
May 29, 2016 | Sceptre Televison & Video
How do i remove the tv stand from a 42 inch flat sreen so i can hang it on the wall
Before detaching the stand, unplug the AC cord from the AC INPUT terminal. Before performing work spread cushioning over the base area to lay the TV on. This will prevent it from being damaged.
With the tool you will be using to remove the stand remove the screws from the bottom back of the television and remove the stand.
Jan 08, 2011 | Televison & Video
How do you remove the bottom stand from the TV set so you can hang it on the wall? I have unscrewed the bottom of the stand, but there seems to be something internal keeping it attached to the TV.
Hope this helps
TV_Doctors
Jan 06, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Took 6 screws out of back of stand on my Olevia TV, but still can't remove stand so I can hang TV on wall
Oct 19, 2010 | Olevia LT32HVM 32 in. LCD Television
How do I take off the stand? I just hung the TV.
Take the TV down. there are 4 Phillips head screws one the back bottom that hold the stand on. take them out and lift the TV off the stand and hang it back on the wall. be sure to remove the stand screws and not the screws that hold the TV together.
Jan 11, 2010 | Akai LCT42Z6TA 42 in. LCD Television
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
How do you hang on the wall- i cant release the stand - help
If this TV have 4 fixing holes on the back (should be 100x100mm - VESA standard 100) then it is wall mountable and the stand should release - its normal to have a clip system or bolts holding the stand into place.
See this guide for more advice:
http://www.mountright.com/articles/?s=mount
Sep 14, 2009 | Astar LTV-19BG TV
Cant find how to remove the stand on our newly purchased Soniq QSL323CT1 anywhere in the manual. We are trying to mount it on the wall.
1. Disconnect all cables.
2. Cover a level and stable surface with a thick and soft cloth.
3. Gently lay the TV, face down, onto the cloth. Make sure the Table-Top stand is hanging over the edge.
4. Rotate the cable holder 90 degrees, and pull it out completely.
5. Remove the screws (3 or 4 in rear next to cable holder, depending on which model wall-mount kit you have) being sure to hold the Table-Top-Stand firmly while removing the last screw.
6. Do not remove any other screws from the TV.
They also say not to remove the stand for any reason other than wall-mounting the TV. Their should be instructions with the wall-mount kit.
Hope this helps!
Thanks
Smith.
Sep 07, 2009 | Televison & Video
May 02, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
