Question about Electronics - Others
I am getting no spark but power is going to my coil, it seems like it sparks when it wants to but most of the time it doesn't
  • Bill
    Bill May 11, 2010
    Make,model,year?
    Guru:
  • 597 Answers
Well you don't list a model or type of motor but with most coils like this they require some type of points or rotors that tell the coil when to send fire to the spark plugs. You might also have a crack in the top of the coil that causes the spark to not fire correctly or efficiently. If this is an older motor and you have points, the points may be burned and need to be replaced and adjusted to the correct firing gap. There are two leads going to the coil. One from the battery and the other lead comes from your points. That is the lead that sends the signal to fire. You need to follow that lead to it's source and that should lead you to the problem as to why the coil isn't firing correctly.
Posted on Nov 20, 2009
Riding lawn mower
get a spark tester and plug it into one of the plugs after it gets up to operating temperature. test the other one if you have good spark plugs and no spark going through the tester the coil may be breaking down. and needs to be replaced.
Aug 05, 2016 | Craftsman Garden
My ninja is losing power when i get into it. Idles great on all 4 but when i get going it loses power and seems to be just running on 3 cylinders. I have change spark plugs and wires and that didnt help....
Test the Coils . The coil produce the high voltage for wire plugs+spark plug+motor. If the coil is defective you ignition system can be wrong. see the diagram attached.
Jun 20, 2013 | Cars & Trucks
No spark going to spark plug
First you should get a new plug. Then look at the coil to see if it is got good ground.. Make sure the plug wire is good... If that doesn't work then check the coil if you can't find a dealer to check. Most electric components are under warranty, even some life time. Good luck.
Sep 11, 2012 | McCulloch Garden
18.5 hp Briggs & Stratton no spark after running out of gas
I believe you are right about heat induce electrical problem.
About all there is for ignition is the coil and breaker points.
Mar 05, 2017 | Briggs & Stratton Measuring Tools &...
Mechanical
Before you threw a bunch of parts at it maybe you should at least see if it has spark. If it doesn't have spark then the crank sensor and coil pack would be appropriate. If it is not getting fuel then the fuel pump, filter, etc. would be the way to go. So see if there is spark, do this by pulling a spark plug and see if there is spark out the end with it plugged into the wire and cranking it over. If there is spark put all this back together and squirt some fuel into the throttle body while cranking it over, if it tries to start but doesn't try to start on its own without squirting fuel in it then the fuel pump is bad. How many miles on it? Possibly the cam timing is off. Maybe take a compression check and see if the cam is out of time.
Mar 11, 2012 | 2001 Chevrolet Cavalier
My 1990 hond accord will turn over but wont start can you please help
MAKE SURE SPARK PLUGS AND WIRES IN GOOD CONDITION, REPLACE DISTRIBUTOR CAP AND ROTOR,CHECK FOR SPARK AT SPARK PLUGS,IF YOU DONT SEE SPARK CHECK TO SEE IF POWER GOING TO COIL IF NOT CHECK IGNITION FUSE.IF FUSE OKAY AND POWER GOING TO IGNITION COIL,COIL FAULTY OR IGNITER UNIT FAULTY. CHECK FOR FUEL PRESSURE MAKE SURE FUEL FILTER BEEN CHANGED.FUEL PRESSURE SHOULD BE 40 PSI. IF YOU GETTING SPARK AND FUEL. YOUR IGNITION TIMING OFF OR VALVE TIMING OFF DUE TO A WORN TIMING BELT.
Nov 01, 2011 | 1990 Honda Accord
2001 Harley Davidson Sportster 1200 C cranks but won't start. Doesn't seem to be getting spark to plug
Check your pick-up sensor located inside the timing cover,behind the adjustor plate. If the filament is not intact you will have no spark.
A defective coil, cam position sensor, or stator will also cause a no spark condition.
Good luck, i hope this will FixYa and get your bike back on the road.
Jun 28, 2011 | 2001 Harley Davidson XL 1200 C Sportster...
Hi, I have a 1998 cbr 600f3. There are 2 coils on this bike for 4 cylinders and two wires coming in and 2 coming out(spark plug wires going out). I can only get one side of both coils to fire so the bike...
Hi and welcome to FixYa,
On the 2 ignition coils:
  • two wires coming in - black/white carries/supplies IGN + 12 to both coils and the ignition control module. Coil1 (left) is connected to the ICM by the yellow/blue wire while coil2 (right) is connected through the blue/yellow wire;
  • 2 coming out - left coil powers 1 & 4 while right coil powers 2 & 3;
  • 1 &4 will fire together; so with 2 &3.
Good luck and thank you for asking FixYa.
Nov 11, 2009 | Honda CBR 600 F(3)T Motorcycles
1989 ford laser, seems o be no spark from the
CHECK TO SEE IF POWER IS GETTING TO THE COIL,IF IT IS COULD YOU TRY A REPLACEMENT COIL,[TRY TO BORROW ONE JUST TO TEST].
Oct 20, 2009 | Ford Laser Cars & Trucks
Electronics - Others Logo
139 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
