Question about Kenmore Washing Machines
My neighbor just moved & gave me her stackable washer/dryer & somewhere between her house & mine the washer doesn't aggitate on any cycle. I checked for loose wires & checked to make sure the motor hadn't seized up & didn't see any aparent problem... it does everything else, but hums instead of aggitating. It's less than a year or two from being new. Any ideas?
  • lesleyleehal Nov 20, 2009
    She just moved & had been using it so I'm sure the shipping bolts were removed & yes I can move the agitator by hand.
    President:
  • 3,085 Answers
Make sure the shipping bolts have been removed. Can you move the agitator by hand?
Posted on Nov 20, 2009
The washer won't start.
you must need to check the motor first if still working. you can directly plug the motor to the ac outlet to ensure if still good. if still good you can check the wiring, look at the wiring diagram post inside at the back portion of the cover serve as your guide.
Oct 12, 2012 | Frigidaire Washing Machines
I just got a used kenmore model number 110 88752792 stackable washer and dryer. it had a 4 prong cord.I live in a travel trailer, it has a 24 inch wide space for a stackable washer and dryer that the 110...
You will need to get 230v to allow the dryer to work if your service panel has 230 you will need to get a 30 amp two pole breaker and run 3 wire #8 in size. Then get the socket and plug for the dryer. The 110 in the model number simply means made by whirlpool and is a pretty good machine but requires 230 volts to dry with heat.
Jul 28, 2010 | Dryers
Washer on stackable unit won't start after it initially started..
Check the out of ballance switch. It' located between the tub and the cabenit. It sounds like it might have gotten broken when you moved it. You can bypass it by connecting the two wires together until you can replace it.
Please rate solution if helpful
Aug 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stackable washer dryer. Dryer buzzer is
Just solved this problem for a Kenmore stackable washer dyer! Sorry I don't have the model number. I have a baby on the way and a small house. I was pretty sure I would get no sleep between the baby crying and the baby crying because of that darn buzzer!
The buzzer is attached to the timer with a quick connect post. Access the controls by unscrewing the large panel above the washer door. You will need a square screwdriver or a very small flathead and some vice grips to get it started. The panel will fall forward onto the washer. In mine there was a pouch with an electrical diagram of the unit. To release the controls, two more screws must be removed from the sides of the small panel housing the controls. Once again you need a square screwdriver or a very small flathead and some vice grips to get it started. Once these are out you should be able to lift the control panel up and it will fall forward. Get a small box or stand to put on the washer. This will support the panel as the wires are not that long. On the left side of the timer controls you will see a quick connect post marked with an "H". Disconnect this wire and your problems are solved. Beautiful silence! I put electrical tape on the quick connect wire. Not sure if I needed to as I'm not an electrician. Hope this helps.
Apr 09, 2009 | Dryers
Washer won't drain or spin
sounds as if you have a lid lick/door switch issue, the machine is not recognizing the door being closed and for safety reasons will not enter spin/drain.. open anc\d close lid a few times slowly, cam you hear a "clicking noise" whe njust about closed?? id assume not replace teh lidswitch
Jan 21, 2009 | Kenmore 88732 Top Load Stacked Washer /...
STACKABLE WASHER/DRYER DISASSEMBLY
FLSE72GCS6 this model number is showin as a complete laundry center, not 2 seperate peices. in which casse there is no seperating them
Dec 09, 2008 | Frigidaire FEX831CS Top Load Stacked...
Kenmore stackable unit
Yes, you can use any safety 4-prong as long as it is a dryer cord rated at 220V.
Jan 08, 2008 | Frigidaire FEX831CS Top Load Stacked...
Kenmore stackable
Dryer probably element or thermostat, washer sounds like a suspension arm collapsed. Price up the parts & then decide if its worth it! Regards
Apr 09, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
53 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
