Question about GE Refrigerators
The freezer side of my GE GSS25PGMF is not working, but the refrigerator side is fine. Is there an easy/inexpensive fix?
  • GE Master
  • 1,606 Answers
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board ( you already know , since you changed it ) . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also .
Posted on Nov 20, 2009
  • francineande Oct 08, 2010
    THIS WORKED..THX
Ge gss25pgmf
Before replacing water valve open open back panel disconnected water line of water dispensser and tell some 1 to press water actuator on dispensor and check water pressure from it. If its slow then it can be valve or it can be filter housing. Repalce both if confuse.
Mar 03, 2014 | General Refrigerators
Frig not cooling-water line frozen
Check to see if the fan in the freezer is working. It moves cold air from the freezer side to the refrigerator side. If it is not working or if there is an obstruction in the duct work the issue could be there. Fans and motors are cheap and easy to replace.
Apr 12, 2010 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator no cooling,ice forming on back of side-byside freezer
The refrig is freezing up. I suspect the defrost timer isnt working. The timer activates a heater in the coils which allows them to warm and be self defrosting. If the timer isnt working this wont happen and freezer becomes an iceball. Take the panel off inside the freezer side and you will see the coil froze up. Defrost these with a hairdryer then replace the defrost timer inside the refrigerator behind the light and place where you adjust temp. If that dosent fix it it could be the heater itself but the only way to know is try that first. Easy fix should be inexpensive
Feb 22, 2010 | General Electric GSH22JSXSS Stainless...
Top mount freezer won't cool, fridge works fine.
check for compresor operation. a relay on compresor could be out
Feb 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a refrigerator GE GSS25PGMF and I have no idea how I should get inside of the freezer door. I do not see any screws.
The doors are not made to get into . All parts are accessable from the outside , except , for the water line inside the door .
The liner and waterline , are set on the door , and then insulation material , is then piped into the door .
Oct 09, 2009 | GE Refrigerators
GSS25PGMF FREEZER NOT WORKING. This morning when I opened the freezer door, everything was defrosted. The ice tray was half water. Their was frost on the inside back of the refrig. The regrig side...
You have a defrost problem. You can defrost the unit down by removing the back panel and get a hair dryer and go back and forth over the defrost. Make sure that you don't get any of the coils too hot or you'll destroy your unit. But you'll need a meter to check which part or parts are bad. Do you have a meter? But you will either need a defrost timer, defrost heater or a defrost themostat. But you'll have to have a meter to OHM out the defrost heater. If your unit beeps then you'll need to replace the defrost timer and defrost themostat. If the heater checks bad then you'll need to replace only the defrost heater.
Aug 20, 2009 | GE Refrigerators
GE Model GSS22JERFBB moaning sound form freezer section
That's the fan motor. Either the fan blade is hitting something or the motor is going bad. Either is a cheap fix.
Jul 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS25LGM freezer not working. It's about 8
it seems like the thermostat on the freezer side is not function right but does the motor of the freezer run or not if not check thermostat
May 16, 2009 | GE GSS25LGM Side by Side Refrigerator
Ge SIde by side SSS25KFMDWW stopped freezing
number one,is the freezer fan working?2,is there frost forming on the back wall of freezer?let me know more-mike
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
280 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
