Question about NetGear WGR614 Wireless Router
Lost the smart wizard installation disc...how do
Lost the smart wizard installation disc...how do i set t up with out it
  • NetGear Master
  • 32,281 Answers
The wireless router can be configured without a CD by using the IE browser.
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address. (http://192.168.0.1)
3. Enter the router setup, login and password (default login = admin
and the default PW = password)
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Posted on Nov 20, 2009
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Feb 04, 2011 | NetGear WNR1000 Router
I lost my password to my netgear. How can I retrieve it?
Go to NETGEAR Router.
After connecting the Router into your network, you must configure it. You can do this using the Smart Setup Wizard -- where the wizard will attempt to auto-detect the type of Internet service you have through your ISP -- or you can configure the router manually. It is recommended that, if you aren't used to setting up Internet connections, you let the Smart Setup Wizard do some of the work for you.
To configure the router, you'll use the information that you filled out earlier in the Installation Guide.
To get started:
  1. Select Yes if you want to use the Smart Setup Wizard.
    or
    Select No to configure the router manually.
  2. Click Next.
Nov 06, 2010 | NetGear WGR614 Router
How to use a recovery disc for presario cq 60 206us
Set your 1st boot to CD/DVD from your Bios Setting or use the hp Boot utility when you restart your computer.
Insert your Recovery disc into the CD/DVD Rom and reboot your computer. Just follow the installation wizard to install your system back to default/original settings. All of your data will be lost.
**Note
When you use the Recovery disc all the setings will be reverted back to the original settings. Back up or save your data before you use the Recovery disc.
Hope it helps.
Oct 19, 2010 | Computers & Internet
Good day to all. I have a problem of my NETGEARWPN824V3
To access the Smart Wizard installation and configuration program on your router:
  1. Connect your router to a computer by plugging one end of an Ethernet Cable into any of the four LAN ports on the back of your router.
  2. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  3. To install your router, simply click on the "Setup Wizard" link at the top of the left-hand navigation menu once you are logged into your router.
Configuring Smart Wizard for WEP encryption:
  1. Click Start then go to All programs. Look for NETGEAR wireless adapter folder then select the NETGEAR Smart Wizard.
  2. NETGEAR Smart Wizard wireless utility should appear on your desktop screen.
  3. Click on the Networks Tab. This will automatically scan for all the available wireless network within your proximity.
  4. Select the SSID of the wireless network that you want to connect, then hit the Connect button.
  5. On the Settings tab, click WEP under the Security option then select Enter Key Manually.
    Note: If the network key consists of 10 characters, set it to 64 Bits. If the network key consists of 26 characters, set it to 128 Bits.
  6. Type the 10 or 26 characters (Hexa decimal) keys on the space provided.
  7. In the Profiles field, assign a name to help you remember this wireless network settings in the future, then click Save Profile.
  8. Click on Apply to validate the settings.
  9. Once connected wirelessly, go to About tab and check for an IP address.
Configuring Smart Wizard for WPA encryption:
  1. Click Start then go to All Programs. Look for NETGEAR wireless adapter folder then select the NETGEAR Smart Wizard.
  3. Click on the Networks Tab. This will automatically scan for all the available wireless networks within your proximity.
  4. Select the SSID of the wireless network that you want to connect, then hit Connect button.
  5. On the Settings tab, select WPA under the Security option.
  6. Type the WPA password/passphrase inside the empty field next to the WPA drop down menu.
Best of luck and have a happy and safe 4th of July weekend!
Jul 02, 2010 | NetGear RangeMax WPN824 Router
No installation CD
Lost or Unable to use Router Configuration CD Problem: var js_3;function initPsDisplay(){js_3 = new PsDisplay({"info":{"controller_name":"PsDisplay","name":"PsDisplay_3","type":"FormField","w_id":3},"attrs":{"label":"","tabindex":"","field_name":"description","cf_id":"","table":"answers","highlight":0},"js":null});js_3.init();}YAHOO.util.Event.onDOMReady(initPsDisplay);
NETGEAR does not replace lost or broken CDs because the Smart Wizard installation and configuration utility on the CD is already built into your router management software. There is no need to download anything to replace the CD - everything you need is in your router. This is true even if:
  • the CD that shipped with the router has been lost or cannot be read, or
  • errors occur when running the configuration program, or
  • the router is not connected to a computer using the Windows operating system.
Workaround: var js_4;function initPsDisplay(){js_4 = new PsDisplay({"info":{"controller_name":"PsDisplay","name":"PsDisplay_4","type":"FormField","w_id":4},"attrs":{"label":"","tabindex":"","field_name":"solution","cf_id":"","table":"answers","highlight":0},"js":null});js_4.init();}YAHOO.util.Event.onDOMReady(initPsDisplay);
A video walk-through of installing and configuring your router using the Smart Wizard is available at http://kb.netgear.com/app/answers/detail/a_id/12873.
May 10, 2010 | NetGear DG834G 54 Mbps 802.11g Wireless...
NETGEAr support
not sure exactly why you would need the setup software... you should be able to plug it in and access the routers firmware and set it up that way.
here is the link to the site for your hardware.
http://kb.netgear.com/app/products/model/a_id/2591
Jun 01, 2009 | NetGear WGR614 Wireless Router
Hp4300 series disc won't work with my new hp window vista computer my printer is a 4315v
Please perform the steps given below and check if yuo are able to fax
1. Open a MS Word Document.
2. Click File -> Send to -> Recipient using a fax modem.
3. Follow the instructions given in the fax wizard. Ensure that you select the HP all-in-one as the fax program.
Now check whether you are able to send the fax.
OR
Try setting up the Fax once again
=== Fax Setup wizard ===
- Double-click on the HP Solution Center to open it.
- Go to Settings --> Fax Settings & Setup --> Fax Setup Wizard.
Complete the fax setup wizard and then, try to fax
Vishwanath V U
May 19, 2009 | HP Officejet 4315v All-In-One InkJet...
Net Gear PS121 print server, prints test page but not word docs
It's a driver problem not installed properly on the XP machines. Here's what you can do. Install first the driver of the printer directly to the XP machines. Then try to re-do the smart wizard installation.
Dec 02, 2008 | NetGear WGR614 Router
Earthlink
I hope you already have Easy set-up with Smart Wizard® installation CD with you. Connect router with LAN connection to your desktop and install software CD then it will ask you to provide DSL settings,for that better contact your ISP help desk they will give you in detail. netgear Easy set-up with Smart Wizard easy to use just you need ISP settings. good luck!
Dec 15, 2007 | NetGear RangeMax WPN824 Router
NetGear WGR614 Wireless Router Logo
1,066 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
