Question about Olympus Camedia D-435 Digital Camera
I have my camera connected to the USB cord and the USP cord plugged into my PC. I turned the camera on and chose PC on the menu then nothing...why aren't they automatically uploading?
    Brigadier General:
  • 11,967 Answers
The easiest solution is to use a card reader to download your pics to a folder you create on your desktop.
Posted on Nov 20, 2009
I have a GC-XA2BU and the camera will not cut on? I have purchased a replacement battery but neither work.
As soon as you connect a camera to a computer, it will stop working, because the USB connection will be used to charge the battery.
If your computer is not correct wired on the USB port, or when you are using a hub, without an external power supply, the battery will not be charged. So you end up with an empty battery and a camera that does not respond.
Try charging the battery on an external charger and remove the USB cable, before switching on the camera. Also check if the USB connector on the camera is free. Avoiding the camera to "think" there is still a USB cable connected.
Feb 11, 2014 | Cameras
Purchased a Polaroid x800 camera and can not transfer photos to computer (and I have tried 3 computers - 2 running XP Pro and 1 running Windows 7). Upon connecting the USB cable it shows up as a removable...
Just did this with my daughter and it worked:
1. Turn PC on.
2. Plug camera cable into Camera.
3. Plug camera cable USB end into computer USB port.
4. Turn on Camera... wait until camera show message 'USB, PC, Pictbridge'.
5. PC should be selected if not select by highlighting and press shutter button.
6. Press 'Shutter' button.
7. Window 'Autoplay' appears on PC. Select 'import' in Autoplay window.
8. Another window will ask you to name your picture folder. Give it a name.
9. The pictures download to the picture folder automatically.
10. Turn the camera off and disconnect cable from camera and from the PC
11. ENJOY!!
Nov 10, 2010 | Polaroid Cameras
When I plug in the usp port cord to my computer and turn on the camera the camera will first flash on then try to connect to the computer, then flash on again and disconnect from the computer before any...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Oct 21, 2010 | Nikon COOLPIX S630 Digital Camera
Sony camera says Switch on [MENU] when i upload pic from USB cord
1) Try uninstalling then re-installing your Sony software.
2) When you connect to the PC and switch on, Click on Start - "My Computer". Your hard drives and disk drives should appear in the window.
Have a good look, is there a new drive, it may be called Sony, or USB mass storage device it may just be called drive E or F.
If so double click on that drive, if there's a folder there, double click on there, with luck you should see your pictures, that new drive is really your camera.
You should be able to move pictures by copy and pasting. Once copied you can deleted them from your camera.
3) You can buy a device called a "Memory card reader" Make sure its good for sony memory sticks.
You take you card from you camera and put it in the card reader. Then, once plugged into a USB port its just like another HDD as described in 2.
4) I should have said this first, try another USB port if you can, it my just be dust in the port making life hard............
Good Luck.
May 08, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
Nikon coolpix s210 will not connect to mac
I have a Intel Mac Powerbook running OS10.5.8
On a coolpix 100, the default setting is that the camera is charged by the computer through the USB cable. You need switch that OFF.
While the camera still does not show as usb device, you can access it through the Nikon transfer program AND through iPhoto
ez-pics
Mar 19, 2009 | Nikon Coolpix S210 Digital Camera
Devise not responding
The same thing happened to me,
turn your camera on, hold down menu/ok button, click over to the wrench tool which is called the setup menu, scroll down to USB Configuration, click on it, then scroll to disk drive and select it.
Now try turning your camera off and then back on, connect USB cord to computer and you should be all right.
Nov 11, 2008 | HP Photosmart M525 Digital Camera
Help with camera
Try a different usb port.
1>connect the cord to the computer
2>connect the cord to the camera
3>turn the camera on.
Disconnect in the same way, or you may damage your camera.
Also don't forget to check batteries.
May 25, 2008 | Vivitar ViviCam 5100 Digital Camera
What's up with my camera
You will probably have to go into "My Computer" and find your camera in the "Devices with Removable Storage". It should be there, otherwise, try plugging it into a different USB jack on your computer, if you have one.
Dec 06, 2007 | Samsung Digimax S630 Digital Camera
UPLOADING
first, open Windows Explorer and then search for the drive letter that Windows has automatically selected to be your camera's memory card. If you cannot find it (remember to right mouse click over each letter to see a short description). Once found on Windows Explorer, double mouse click it and then search all camera memory folders for the video files. You can then right mouse click and copy each file and then past (rt. mouse click select paste from pop-up sub-menu) each file onto your pc hard drive.
Aug 01, 2007 | Samsung Digimax S500 Digital Camera
Can't Upload Pictures
What kind of system are u using? Mac or PC? What version of windows? If you are using their photoloader software please check the following: In picture taking mode press menu Go to setup tab Go up to USB press right arrow and highlight mass storage. press set. try that. If that doesn't work then try this: In picture taking mode press menu Go to setup tab Go to USB press right arrow highlight PTP press set. This will allow you to chose which program to open with. Chose the Microsoft scanner/camera wizard and then just follow prompts.
Aug 07, 2006 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Olympus Camedia D-435 Digital Camera Logo
149 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
