Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
My bissell pro heat cleaner stopped spinning but the belt is good what can i do to fix it
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rtthhgs
Posted on Sep 30, 2010
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
How do I change the belt on my Bissell Pro Heat
heatman101
twerw
Apr 16, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
I need a manual on bissell pro-heat steam cleaner. I have forgotten how to change the belts.
heatman101
Jan 30, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Brush not moving in Bissell pro-heat
if the belt is more then 6 months old or more, then the belt will have to be replaced reguardless of the way it lookes. belts can stretch over time and when you put the machine on the carpet the friction causes the brush to stop because the belt has stretched. i would try this first. hope this helps
Jul 30, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
I have a Bissell Pro Heat 2X carpet cleaner and the brushes spin, then stop. I turn it off and when I re-start, the brushes do not spin until I push foreward. The it spins and stops again. Both belts are...
The reason for the brushes to stop when it is above any surface is there is a switch in the handle that stops the brushes so it dont burn your motor up it may have a faulty switch.
Jul 14, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
I have a bissell pro heat water wont come out
The pump may spin but the vanes inside could be broken or worn enough that they are unable to push water through the pump system. I am repairing a Bissell Model 8920 Pro-Heat 2X that has this very same problem.
I tested all the hoses to verify that they were not plugged. I then hooked the water and cleaner tub from the rear directly to the pump and held it above the pump assembly and water barely went through it with gravity feed and the pump was visibly spinning. The pump assembly can be acquired from AE Carters for $10.00.
I do not give any guarantee that this is the only problem.
Ron Goodrich
May 16, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Water/solution flow problem
check your belts. if your brush is not spinning when you have it on, it is a belt. goto bissell.com and there you will find on line videos to help you with this troubleshooting process, it will also tell you how to change it.
May 12, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
How do you change belt on Bissell pro heat carpet cleaner. can you please send diagram or instruction how to change belts.
http://www.bissell.com/images/UserGuides/7950_1204.indd.pdf
here is the complete manual (it is in pdf form)includes diagrams & instructions on belt replacment.thanx for using fix-ya!!!please rate all replys.
Nov 30, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Pro Heat 2x steam cleaner, problems!
Must likely the brush motor is bad. The top cover has to come off to check it, this is where the tank sits on. Part # 2036757 and is #35 in the pix.
Mar 14, 2008 | Vacuums
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
42 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
