Question about RCA HD52W56 52" Rear Projection HDTV
My tv keeps shutting off at random intervals. It doesn't happen every day, but today it has happened six times. It doesn't feel warm to the touch, and I have vacuumed all the vents. How do I fix that or what is the problem?
  • redheadeddev Nov 21, 2009
    The expert opinion I received directed me to a website for online tv. Is this a sarcastic joke? I think that is passing the buck to an ultimate degree. If you don't know, say it. Don't waste my time with such stupidity and frivolity.
3 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: Cutting off at different intervals
it could be high voltage cap located by flyback,if you have back off of tv and turn tv on,you will see green led's turn on,(on the board)if they turn off there is a small blue high voltage cap hidden under glue(i believe it's a 102 cap)that would be the one change,99% of time that is what will fix problem
Posted on Dec 15, 2007
  • 979 Answers
SOURCE: rca d40w20 rear projection tv with popping noise
It sounds as if you have a grid to anode short that is inconsistent. I would try to get the warranty company to just go ahead and replace all three tubes and be done with it. But, this is only my opinion, and past experiences with these sets. An aside; the more brightness level you ask of the tubes, the more this can be aggravated, as a general rule. Try different sources and program content and see if this is the case. Those scenes with more luminance (brightness) will stress the tubes more than low-level or dark scenes. See if that helps...accordianman
Posted on Jun 25, 2008
Jumps forward when brakes are applied at intersections when stopping. Doesn't happen all the time.
SOUNDS LIKE YOUR BRAKE PADS ARE DOWN TO THE METAL CANGE THEM IMMEDIATELY WHEN VEHICLE STANDS ALL DAY THE PAD METAL BACKING RUSTS THAT MAKES THEM HOWL
Oct 19, 2012 | Pontiac Grand Am Cars & Trucks
Random single beeps coming from the laptop. Diagnostics came back clean. The beeps can happen one, two, several times a day and random intervals or go days, weeks without any beeps.
hmmmm sounds familiar, i had the same issue it turned out to be a cracked ram clip that caused the random beeps from time to time. i would take a look at your ram and reseat and check for damage to the clips.
May 28, 2011 | Dell Precision M4500 Notebook
I have an Acer Aspire 6530 running Windows Vista and today it started shutting off at random. When it shuts off the bottom 2/3 of the screen has blue stripes across it, and on the blue is text I cannot...
Good question.
Does the computer feel hot when it shuts off?
Does it always happen at the same exact time?
Can you try booting the computer into Safe Mode? (What Happens?)
First thing I'd try is uninstalling the video adapter driver under device manager and restart the computer.
Let me know what happens!
May 20, 2010 | Acer Aspire 6530-5143 Notebook PC
Our 32" Sony Wega CRT TV randomly shuts off. It starts to dim then completely shuts off. This is happening at faster intervals. (Shorter on times)The indicator led blinks 6 times after the random shut...
monitor if b+ voltage normal, if fluctuate check for the power supply area ckt parts for some discrepancy on biasing. if supply normal check on horizontal section area also replace crystal capacitor and check.
Aug 22, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Shuts itself off periodically
If the period of time in question is reasonably consistent - say 45 minutes after powering up it shuts off - you could be suffering from an overheating issue inside the unit. Temprature sensors can override manual operation and shut the unit off to avoid greater damage (or even a fire) occuring. Have the TV serviced.
If you find it happens at random time intervals from cold this is less likely to be the case and it could be relative to the mains power supply going to the TV. If you suffer from 'dirty power' (power that dips and surges instead of giving a consistent voltage) this could also cause an automatic shutdown condition within the TV. This could happen at any time after the unit has been turned on. An unterruptible power supply (UPS) would help with that.
Aug 18, 2009 | Vizio L32 32 in. LCD HDTV
Laptop running Vista gets 'blue screen' and shuts itself down
This type of problem happens a lot. Usually its associated with heat and dirt(dust). A good cleaning will increase your air flow and probably fix your problem.
Either way you MUST see whats happening inside...it can certainly be insects clogging critical areas...I've seen it before.
Apr 24, 2009 | Toshiba Satellite A135-S2386 Notebook
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
TURNS OFF BY ITSELF
my tv starts turning a red color and then turns off by itsself then i have to unplug it to turn it back on every 5 mintues or so.
Nov 14, 2007 | Toshiba 46H84 46" Rear Projection...
RCA HD52W56 52" Rear Projection HDTV Logo
60 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
