Question about Philips Magnavox 9P6034C 60" Rear Projection Television
The green light comes on but nothing else. No picture or sound. Before it quit, the picture would shrink in around the edges then bounce back to full screen. Now nothing happens but the green light. Its a Magnavox 9P6040C1 RPTV. Thanks.
SOURCE: picuture shrinking color fading
I have the same Tv.. Repair tech said it was the deflection board. Cost $395.00 to repair.
Posted on Mar 01, 2009
Ecollier2012
  • 3459 Answers
SOURCE: Philips Magnavox 55P8288 Entire picture has green
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Apr 11, 2009
Ecollier2012
  • 3459 Answers
SOURCE: 61 inch phillips magnavox tv with no picture or sound
Its a common problem with this model.
Goto www.TvRepairKits.com and get their kit + instructions for the shrinking video problem.
Posted on Jun 21, 2009
Ecollier2012
  • 3459 Answers
SOURCE: Picture shrinks toward the center of the screen
Common problem with Philips sets.
If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original chips, email/phone support, etc.
  • 162 Answers
SOURCE: I have a magnavox model 9P5511C102 the picture shrinks.
Try the site www.TvRepairKits.com. They have a kit + instructions for this problem.
Posted on Aug 09, 2009
Pride GoGo Ultra X battery meter needle
you could have a bad throttle pot o speed pot possibly a key switch problem aswell. Hi I a Phillip the "DFW Mobility Specialist"send me a email at dfwmobilityspecialist@yahoo.com if you live in or near the Dallas Fort Worth area.
Apr 10, 2013 | Pride Mobility Products GoGo Ultra X...
Philips Magnavox 9P6031C103 projection tv quit working 2 years ago (before, the picture began to shink and expand until it finally quit completely with no audio nor video -- turned it on two years later to...
Based on what you described I would say your TV has the "shrinking and expanding" fault. Its a common problem on that model and the symptoms can range from the video shrinking and expanding or no video or no audio....You can read more about this fix on the site www.TvRepairKits.com
Jan 13, 2013 | Philips Magnavox 9P6034C 60" Rear...
Magnavox 55 rear projection has no power
This is a common problem. You can get parts and instructions from www.TvRepairKits.com . Find your model on their site and get the shrinking and expanding kit.
Mar 20, 2010 | Philips Magnavox 9P6034C 60" Rear...
Picture tube going out?
Not ur tube.Ur convergence,dying or be dead.U need a convergence kit.U know how to solder right?Replace what in that kit.Tries these websites.Tv Repair World.com
Sep 29, 2009 | Philips Magnavox 51MP392H Rear Projection...
Jun 17, 2009 | Philips Magnavox 9P6034C 60" Rear...
Bad picture around the edge
Hii...
I'm not quietly sure...but sounds like you have much bad caps...I'll try to find out more...
Thank's
[Vrya]
Mar 04, 2008 | RCA F36650 36" TV
60" Projection - Screen shrinks down then back up
I had the exact same problem. The screen would shrink then expand. After thrity minutes it would correct itself. Then one day it just broke - no sound and no video. I searched these forums but did not find clear instructions on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.  To help others like me I documented the fix and created a step by quide and repair kit to fix the problem. You can find it here. http://www.magnavoxhelp.com
Jan 19, 2008 | Philips Magnavox 55P9271 55" Rear...
Philips Magnavox 9P6034C 60 in. Rear... Problem
I had a similiar problem. My screen would shrink in then expand. After a few months of doing this it just broke altogether. No sound or video.  Its not fixed.
You can get a repair kit from this site.
http:///www.magnavoxhelp.com
Sep 28, 2007 | Philips Magnavox 9P6034C 60" Rear...
Power light on but no picture
what is nothing happens? try putting in some signals and give us a full history.
Aug 10, 2007 | Philips 26MF231D 26 in. LCD Television
Shrinking Picture
sounds like your main power supplyis going bad . It supose to be 130 dc but I'll bet its down to around 90 to 100 volts!!! its probably the main filter cap or the regulator IC . hard to say without measureing the b+ good luck
May 01, 2006 | RCA HD61LPW42 61" Rear Projection HDTV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
107 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
