Question about MumboJumbo 7 Wonders of the Ancient World for DS
It says check device type, direct 3d does not support the queried technique... just installed windows xp pro and directx 9.0c still get same message???
Problem with windows 8 pro 32 bit: Fatal error couldn't create device directX error message: dderr_unsupported project igi i m going in
not sure if this question is about windows XP or windows 8.
sound as if directx/java was not installed correctly or not enough memory.
how many times has this happened? if more than one i would reinstall.
good luck
Dec 11, 2013 | Microsoft Windows XP Professional With...
How i download direct 3d device 9?
"direct 3d device 9" is the directX for Win98. For Windows 98 you have to install DirectX 8.1b. If you graphic card does not support 3D function you will not have "3D acceleration".
For DirectX 9, try this link @ http://www.falconfly.de/directx.htm
Hope it helps.
Aug 27, 2011 | Microsoft Windows 98 for PC
I get an error when loading directs. It say That d3derr is not avaliable. What does that means.
Are you trying to play any games? Check the configuration required to play that game. you can try to upgrade the directx.If it works,
However the error D3DERR NOT AVAILABLE means This device does not support the queried technique.
Sep 30, 2010 | Microsoft Windows XP Professional With...
The game crashes when i start a match
Minimum system requirements
80 MB Hard Disk space
32 MB RAM (64 for Wýndows 2000)
DirectX 7.0a
Mouse
Keyboard
Notes on Sound and Video Cards
a.) Problems with the Intel i740 Chipset
Users with an Intel i740 chipset may experience a dithered pattern overlaying the game in the front-end. Gameplay should remain fully playable.
b.) Problems with the ATI Rage Pro Chipset
For Windows 98 users:
The recommended drivers for the ATI Rage Pro chipset are the latest reference drivers found on http://www.ati.com/. We recommend Version 4.12.2632.
For Windows 2000 users:
Ensure that DirectX 8.0 is installed. It can be downloaded from http://www.microsoft.com/downloads/release.asp?ReleaseID=27742. Once installed, right-click on the FIFA 2002 shortcut on the desk top, select Properties, and add "3D=dx8z" to the end of the "Target" property.
c.) Problems with the S3 Savage4 Chipset
Users with an S3 Savage4 chipset may experience minor graphical issues in the front-end. Gameplay should remain fully playable.
d.) Problems with the KYRO Chipsets
In 640x480 the Pause menu overlay will appear to be missing part of the background. To fix this issue, set the resolution to 800x600 or higher. This will not affect game play in any way.
e.) Video Cards NOT supported by FIFA 2002
3Dfx Voodoo 1
3Dfx Voodoo Rush
Hercules Thriller 3D
Diamond Stealth II
Number Nine Revolution IV
ATI Rage II
Chromatic Mpact 2
S3 Virge
S3 Virge VX
S3 Virge DX/GX
S3 Trio 3D
Notes on Windows
FIFA 2002 supports Windows 95b, Windows 98, Windows 2000, Windows ME and Windows XP.
*NOTE - To install the game properly on Windows 2000/Windows XP, you will need administrator access to your machine. Consult your Windows 2000/Windows XP documentation for more information.
Known problems with Windows 2000/Windows XP:
During testing, some video cards experienced problems due to driver incompatibility issues. Check your 3D card manufacturer's web site to obtain updated Windows 2000 or Windows XP drivers.
Jul 06, 2010 | Electronic Arts FIFA Soccer 2002 for...
Direct x features - direct draw acceleration direct 3d acceleration AGP texture acceleration are missing. how can i get?
hi, check whether directx is installed. type this command in run DXDIAG.
If you running XP it would be directx 9C and for Win 7 directx 11.
if you want downland directx latest visit microsoft.com/directx
Jun 14, 2010 | Computers & Internet
I can not play game in my laptop.when i open the game it says can not connect to d3d device.check directx.what will i do?
Hi!
Microsoft DirectX is a software for handling multimedia task, video and game programing. You can download DirectX compatible for the operating system that you use in your laptop.
here are the list, select the file suited for your operating system, click it and save to start downloading, once finished, install it on your computer.
1. DirectX10 - windows vista sp1 & sp2
2. DirectX 9.0c - windows xp sp2
After installing the right directX for your operating system, try to play the game and direct 3d settings will work..
Please rate if this solution work...thanks..
May 27, 2010 | ASUS P5V800-MX Motherboard
I cant play supreme commander, it says cant create direct 3D
try downloading latest directx drivers and also upgrade the graphics drivers on ypour system
Feb 24, 2010 | Microsoft Windows XP Home Edition
HELP xpert 2000 pro ultra 32mb agp drvers
Please take the time to read this link from microsoft Your issue is with your Direct X setup.
Oct 21, 2007 | Ultra Xpert 2000 Pro Rage 128 32mb 4x AGP...
3d direct device
I think ya need to enable DirectX So, to enable DirectX, you must first enable graphics acceleration. To do so follow the next steps: 1. Right click on the desktop and go to Properties, Settings, Advanced, Troubleshooting. 2. Set the Hardware acceleration bar to Full. 3. Click Ok all the way out. To activate Direct3D and DirectDraw (DirectX) follow the next steps: 1. Go to Start/Run and type "dxdiag". 2. Click OK. 3. Click on the Display tab, then click on the Enable button for DirectDraw and Direct3d. 4. Click Ok all the way out.
Aug 17, 2007 | Microsoft Windows XP Professional With...
MumboJumbo 7 Wonders of the Ancient World for DS Logo
682 people viewed this question
Top MumboJumbo Video Game Consoles & Games Experts
ray gallant
Tom Chichester
Are you a MumboJumbo Video Game Console and Game Expert? Answer questions, earn points and help others
