Question about Black & Decker Steam Xpress AS250 Iron with Auto Shut-off
I have a Black and Decker Digital advantage Iron - It flashes an error message and won't heat up? What do I do to reset it?
SOURCE: The Clean light on my Black & Decker Digital
I found a previous answer on FixTa.com that had a link to the owners manual for my iron. The info I needed was there and my problem is resolved!
Posted on Jan 13, 2010
Testimonial: "Exactly what I needed..."
SOURCE: Does anyone know how to
I think I have the solution now!
First of all, remove the temperature knob. Than remove the temperature indicator (it's like a little disc). Theres a hidden screw under the temperature indicator! Remove that screw and continue with your fixes.
I hope it could help you.
Jardel
p.s. - Sorry for my noob english...
Posted on Mar 07, 2009
electrodynam
  • 35 Answers
SOURCE: the black and decker iron wont heat up
It probably has a high temp overload opened up inside or the thermostat control has gone bad.You can only tell for sure by taking the unit apart and testing the circuit for continuity.The steam feature on the iron is heated by the same element that heats the iron so it wont work.the element itself could also be bad,but I have never seen one go bad.You will have to check each component seperately to find the damaged part.or you can test the whole circuit at the plugs end,and use a jumper across each part until you have continuity through the unit.Make sure the thermostat is turned all the way up.the part that you are bypassing when you get continuity is the bad part.
You can buy a cheap continuity checker at any lowes,or even wallmart for that matter.
Posted on Mar 16, 2009
stonephoenix
  • 563 Answers
SOURCE: How do I clean my Black N Decker Advantage Iron
I work for Black & Decker customer service. Our number is 800-231-9786.
You can obtain a new manual for free by visiting www.useandcaremanuals.com. Below is the section from the manual on care and cleaning of your iron.
Care and Cleaning
This product contains no user serviceable parts. Refer
service to qualified service personnel.
It is not necessary to empty the water reservoir after each
use of the iron, if you iron frequently.
To empty the iron, hold the iron over the sink with the tip
pointing down. Water will stream out of the water fill
opening.
TO CLEAN THE OUTSIDE SURFACES
• Unplug and allow iron to cool completely. Wipe the
soleplate and outer surfaces with a soft cloth
dampened in water and a mild household detergent.
Never use abrasives, heavy duty cleansers, vinegar, or
scouring pads that may scratch or discolor the iron.
• After cleaning, iron with steam over an old cloth to
remove any residue from the steam vents.
ABOUT THE SELF-CLEANING SYSTEM
• Use the self-cleaning system to flush out minerals and
lint. If lint is allowed to accumulate in the vents, it can
scorch and cause brown spotting.
For Models D2000 and D2020: Clean about once a
month.
For Models D2010, D2030 and D2035: A "CLEAN"
indicator will appear in the digital display to notify you
when your iron needs cleaning (A).
• Fill the iron as described in "How to Use" but keep the
water level below the MAX line. Plug in the iron, set
the temperature to 6, and stand the iron on its heel
rest. Allow to heat about 3 minutes.
• Unplug the iron and take it to a sink. Holding it
horizontally over a sink, move and HOLD the variable
steam dial in the CLEAN position ( ). There may be
some hissing and spitting while self-cleaning. This is
normal.
• Stay clear of HOT steam and boiling water as it comes
out of the vents while lint, scale, and minerals flush
through! Continue to hold the variable steam dial in
the CLEAN position until all the water has emptied.
If necessary, rock the iron side to side and front to back
to empty it.
• When finished, release the variable steam dial, stand
the iron on its heel rest, and plug it in. Heat for about
2 minutes to dry out any remaining water then unplug.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 04, 2009
heatman101
  • 43501 Answers
SOURCE: Black and Decker AS775 Iron won't reset to heat up.
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
How to fix a Black and Decker Iron?
irons are not meant to be fixed due to their construction. the cost is generally more than a new one ( if you could get the parts)
take it to an appliance service centre to determine exactly what is the fault but be prepared for a "new one" answer.
May 08, 2014 | Applica Black And Decker Steam Advantage...
How do you replace the cord and or dismantle a Black and Decker Digital Advantage Iron
have this done by an accredited appliance service shop as it is not a job for beginners.
Feb 19, 2014 | Applica Black And Decker D1500 Digital...
Instructions for steam clean on B&D iron
http://useandcaremanuals.com/pdf/D1200,D1500,D1600,D1650997.pdf
Or http://useandcaremanuals.com/SearchManuals.aspx?SiteID=4
Hope this helps you.
Aug 01, 2010 | Black & Decker Irons
The Clean light on my Black & Decker Digital Advantage iron has come on and I can't find my manual. How do I 1) clean it and 2) get the light to turn off?
Jan 12, 2010 | Black & Decker D2030 Iron
Stopped heating
I work for Black & Decker. Any part that someone is telling you to purchase for that iron isn't from Black & Decker. Their irons are no designed to be repaired. If the iron is no longer heating, it needs to be replaced. Please call our customer service department at 800-231-9786 so that we may determine your warranty status.
Please post a comment if you need additional assistance so that I can help you further.
Jul 20, 2009 | Black & Decker D2030 Iron
Need the repair manual for a black and decker digital advantage iron. I will turn on but will not heat. rmsc
I work for Black and Decker customer support. Our customer service phone number is 1-800-231-9786.
If the iron isn't heating, it needs to be replaced. Unfortunately, the unit can't be repaired. The unit comes with a one year warranty from the date of purchase. Please call the number above so that we can determine your warranty eligibility and help you any way we can.
May 04, 2009 | Black & Decker D2030 Iron
Black & Decker model D1600 iron error message
If the unit isn't heating anymore, it needs to be replaced. Unfortunately, the unit can't be repaired. The unit comes with a one year warranty from the date of purchase. Please call the number above so that we can determine your warranty eligibility and help you any way we can.
Apr 27, 2009 | Black & Decker ICR200 Iron with Auto...
How I can fix The Black&Decker digital advantage that does not heat
The iron will probably have to be taken apart.
If you are handy, you can do this when unplugged.
Check for broken connections and anything that is obvious like burned smell etc.
Feb 16, 2008 | Black & Decker AS150 Iron
Black & Decker Steam Xpress AS250 Iron with Auto Shut-off Logo
1,753 people viewed this question
Top Black & Decker Irons Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
