Question about Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine
I have a new sewing maching and when I back stitch it looks like the top stitch is way to lose and it only happens when I back (reverse) stitch
  • 96 Answers
Double check the upper tension
Posted on Dec 13, 2009
Singer 4411 sews fine forward and reverse in straight stitch, in zigzag top thread looks fine on top, but all loopy underneath and will only reverse stitch 1 or 2 zigs or zags
check that the bobbin underneath has the same thread as the upper bobbin and that you push all the way on the lever when sewing back and also, go full speed as this happened to me and that was my mistake. Hope this will help you :)
Aug 11, 2014 | Singer 4411 Sewing Machine
Sewing machine not working in reverse
try a new needle
try a different thread top and bobbin
try adjusting the top thread tension one number or letter at a time
higher sewing on a scrap piece of paper till the stitches look
normal
make sure the top thread does not come off the thread take up lever
Jan 11, 2013 | Sewing Machines
I just got this, trying it for the first time and its sewing in reverse even though I'm not pressing the lever. I'm a novice and I'm sure I'm just doing something wrong but I rethreaded top and bottom...
Try putting your stitch length lever to its longest stitch, such as 9 or 10. I am wondering if you have it on the buttonhole stitch, by accident. If, this does not work, I would take it back to where you bought it.
Mar 05, 2011 | Brother LX3125 Sewing Machine
Started sewing backwards now not moving material at all
Sounds like the machine's age is causing the lubrication to get sticky.
Try changing the pattern by moving the pattern selector around.
Take out the bobbin and remove the thread and presser foot, raise the presser lever, set the pattern to zig zag, set the stitch length to maximum and run the machine at full speed. While it's running, repeatedly press the reverse lever all the way down. Run it for at least a few minutes.
Nov 14, 2009 | New Home MX-3123 Computerized Sewing...
My Sears Kenmore 1751 siz-zag sewing maching will only sew in reverse. A few minute ago it was sewing fine in both directions. The button I push to make it sew in reverse doesn't feel like it is...
these older cam machines have grease in then that can jam up the cams if you can get the covers off soak the machine with wd-40 and play with the reverse and stitch length if it breaks free try and soak up as much of the wd-40 as you can and then put sewing machine oil in the machine
Jun 21, 2009 | Sewing Machines
Singer sewing machine beeps and wont repond to commands.
Sounds like you may have a blockage somewhere in the bobbin area that needs cleaning as this is normally what happens when it gets jammed. Reverse sewing can sometimes cause jams. Remove bobbin area and reassemble.
Mar 17, 2009 | Singer 7462 Mechanical Sewing Machine
Sewing maching making randon loops bottom stitching
Sounds like you are getting some skipped stitches. Have you tried changing your needle? You may want to make sure you are using a ball point, those help alot with skipped stitches.
Dec 15, 2008 | Kenmore 15516 Mechanical Sewing Machine
Hi I have a cee100 singer embroidery/sewing mach. in utility mode on straight stitching i have the problem of uncontinuous stitching. Sometimes when the foot lever is pressed it will sew a few inches but...
i spoke with support and they tell me that this is a threading issue. pull the thread back and forth, like flossing, under the plastic plate on top so the thread clicks into place. then procede with threading.
Oct 31, 2008 | Singer CE-100 Futura Computerized Sewing...
Long stitch!!
Hi teza...I assume that you have decreased your stitch length selector resulting in no change, indicating that the internal stitch length mechanism is either insufficiently lubricated, or truly broken If not broken, you can work the mechanism free by removing your needle, selecting the maximum stitch length and any non-overlock stich pattern, ie. straight or zigzag, fully depress your foot pedal so it runs at maximum speed, and methodically press and release the Reverse button/lever. After a minute of this, hand crank your machine while observing the feed dogs, and changing your stitch length. If your stich length is set to 0, your should observe your feed dogs moving vertically up and down with no back/forward motion, however, increasing as you lengthen your stitch length. Repeat the previous high speed work out until you notice full strokes of your feed dog...good luck my friend
Jun 10, 2007 | Bernina Activa 140
Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine Logo
74 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
