Question about Vizio P2 42 in. HD-Ready Plasma Television
I had a few hd channels when i push the hd button but now i cant get any do u think my tuner is bad
    Sergeant:
    Champion:
  • 245 Answers
U MAY LIVE IN A AREA WHERE HD IS TRANSMITTING BUT THE SIGNAL IS NOT STRONG ENOUGH TO GET TRUE ALL THE TIME......ARE U USING A INDOOR OR OUTDOOR AERIAL? ALL THIS CAN HAVE A IMPACT RECEIVING HD
BEST WOULD BE U USE A OUTDOOR AERIAL
Posted on Nov 20, 2009
Using a digital antenna to channel scan for broadcasted channels
It is no different that channel scanning for cable or analog over-the-air channels. You simply ensure that you have selected the digital tuner of the set prior to scanning. Some older flat panel sets do not have integrated digital tuners. A digital antenna alone will not allow these sets to receive digital broadcast channels. A converter box is needed to convert the digital broadcast signals to analog for the tuner in the set. Also, sets that do not have digital tuners may not support the resolution rate of digital TV broadcasts. Most digital HD broadcasts are 720p and a few are 1080p.
Jul 28, 2016 | Televison & Video
Hitachi 42" ultravision...power light on, hear
Tries pushes the power switch on the remote few times,each times push wait like a 1 mins or 2 mins for the tv Tuner signal board to take it effect.This process should get ur tv picture back,because the tv Tuner signal board it is old and having problems,evenually require replacement of a refurbish tv Tuner signal board.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
May 23, 2011 | Hitachi UltraVision 42HDS52 42 in....
My samsung ps42c91hdx/xsa tv wont tune in the high def channel 10. the tv can't find it. My sons tvs are picking it up so it cant be the signal.
go to MENU, SETUP,
There you can reset to factory settings. After you set the clock and date, it will ask to scan for all active channels and it will block out the channels it does not find a signal for. Let it complete this task (20 minutes). It asks you for the type of signal but just leave the STD setting for both options before starting the channel finding routine.
When complete, go to channel 10 to see what show is on (low def version). then click down to channel 2 and then push the channel down button several times again to try and find the HD version of that show. (HD channels are high-number channels that are easiest to get to by scrolling below channel 2. Most will have a hyphan in the channel name (e.g. 93-2; 94-1, 94-2, ...).
If your TV goes directly to a 2-digit channel, they you do not have an HD tuner in your set. I doubt that is true so I think you will find what you need.
Let me know if it doesn't work.
May 06, 2011 | Samsung PS42C91HDX 42 in. Plasma TV
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
Can't get HD channels after voncersion
The "HDTV ready" TV only has analog tuner included. That unit can be used with external HDTV tuner to receive digital television.
Jun 15, 2009 | Mintek DTV-263 26 in. LCD Television
Cant program digital channels.
Nothing. Digital Tuners Broke. I wouldn't be suprised if your TV freezes up momentarily (or for a long time) when you switch over to the Digital Channels.
This TV has 1 tuner for analog channels and 1 tuner for digital channels. You can probably find the Digital Tuner on Ebay and replace it.
Mar 04, 2009 | JVC HD-61G787 61" Television
NO DTV CHANNELS
There may be an input button on the remote, or on the TV, that allows you to switch from the standard ATSC tuner to the DTV tuner.
Let me know if you can't find it and I will dig for an owner manual. But the above should allow you to switch tuners and input sources.
Feb 16, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Olevia 537 - wont select HD channels
I assume the control panel on the tv still works correctly? If so i would think you have a remote problem. If thats the case let me know I will send you a link to instructions to repair your remote.
lone99star
Jan 09, 2009 | Televison & Video
Cable setuo for model 27r410t
Get an antenna hooked up, even rabbit ears should pull in a few analog channels. Set top boxes will only output Ch 3 (switcheable to ch 4 on the back if needed) and cable may be dead or only give you scrambled CATV channels. You need to set your tuner to "antenna", not CATV, IRC,HRC, or ATSC (if you have a digital tuner) and do the setup again. You could have a bad tuner at worst, and all is not lost, just hook up a VCR via RCA cables and use the VCR tuner to change channels. Keep TV on Ch3.
Feb 12, 2008 | Televison & Video
Thick multicoloured stripes accross the screen
Some condesator gone bad.. remote control IR eye needs 5V voltage but now it's not there so i think you need to replace bad condesator.
May 30, 2007 | ViewSonic N3000W 30 in. HD-Ready LCD...
Vizio P2 42 in. HD-Ready Plasma Television Logo
35 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
