Back to Basics Blender Solution 5500 Blender Logo
Posted on Nov 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replacement jar for a GE Insta Blend 14
I would like to find a replacement jar for a GE Insta Blend 14 Model BL21. The rest of the unit is still in good condition. It is quite old - 70s or 80s model.
Anonymous
Level 3:
  • Master 576 Answers
  • Posted on Nov 20, 2009
Anonymous
Master
Level 3:
Answers
576
Questions
0
Helped
203989
Points
1663
Many blenders will work with a standard canning jar (pint or quart) I'm not sure if that will work for you, but it's a definite cheap fix.
Hi, Oh no!!!!!!, my blade has seized up and left little black bits of the gasket right under the blade in the jar. Can I get this gasket? We bought this absolute AWESOME Blender at the Home Show here in...
The bearing and seal are not replaceable. The bearing is sonically welded into thte base of the jar. The K-Tec is made by Blend-Tec, and any of the Blend-Tec jars will work as a direct replacement.
Hello, I didn't see model #BBL600XL which is what
The jar has to be on for it to blend.
If you replace the jar first check the printing on your old jar. If your jar has blue print you will need a new jar and blade, Breville redesigned the jar and now the old blades don't work with the new jars. You tell the difference between the jars by the print color, old is blue, new is white.
BBL600XL/06A jar part number
BBL600XL/14A blade part number
Contact Breville at 1-866-273-8455 for service center locations.
1helpful
2answers
Blendtec replacement jar
You can also go to http://veggiesensations.com to buy blendtec total blender parts. Hope this helps!
2helpful
3answers
There is a leak in the caraffe(or jar). It is at
Common issue with all of these carafe's. Once the jar starts to leak the bearings are shot and it is time to replace the jar. The bearings are non-replacable. Bad design in my opinion. I was able to get my last jar (I have been through 3 before the 5 year warranty went out) to last by hand washing and not putting it in the dishwasher, but after 4 years of use on this jar it failed too.
4helpful
2answers
I need a replacement jar for a GE Blender model 169053
By now I'm sure you've given up, but do you still need the jar? I have one that is now useless to me since my son tried to run the blender when the jar and base were not seated correctly and the rotors on both were worn off.
1helpful
GE Blender Jar loose rotator
Remove the bottom clean the unit fully. Add the bottom blad assebly and this will fix your problem. The "sooty" is plastic shavings. Take note that the fitting were the "jar" connects to the motor that this is not wearing away. The unit i have broke and i am unable to find a replacement blade assembly.
Apr 04, 2009 • Blenders
Cracked blade part
Bought a new one from JC Penneys!
Top Back to Basics Blenders Experts
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
Are you a Back to Basics Blender Expert? Answer questions, earn points and help others
