Question about Mitsubishi WS-55809 55" Rear Projection Television
The colors do not converge until the TV has been on for awhile
    President:
  • Mitsubishi Master
  • 1,779 Answers
Sounds like your Convergence IC's need to be re soldered. Bad solder joints.
Posted on Nov 20, 2009
In the past, turning off and on would result in "blinking power light" situation. I would unplug for 10 minutes, and all would be well. But suddenlt, powering on just show a mess of RGB colors...
The tv board that call the HYPER board nown as the tv convergence board was dying and have problems,but the tv was still used able that why u able to unplug it awhile,replug it back and get it up and running.Now the tv HYPER board known as tv convergence board are totally dead,colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures for a minute when the HYPER board was still functional for a little bit.Now the tv HYPER board getting no voltages at all,that why ur tv getting only a power LED indication light flashing only.The tv must get it tv HYPER board fixed also known as a tv convergence board.The tv HYPER boad must have it parts replace like 2 STK convergence ICS and some or all of it resistors too.To get the tv up and running again.The tvs shops will cost u like $300-350 for parts and labors.
Aug 10, 2011 | Toshiba 55H70 55" Rear Projection...
My Sony KP-46WT500 has a yellow arc of color on the upper left side that never goes away even with plug in devices like Wii. It started about 6 months ago and has gotten worse over time. What can I do?...
Very common problems,through out the DLP tv life cycles could happen again again until end of the tv life itself.The tv have a problems known as a convergence picture problems,it is dead.Tv have any colors lines like R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?Yes?Than the tv convergence board it is dead.The tv convergence board must have it components parts replaced like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The Shop will cost u like $300-350 for parts and labors.
Aug 03, 2011 | Sony KP-46WT500 46" Rear Projection...
I bought this model from a friend and he mentioned that when moving the tv around it might get bumped a little bit and this could "throw the colors off". HE said i could pop the outter casing off...
Tv now have colors R,G,B lines mis alignments,have colors shadows or 3D pictures look alike?Yes,this tv have a problems known as a convergence problems,sorry but ur friend screw u over.This tv the convergence board is dead.The tv convergence board require replacing 2 STK convergence ICS and some or all of it resistors too.Fix the convergence board to solved the tv convergence picture problems.U have all the tools and can u do basic soldering?Yes,tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.Or the shop,will cost u like $300-350 for parts and labors.
Jan 22, 2011 | Philips Magnavox 51MP392H Rear Projection...
The picture on our Sony TV Model KP-43HT20 recently became distorted, concaving at top and bottom. If I use reset the Flash Focus, the picture will return to full screen side for awhile but the colors do...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergene board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 15, 2011 | Sony KP-43HT20 43" Rear Projection...
My Sony kp57hw40 looks like it is in 3d after it has been on for awhile it goes back to normal
It starting to died.It will happen for good.The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have pictures colors shadows or 3D picture look like.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The Shop,will cost u $300-350 for parts and labors.
Oct 20, 2010 | Sony KP-57HW40 57" Rear Projection...
Sony TV losing focus
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 17, 2009 | Sony KP-65WV600 65" Rear Projection...
RCA HD52W66 convergence problem
you will need to replace FL231, DL231 and CL230 all located on the deflection board . You can get replacements at the following link with free instructions on how to do the repair. the parts are all listed under the RCA parts category. Heres the link http://servicemanuals.vstore.ca/
Jan 06, 2009 | RCA HD52W66 Projection Television
Colors split on my ony rear projection tv
If by a color split, it looks like a 3-D picture, the problem is in the convergence circuit. Since it recovers on its own, it suggests to me that there is a poor solder connection at the convergence ICs. If you can solder, this should be a simple repair. Locate the convergence ICs (large black ICs attached to a heat sink that should be marked STKxxx). Resolder the pins on both ICs. If that does not resolve the problem, let me know.
Dan
Dec 21, 2008 | Televison & Video
Picture Problems: Snow, color, lines
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 23, 2008 | Sony KP-53XBR200 53" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
67 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
