Question about Toshiba 22LV610 LCD TV
New toshiba lcd has sound, is getting all cable
New (got it home about 2 hours ago) toshiba lcd has sound, is getting all cable channels as I can change them with remote-- but has no picture. Just a bright gray screen. Auto setup never came on as it was supposed to. DVD sound works also, but still no picture.
  • cshaydel Nov 20, 2009
    thanks Lee. The DVD player is built-in. There's NEVER been even a flicker of a picture since I turned it on. I'm just about resigned to packing it up and hauling it back tomorrow. Strange because I can hear all the cable channels...so the box is connected.
    Checked cable connection...get the same bright screen whether cable connected or not and whether plugged into a different outlet. Same cable works fine on old TV that we're replacing.
  • 4,472 Answers
What kind of video connections are you using to hook up the cable and the dvd player? Also does the menu of the tv come up normally? Once I have more information I can assist you further. Worst case scenario you will end up needing to return it for a replacement where you bought it from but lets do a little troubleshooting first.
Thank you,
Lee
Posted on Nov 20, 2009
  • Lee A.
    Lee A. Nov 20, 2009
    If it is built in dvd then it should definitely have some sort of picture. Even a dvd loading screen at least.It is definitely a defective tv. Also just FYI I don't recommend tv's with built in dvd players. In the long run it is just something else that can fail. You can get a separate dvd player for quite cheap and then if it fails you can always just replace that. If you have any other questions please let me know.
    Good luck tomorrow and thanks again,
    Lee
The sound goes out and you have to change the channel to get the sound back on
That problem is not on the TV but on the cable connections or signal if you are using analog/aerial antenna..
If you are using digital cable try to contact your cable provider to assist you...
Dec 27, 2011 | LG 32LG30 32 in. LCD HDTV
We have Toshiba Regza 52XV645U. We have dish network hd channels and ever since hd channels were installed after tv plays for few hours the speakers get a funny sounds like channel sound is scrambling. It...
This sounds like what may be causing it is the cable going from the tv to the receiver box. If it is only happening on the sat channels, you know that it's not the tv. I would replace the cable, if that does not work, then it may be that the receiver needs to be replaced.
Becki Barned
DISH Network Customer Service
Dec 16, 2010 | Toshiba Regza 52XV645U LCD TV
ID 4Z9AB0MC activated 2 days ago. Cannot select channels. Thumbwheel only displays 3 channels, ch.0,1,247. When pre/dir is pressed and a channel is selected, the selected channel number flashes...
Use plug-in power supply and leave on channel 1. Call XM (1-800-XM-RADIO) and ask them to "refresh" your radio. WAIT 1/2 hour, then check your channels. Make sure you have a decent signal too (can hear Channel 1 okay) before you call XM for the 'refresh signal' for your new radio.
Dec 21, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
Sound goes out on random cable channels..only on this tv
It might not be your TV it might be you Cable Provider. Get them to look at your cables in your home
Aug 25, 2009 | Sanyo DP19648 19 in. LCD TV
My 32" Toshiba LCD HDTV keeps freezing on the same channel and when I try to change the channel or input selection, it doesn't respond(to the remote or directly on the TV.) The only thing that works is...
These problems are normally caused by the TV station.
1. Call the TV station responsible and ask for the network engineer.
2. Tell him the Day, Time, Channel, Program, basically every little detail about the problem.
3. The station will normally check it and fix it.
Also, contact Toshiba and tell them. Really this is part of the DTV Transition thing. Many stations are reconfiguring and settin up equipment. They sometimes make mistakes. Don't worry much about it unless it continues for more than a week. If you like the station, I would call right away.
May 25, 2009 | Televison & Video
No sound on my 32'' Insignia LCD HDTV
Try to unplug the tv for a few seconds and then plug it back in again.
Jan 28, 2009 | Insignia LCDTV26 26 in. Television
Problems with sound that buzz/vibration sound My brand new Toshiba 40 LCD has similar occasional buzz/ vibration coming from inside TV
Same problem with my new Toshiba 55" LCD.
Also, after being on for awhile, the sound suddenly gets distorted in a fuzzy, echoie kind of way. Switching to a non-digital channel and switching back seems to make that correct itself. I may try a new HDMI cable to see if the problem goes away. Any other ideas?
Jan 14, 2009 | Televison & Video
No sound when playing dvd
HDMI may not output sound. Go into the setup screen of the DVD player and go into audio setup. Make sure you have it set for PCM or equivalent DIGITAL setting. If you set that and you still get no surround sound, you will have to use and optical cable between the receiver and the DVD.
Sep 06, 2008 | Audio Players & Recorders
Toshiba 22LV610 LCD TV Logo
131 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
