Question about Sharp AR-M280N Copier
Sharp AR-M280N Display shows "Finisher out of service" and gives error code F1-87
  • xavierlopez Nov 12, 2008
    got this used sharp arm350n and I have the same code problem MY question is can this code be overide I just need the machine to make copies
  • Anonymous Mar 22, 2014
    display code call for service F109
    Sniper:
  • 54 Answers
Does not need a fuser. Hit P * C * then hit 14 then Start ( Like making a copy) hit 1 and start then CA button. Machine will reboot. If code comes back, check the stapler to make sure it is in the proper home postion.
Don't forget to rate your answers please!
Posted on Mar 16, 2008
    Problem Solver:
  • 8 Answers
Does this copier have a stapler on the finishrer?, if so there is a problem with the stapler, the finisher may need to be removed, but first check the lower exit tray and make sure that it is seated properly
Posted on Feb 15, 2008
    Genius:
  • 1,003 Answers
NEEDS FUSER ASSY
Posted on Jan 13, 2008
Service manual manuals
http://www.smpcshop.com/Sharp-AR-M280N-Sharp-AR-M280U-Sharp-AR-M350-Sharp-AR-M450-U-N-Service-Manual.html
Nov 23, 2013 | Sharp AR-M450N Black & White Copier
Sharp AR-M280N shows L04-02 service code
check home position sensor, main board, scanner motor, cable harness. ccd unit scanner sensor all connectors the optics reset eror
Feb 19, 2013 | Sharp AL-1457 Black and White Copier
Sharp AR-M45ON coming up with F1-15 error code "Finisher Trouble" Can you tell me what this means and if there is an easy fix for it, please? Also, what is a finisher and where do I find it if...
Your machine is installed with finisher model is AR-FN7, it's lift up motor is working ub normally, the motor may be defective or over current to the motor or you have to change the console finisher control PWB, you can try to enter to the service mode by pressing #*c* button in the respective order then you will get another display to enter the main code then press 3, then press start, then again press 3 and start by this you can check the lift up motor working . rate this and give feed back accordingily I can give you the instruction.
May 05, 2011 | Sharp AR-M450N Copier
Sharp AR-405 error code F1-15
Hello sir; this error code means " elevator motor "problem inside the finisher,check it out is something stuck the motor. or you have to replace one.
Feb 16, 2009 | Sharp AR-M205 Copier
Sharp AR-M280N -scanner
the ip address is not configured correctly in the machine. You may be able to print but the scanning server is incorrect.
Dec 09, 2008 | Sharp AR-M280N Copier
Sharp AR-5127, the error code U2-40
U2-40 is a board error, F1-15 is finisher lift motor error.
To reset: #, interrupt, clear, interrupt. (screen should say service mode), enter 16, print, are you sure? , yes.
For the finisher error, follow above procudure, entering 14 instead of 16. if error returns, disconnect the finisher
Nov 26, 2008 | Office Equipment & Supplies
SHARP AR-M280N
Polygon mirror motor isn't up to speed.  It should be looked at by a technician for further troubleshooting in case it is a board, motor, cable, or power supply issue
Nov 07, 2008 | Sharp AR-M280N Copier
Sharp AR-M280N Copier Logo
243 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
