Question about Canon LaserBase MF5750 All-In-One Printer
Canon mf5750 rec paper jam error message no jam found cannot reset
  • 12 more comments
  • kr_officesup Nov 20, 2009
    check switches did not fix
    there is no paper whatsoever in the machine how do you reset the alarm
    left machine unpluged 15 min still did not clear what now
    motor does not try to drive nothing happens because it will not reset exactly were are the micro swicthes
    yes it happened after a paper jam
    auto feed out of paper tray
    found 1/2 x 1 piece of paper now machine says adjusting waiting to scan what now
    unpluged let set 2 min still says adjusting is that normal
    still waiting will see what happens in a 5 min
    machine just reset a copied THANKS FOR YOUR HELP FIRST TIME I USED U THIS IS A ONE TIME CHARGE ON MY CREDIT CORRECT
    LOOKS LIKE CUSTOMER CUT UP SOME KIND OF MAIL INTO SMALL PIECES AND A PIECE OF THAT FEED INTO MACHINE BY ACCIDENT IT WAS A GLOSSY BLACK PAPER
    DO I DO THAT JUST BY HITTING ACCEPT
    THANKS AGAIN & GOODNIGHT
    THE PROBLEM WAS SOLVED AFTER TALKING TO THE TECH THAT HELPED ME VERY VERY HELPFUL FOR CHECKING DIFFERENT AREAS OF THE MACHINE THANK YOU VERRY MUCH
  • 6,918 Answers
Check the micro switches in the bottom of the paper try,down in the machine.
Posted on Nov 20, 2009
  • 14 more comments
  • Ronny Bennett Sr.
    Ronny Bennett Sr. Nov 20, 2009
    There may be something,pulp,or paper,jamming the gears for the motoe,you may have to go deeper to find it.
  • Ronny Bennett Sr.
    Unplugging,and plugging the unit.Most of the time off and on.
  • Ronny Bennett Sr.
    Does the motor try to pull,and then quits?or nothing?If it is nothing,then one of the micro switches may be bad,check the continuity of the micro switches.
  • Ronny Bennett Sr.
    They are in the paper feed,under the paper lay,it is a very small switch that connects a circuit,that is why I wanted to check them for paper lodged under the paper lay.Paper lays on it and is pulled threw cause the machine senses the paper in the tray,it ,the problem will be in the feed somewhere,if everything is checking out o k,then the circuit board is not working,did this first happen after a actual paper jam?
  • Ronny Bennett Sr.
    If so,then there is a switch that is not working that senses the paper jam,that is why it will not reset is either that,or the circuit board is malfunctioned.Did this happen on manual feed ,or auto,out of the paper tray?
  • Ronny Bennett Sr.
    All the guides,and all the pieces you removed,are they snapped back in correctly,if you are not sure go over it again.You are sure there is no paper up in the middle of the unit>right?just asking cause sometimes it will push the paper else where.
  • Ronny Bennett Sr.
    The machine will let you know when ready.
  • Ronny Bennett Sr.
    Give it a minute,and then try copy.
  • Ronny Bennett Sr.
    It is calibrating.
  • Ronny Bennett Sr.
    it may take a minute or two.
  • Ronny Bennett Sr.
    was this paper you removed torn?or cut this narrow?
  • Ronny Bennett Sr.
    tes,as soon as you o k it and tell them thumbs up!thank you
  • Ronny Bennett Sr.
    yes,I can`t seem to spell tonight,
  • Ronny Bennett Sr.
    oh,o k,thank you,and just let them know i was helpful.
  • Ronny Bennett Sr.
    yes you do
  • Ronny Bennett Sr.
    good night
How to reset canon pixma error code e17
canon gives great support for everything. Pixma error codes can be found ere: PIXMA Printer Error Codes and Error Messages
and even on Fixya this was answered here: When go to print message pops that there is paper jam when in fact there...
Feb 20, 2015 | Canon Office Equipment & Supplies
Printer canon mf 5750 thankyou verymuch
please chack your paper feed sensor i guss it was broken
Aug 04, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Supply rec. paper when i insert paper then rec. paper jam
Your copier feed roller clought is not active wash it and then solve
Jun 11, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Paper jam message, but no paper visible
Are there any traces of paper in the printer? Have you tried by restarting printer?
Mar 18, 2009 | Canon PC-D340 All-In-One Laser Printer
Canon MF5750 paper jam
some papers struk in the fusing unit else check the all sensors,good luck...............by SELVA-SINGA.
Nov 24, 2008 | Office Equipment & Supplies
Not working
Pull out the tray with paper.
You should find a moving plastic "tongue" near the middle of width in the area where your paper tray should go. It's a contact based flag for the device to consider how much paper is in the tray. Check if it's not broken or stuck in odd position. Move it back and forth several times, with no force, it goes very easily. When you lift the flag up, see message and blinking led stop appearing. Try to pull paper tray back in, add paper if error appears again. Enjoy!
Sep 15, 2008 | Canon imageCLASS MF5750 All-In-One Laser...
Jarry cannon
open printer cover, pull out toner cartridge, re-install cartridge, close door, it should re-boot the machine.
Mar 14, 2008 | Canon LaserBase MF5750 All-In-One Printer
Canon LaserBase MF5750 All-In-One Printer Logo
588 people viewed this question
old marine
old marine
