Question about Philips Televison & Video
Cloudy picture on rear projection tv
My philips magnavox rear projection tv was sitting in storage for 3 months now the screen is cloudy and the picture is not clear
    Guru:
  • 1,738 Answers
Your picture guns and mirror is dusty. You can try cleaning yourself if you know what your doing, but I would let a qualify tech to do it.
Posted on Nov 20, 2009
My tv has a red tint to it constantly. Can you tell me why?
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 18, 2011 | Philips Magnavox 51MP392H Rear Projection...
I have a Philips Magnavox 9P6034C 60 in. Rear Projection Television the whit bulb is gone out where do i get another one
  • Screen looks 3D
69189a5.pngSOLUTION
Mar 27, 2011 | Philips Magnavox 9P6034C 60" Rear...
Philips magnavox 55" rear projection tv problems
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 11, 2010 | Philips Magnavox 9P6034C 60" Rear...
Regular picture size shrinks and color fades
This is a common problem on certain models of Philips Magnavox TV sets. The most common symptom is the screen will shrink and expand over and over. After the TV heats up for a while the video will work like normal. After a few weeks or months your TV will eventually stop working and not have video. You can get complete parts and instructions from www.TvRepairKits.com
Jan 01, 2010 | Philips Magnavox 9P6034C 60" Rear...
My rear projection tv is working but the picture in very light and hard to see. Almost like a glare cloud is sitting on the screen. You have to turn off the lights to see whats on the screen.
This is a common problem for Philips/magnavox projection TV's. The coolant fluid between the picture tubes and lenses has broken down and is not clear. It will have to be replaced in order to restore the picture to normal. This is a messy job and the tube and lens assemblies have to be removed. Have a repair shop check it out for you. Thanks for using fixya.
Dec 23, 2009 | Philips 60P8342 60" Rear Projection...
Red and fuzzy picture can you help on my 50 inch phillips magnavox projection TV
This is a very common failure on Projection TV sets.
Screen looks 3D
The other common problem is cloudy lens fluid. After many years the coolant in the blue and green lens will become cloudy and cause the screen to look dull, red/orange, bright white, etc. You may even see halos around video.
You can see some example photos and find a solution here on Fixya.
Nov 25, 2009 | Philips Magnavox 51MP392H Rear Projection...
Picture shrinks to only show top half
May 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
3-d look on words and unclear picture
Go to convergence in the menu. If you colors will not move you need convergence amps. Have professional install
Apr 08, 2009 | Philips Magnavox 51MP392H Rear Projection...
52" philips magnavox
theres focus controls inside the rear of the set on a small control panel with 6 dials 3 control the screens, and the other 3 control the focus for all three tubes.
Jun 15, 2008 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
395 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
