Sony KP-41T65 41 in. Rear Projection Television
Problem for Sony KP-41T65 41 in. Rear Projection Television
I am having a shadow/double image problem only on the left side of the screen
By Ken99287 on Jan 11, 2008
the double image is most noticeable when i have text up on the screen(i'm using the internet function with my Wii). I have tried using the menu options to center the red and blue cross thing. The picture is great everywhere else except the left hand side(as great as a rear projection can be). Is there a "convergence" part i can buy to replace the one in the tv?? i looked on www.partstore.com and i don't know the name of the part! please help! thanks,
Ken
Comments:
Jan 11, 2008
- Ok, do you have any idea how to adjust the convergence other than the red and blue cross?? i really don't see any problem with the picture watching tv, but when there is text, it almost makes me dizzy to watch!
Jan 11, 2008
- ok, so i'm in the menu, and there's like.... 500 different settings, i messed around with some and i think i'm on the right track - i just need to know what the abbreviations mean and what order to change them and to what settings... is there anywhere i can find that info??? i'm soooo close!! thanks sooo much though - you've definately got me on the right track!
Jan 11, 2008
- i actually shut the tv off and i guess my settings weren't saved - which is good, i had it all out of wack. now it's just the same as before where the top left side has a yellowish greenish shadow. i'm sure one of those settings will let me warp that color back in sync with the rest of the screen! where can i find a code chart thing? THANKS!!
Jan 12, 2008
- wow, that is extremely useful information! now i just need to understand it, haha. maybe i'll get lucky. are there any of those adjustments that seem like a good place to start?? thanks a million!
Jan 12, 2008
- oh yeah, one last thing - when i was messing with it yesterday, the settings all went back to the way they were when i shut the tv off. how do i get my changes to save??
Same Problem
Aug 19, 2008
-   double lines red and green-   Guest
Best Solution
posted on Jan 11, 2008
Very Helpful)
Slinteriors
Rank: Guru  Sony Televisions & Videos  Expert
Rating: 89%, 3802 votes
Yes its called the Convergence ICs there are two of them they are mounted on a huge heat sink with the part number stamped on them they will have a STK number such as STK392-110. they have 16 pins on them there are two cost around 10 dollars each, you will also need some Heat sink Compound. Just look for the largest heat sink in your tv and thats where they will be. However if you can move both red and blue colors up,down right and left its probaly not your ICs. Do the colors move in all directions? If so you probaly just need to do a multipoint convergence adjustment.via of the service menu. Hope this helps. let me know if you need anything further.
Comments:
Jan 11, 2008
- You can enter the service mode by turning the set off. Then using the remote press Display, 5, Vol UP, then power. Write down anything that you change so you can change it back if you need too. Use #1 and #4 to select items to adjust and #3 and #4 to adjust.You will be looking for coarse convergence, fine convergence or Multipoint convergence your set should have at least two in the service menu. Hope this helps. Let me know if I can be of further assistance.
Jan 11, 2008
- Heres what I found you will need the convergence items. Write down anything you change. Good luck
Go Home LIST OF SETTINGS Go Top
ITEM TYPICAL RANGE DESCRIPTION ------------------------------------------------------------- AFC 0 0-3 AFC Loop Gain HFRE 42 0-127 Horizontal Frequency VFRE 11 0-31 Vertical Frequency VPOS 16 0-31 Vertical Picture Position VSIZ 18 0-63 Vertical Picture Size VLIN 6 0-15 Vertical Picture Linearity VSCO 10 0-15 Vertical Correction HPOS 6 0-15 Horizontal Picture Position HSIZ 11 0-31 Horizontal Picture Size PAMP 18 0-31 Pincushion Amp. CPIN 4 0-7 Corner Pincushion PPHA 7 0-15 Pincushion Phase UPIN 10 0-31 Pincushion upper ends, vertical lines LPIN 10 0-31 Pincushion lower ends, vertical lines PPHA 7 0-15 Keystone correction vertical lines HKEY 6 0-15 Keystone distortion, horizontal lines HTRP 8 0-15 Keystone correction, horizontal lines VCOM 2 0-7 Vertical Compensation VUSN 0 0,1 Shrinks Vertical Height to 16x9 Area VZOM 0 0,1 Places Bars on Picture to give 16x9 Area EHT 15 Adjust Height of VZOM ASP 47 Vertical Picture Size - Aspect SCRL 31 Vertical Picture Position HBLK 1 0,1 Horizontal Blanking (on/off) LBLK 15 Left Blanking RBLK 3 Right Blanking GAMP 18 0-31 Green Amp. BAMP 14 0-31 Blue Amp. GDRV 18 0-31 Green Driver BDRV 14 0-31 Blue Driver RCUT 15 Red Cutoff - (lower level) GCUT 4 0-15 Green Cutoff - (lower level) BCUT 1 0-15 Blue Cutoff - (lower level) RDRV 21 Red Amp. - (upper level) GDRV 18 Green Amp. - (upper level) BDRV 14 Blue Amp. - (upper level) DCOL 1 0,1 Color Temperature COFF 0 0,1 Color On/Off - B/W Picture Y-DC 0 0-15 BLACK background level retention R-YR 15 0-15 Sets the amount of RED R-YB 15 0-15 Sets the amount of RED G-YG 11 0-15 Sets the amount of GREEN G-YB 9 0-15 Sets the amount of GREEN AXIS 0 0-15 Cleans up the red & oranginess in yellow DPIX 0 0-3 Dynamic Picture CROM 28 0-63 Chroma Trap SPIX 30 0-63 Sub-Picture Contrast (Picture) SCON 30 0-63 Sub-Picture Contrast (Picture) SHUE 23 0-63 Sub-Picture Hue SCOL 26 0-63 Sub-Picture Color SBRT 22 0-63 Sub-Picture Brightness (Black Level) RGBP 10 0-63 RGB Picture SHAP 6 0-15 Sub-Picture Sharpness SHPF 3 0-15 This helps with the S-Video sharpness NRLV 0 0-3 Find the value that gives the best resolution VSMO 1 0,1 Vertical Pull In Range (1 allows PAL in B&W) REF 2 0-3 Reference Line ROFF 1 0,1 Red Gun ON(1)/OFF(0) GOFF 1 0,1 Green Gun ON(1)/OFF(0) BOFF 1 0,1 Blue Gun ON(1)/OFF(0) RON 1* 0,1 Red Gun ON(1)/OFF(0) GON 1* 0,1 Green Gun ON(1)/OFF(0) BON 1* 0,1 Blue Gun ON(1)/OFF(0) AXPL 0 0,1 Cleans up Reds/Yellows ABLM 0 0,1 Automatic Background or Brightness Limiter NOTC 1 0,1 Notch Filter ON(1)/OFF(0) VMLV 0 0,1 Scanning Velocity Modulation ON(1)/OFF(0) VAPI 0 0,1 Sets vert resolution for 3-d comb filter VAPG 0 0,1 Sets vert resolution for 3-d comb filter DRGB 0 0,1 On-Screen Display (OSD) Intensity DISP 35 0-63 On-Screen Display (OSD) Menu Placement (L/R) VTMS 0 0-3 On Screen Display (OSD) - On/Off DPDV 1 0-3 Lumipon MPIC 8 0-63 Lumipon (depth) SVOL 0 0-15 Sub-Volume (0=Max,15=Min.) SBAL 7 0-15 Sub-Balance (0=Left,15=Right) BASS 8 0-15 Sub-Bass (0=Min., 15=Max.) TRE 7 0-15 Sub-Treble (0=Mix., 15=Max.) MPX - 0-15 Audio ATT FILO - 0-15 Audio I1 DEEM - 0-15 Audio I2 STEV - 0-15 Audio OSC1 SAPV - 0-15 Audio OSC2 PILO - 0-15 Audio PILOT SEP - 0-15 Audio WIDE BAND VD - 0-15 Audio SPECTRAL LVOL - 0-15 Audio VOLUME-L RVOL - 0-15 Audio VOLUME-R PADJ 63 0-255 Hor/Vert Picture Adjustment (total picture) UYBO 32 0-63 Upper Y Bow (B/R Top) LYBO 27 0-63 Lower Y Bow (B/R Bottom) HAMP 34 0-63 Horizontal Amp. (B/R OuterLines) HTIL 32 0-63 Horizontal Tilt (R/R) UCBO 39 0-63 Upper C Bow (B/R Corners Only) UTIL 37 0-63 Upper Tilt (Top Corners) LCBO 41 0-63 Lower C Bow (B/R Corners Only) LTIL 40 0-63 Lower Tilt (Bottom Corners) DCSH 36 0-63 DC Shift (Static Convergence All Vertical) VBOW 30 0-63 Bow distortion correction vertical lines VANG 30 0-63 Skew correction, vertical lines RTCO - 0-63 Raster Rotation PHPO 79 0-127 Picture In Picture (PIP) Horizontal Position PHUE 0 0-31 Picture In Picture (PIP) Hue MSHU - 0-31 Main PIP hue MSCOL - 0-31 Main PIP color SSHU - 0-31 Small PIP Hue SSCO - 0-31 Small PIP Color GV SKEW - 0-63 convergence service item GH SKEW - 0-63 convergence service item GH BOW - 0-63 convergence service item RV SKEW - 0-63 convergence service item BV SKEW - 0-63 convergence service item GH PIN - 0-63 convergence service item GH CENT - 0-63 convergence service item GV CENT - 0-63 convergence service item RH CENT - 0-63 convergence service item RV CENT - 0-63 convergence service item BH CENT - 0-63 convergence service item BV CENT - 0-63 convergence service item ID0 88 0-127 Model ID ID1 127 0-127 Model ID ID2 104 0-127 Model ID ID3 64 0-127 Model ID ID4 19 0-127 Model ID ID5 1 0-127 Model ID
    NOTE:
    1. Not all ITEMS appear on all televisions models.
    2. Provisions for convergence adjustments are not enabled on 27" or smaller Sony direct view television sets.
    3. Typical settings may not apply to your particular model and are shown only for reference purposes.
Jan 12, 2008
- I would start with the convergence items. If your red say is off i would concentrate on just the red conversion items. Just write down what the origional values were and how you changed them. If you do mess up just unplug the set and it will go back to the default settings. Just go slow and take notes.
Jan 12, 2008
- Heres how you navigate through the service menu and save changes. Once you save all default ones will be gone so remember to write down anything you change. Hope this helps.
NAVIGATE IN SERVICE MODE
    [1] = Moves to Previous Menu Item
    [4] = Moves to Next Menu Item
    [3] = Adjusts Value Up
    [6] = Adjusts Value Down
    [MTS] = Toggles Stereo/Mono Audio
SAVE NEW SETTING
    [MUTE] followed by [ENTER] = stores NEW service mode settings to NVRAM
Was this helpful?
Yes
No
Solution #2
posted on Aug 28, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
red has up and down, but no side to side
Popular Solutions for Sony KP-41T65 41 in. Rear
Questions and Unsolved Problems for Sony KP-41T65 41 in. Rear
Do you recommend Sony KP-41T65 41 in. Rear Projection Television?
Answer
Answer
I got very blurry image... on my sony kp-41s4 projection tv and want to know if i can do something... (More)
Answer
i have a sony kp41t65 television, the varister from ey33 to ey34 smokes/burnt out.. i need the value... (More)
Answer
I have a sony kp-41t65 tv, I purchased it new in 1998. Today it's acting like a computer screen at... (More)
Answer
the number of flayback kp-45t65 not look to buy another
Answer
no picture, but power button on- could this be replacement bulb
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in Newport, KY
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
