Question about Garden
Toro Dingo TX420 steering is labored and stiff.
  • 169 Answers
Dissaemble the steering and clean out the rust and corrosion that is causing the stiff steering. It would be cool to have a pool full of wd40 you could soak it in :) hope this helps. Let us know how it turns out
Posted on Nov 20, 2009
Toro dingo drives forward slowly but rev is ok
have you greased and oiled the machine, changed the oil. it sounds like the oil. the oil pump start to fail, causing metal to metal reaction,
Sep 16, 2015 | Toro 2007 Dingo Tx420 Walk Behind Mini...
Is it left handed steering original for mitsubishi dingo
dingo is not native to USA so if it came from another country other than the USA the the answer is yes
Apr 14, 2015 | Mitsubishi Cars & Trucks
Power steering stiff after recon steering turns pump works steering stay stiff and hard no power steering even if you start the engine
Check the drive belt to the power steering pump and the level of fluid in the power steering reservoir.
Feb 18, 2014 | 1996 Honda Prelude
I installed a new GX 390 Honda engine in a Toro 413 TX machine. Motor starts, idles and full throttle fine, but when hydraulics,i.e. drive is engaged, motor dies.
you have a dingo, ugh
I would suspect a bad pump or wheel motor if the rpms are set correctly and no safety switches are causing it to die...
Dec 26, 2013 | 13 HP Electric Start GX390
I have a year 2000 toro dingo (walk behind). The I have a year 2000 toro dingo (walk behind). The motor runs great but stalls out immediately when I engage the track. To move forward or back. I checke
One of your hydro pumps are seized. this is causing the engine to stall when ever the torque is transferred to the pump. There are the small pumps (or final drives) under the engine. One or both need to be replaced
Mar 27, 2013 | Toro 2007 Dingo Tx420 Walk Behind Mini...
Hard steering 2002 nissan sentra
Rack may be contaminated or coming apart inside.
Jan 13, 2018 | Cars & Trucks
2001Dodge Durango power steering is stiff
Get it to a shop you may have a power steering censor leak. If your handy read on.. Check the fluid level if it's low don't add more change the censor first then refill. The issue is the fluid travels through the censor into your wiring harness to your computer and other censors shorting everything out. If your fluid is low pull the censor wire off it's next to the fill tank on the pipe connected to it, if you see fluid in that wire bring this truck to Dodge. Or as I said before if your handy and you suspect this is the case, wright back and I'll give you a call and walk you through this. This is a common serious problem the can destroy your computer and possibly you engine. It can be fixed for under a hundred dollors.
Apr 21, 2009 | 2001 Dodge Durango
Power steering
MOST LIKELY THIS IS THE POWER STEERING PUMP AND THE ELECTRIC ASSIST FAN UNIT CONNECTED TO IT. OFTEN THE FAN COVER WILL OR CAN GET CLOGGED, BUT MORE LIKELY IT IS THE PUMP. IF IT GOES OUT IT USUALLY DO SO SLOWLY. THE STEERING WILL BE HARDER BUT YOU WILL BE ABLE TO STEER. THE NORMAL COST FOR THE REPAIR IS $1000 WITH LABOR. IT DOES NOT TAKE LONG, BUT CONSIDER BUYING THE PART ONLINE AND DOING IT YOURSELF OR TAKE THE PART TO A COMPETENT GARAGE
AND HAVE THEM DO IT.YOU COULD SAFE HALF THE COST!
REALLY.
BH
Jul 01, 2008 | 2003 Mini Cooper
Garden Logo
214 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
