Question about Philips 55PP9363 55" Rear Projection HDTV-Ready Television
Timer accidently set to turn tv off. cant turn it back on
Need to reset the timer so the tv will turn back on
  • albertoes664 May 12, 2010
    I have problems with my philips 55PP9363717
    to hear a relay switch that turns on and off
    and will not start
    Guru:
  • 1,738 Answers
Unplug the tv for fifteen minutes or so.
Posted on Nov 20, 2009
I cant get the picture back on my tv it only has audio
Look for and use the reset control to undue what you did and restore set to factory settings.
Jun 23, 2017 | Televison & Video
How do i reset Clarity ctvl37w2hdf led tv or at least set the timer to off?
to reset the tv, hold the power button while you unplug the TV. Keep holding the power button for :15 seconds, then release it and turn the power back on. That should reset any timer.
Nov 25, 2014 | Hardware & Accessories
My Mitsubishi hd1080 tv will not come on when i turn the power button on the green timer light comes on but the tv goes back off
The TV reset may help you. If the timer was set by accident many of these TV's that have the sleep timer have this problem. Try the factory reset initialization.
Nov 19, 2014 | Televison & Video
Why does my tv turn off automaticly
Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. M Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. M Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. Malena!!
May 10, 2012 | Vizio Televison & Video
Replaced the lamp on my sony tv but it still says the lamp is nearing the end of its life when I turn the tv on....whats up??
Hello.
Lamp timer have to be reset in service menu of your TV. Without resetting it you will have this message every time you turn TV on.
I can not provide you with directions how to do it - it's forbidden by Sony for me to give information like this to the customer, because without proper training you can easy change some settings by accident that would not be restorative after all and it would cost you pretty penny to replace main board that have all memory settings.
I would advise call any local TV repair and ask them to show up and reset timer (shouldn't cost you too much, they don't need to open up TV or anything like it). Or search internet for specific information (but do it on your own risk).
Regards.
Russ.
Aug 18, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Blinking green timer light on front nearpower button keeps blinking, tv will not turn on, unplugged for 24 hours and tried again, also hit system reset and still nothing.
Thats a common problem when the caps on the DM need replacement. They will function fine untill power is interupted then the set will not complete the boot sequence when power is reapplied and the led will just continue to blink. Hers a link to the kit that will usually repair that issue the kit comes with instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
May 09, 2009 | Televison & Video
The timer on button flashes
The timer light blinking indicates a failure in the TV set. Either the vertical circuit or horizontal circuit has failed and needs repair. It actually has nothing to do with the timer circuit.
In my experience its probably a vertical output chip, smalla capacitor and zener diode. There may also be an open resistor.
Cost to repair in the 50-75 dollar range usually
Feb 24, 2009 | JVC AV-27020 TV
Tv won't turn on or respond
if its a sony bravio LCD the backlight inverter failed
Dec 06, 2008 | Televison & Video
My TV turns itself off and on by itself.
You have a timer that has been accidently set by someone by the remote control.
If you have an instruction amnual for the tv, it will tell you how to turn off the tv's timer.
Feb 13, 2008 | RCA P52930BL 52" Rear Projection...
Philips 55PP9363 55" Rear Projection HDTV-Ready Television Logo
53 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
