Question about Daewoo Vacuums
I want to **** the air out off a pipe place vertically in water without sucking any water
  • 576 Answers
Oh, I see how this site edits things now. The only way I know to do that is placing an air lock in between. If you can get a 5 gallon bucket with a lid and install 2 pipes into it. Run one to the vacuum and one to the pipe. eventually you will draw water into the bucket, but as long as you don't let the bucket get full, it won't draw water into the vacuum.
Posted on Nov 20, 2009
Shop Vac MAC 12-200D my shop vac is blowing air instead of sucking air. How do I fix it
this might sound silly but have you got the pipe in the blowing end instead of the sucking end hope this helps
Oct 09, 2016 | Shop Vac Vacuums
Foodsaver V3460 vacuum runs and sounds like it has reached the end of the cycle then seals bag.
then you do not have the bag in proper place in the sealer , mine has never failed .
Aug 05, 2015 | FoodSaver V3460 Vertical Vacuum Sealer,...
Troubleshooting dyson
Hi there, it's Jack at Dyson.
I'm sure we can help get your DC50 up and running as normal again. The best place to start is our online Support guide - it will walk you through each troubleshooting step, and help you to locate and remove any blockages: http://www.dyson.co.uk/support/dc50/dc50-multi-floor/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usualdc50
If you haven't washed the filters recently, this should also be done. We recommend washing both filters at least once a month, using cold water without detergent. Allow at least 24 hours for both filters to dry completely before replacing them.
I'm confident that checking for blockages and giving both filters a wash will restore full performance. But if you'd like any further advice after giving this a try, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 12, 2014 | Dyson Dc50 Ball Multi-Floor 2-Tier...
V3420 foodsaver will not suck out the air
Is the motor still running?
If so it sounds like a blocked pipe
Aug 09, 2014 | FoodSaver V3420 Smart Seal Vacuum Sealer...
I shampooed my carpet, loaded clean water twice and added the cleaning solution. Then it dawned on me, the carpet is wet and there is not dirty water return. What am I doing wrong?
Look for a place where the dirty water reservoir is not sealed. There is air being sucked in somewhere else instead of the bottom where it's supposed to **** the water.
Jul 20, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
My shop vac is not sucking anything only blowing air out of the open hole where the hose should go if I wanted to blow something. I want it to vacuum not blow out. The filter sleeve and dry cloth are...
I just had the same problem, the vac wouldn't suck in. Turned out to be because the filter was WET. It works great when I take the filter off before sucking up water or liquids! Not sure if this applies in your case, but definitely something to keep in mind. : )
Jan 17, 2011 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
My Hoover Floormate series H3032 won't suction wet or dry. I have thoroughly checked the hose for clogs or cracks and there's no problem there. I notice the float never closes but just hangs down...
Check again that the pipes aren't clogged. Check all the way through from where the muck goes in to where it's supposed to end up, paying particular attention to places where the pipe narrows, goes round a bend, or changes material.
Check the machine doesn't just need emptying.
Wet/dry machines usually have some sort of float operated stop valve to stop you flooding the motor when you've filled it with water. Make sure this isn't stuck shut.
Check everything from the impellor right back to where the muck goes in is airtight. It doesn't take a huge hole to lose you a lot of suction. Pay particular attention to places that are meant to come apart routinely, and places where hoses join to hard fittings. If in doubt, run the machine and listen for sucking noises.
If there's a filter between the fan and the air outlet (there usually is) make sure it is clean
Assuming the motor is running, check it is turning the fan impeller.
Hopefully, one or other of these will get you somewhere
Dec 09, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover carpet cleaner blowing not sucking
While the blower has different source that the sucking of water, the passage for the sucking of water needs to be cleaned to eliminate any blockage within the passage.
Apr 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Blowing warm air
Is there a part missing on the front of the dirty water tank? On some of these machines, there is block that you take out so you can insert the hose in its place. So if this spot is open, then it can't suck and will be blowing warm air.
Dec 15, 2007 | Hoover SteamVac F5914-900 SpinScrub...
My hoover floormate won;t suck/ suction anything!
Things to check: Check again that the pipes aren't clogged. Check all the way through from where the muck goes in to where it's supposed to end up, paying particular attention to places where the pipe narrows, goes round a bend, or changes material. Check the machine doesn't just need emptying. Wet/dry machines usually have some sort of float operated stop valve to stop you flooding the motor when you've filled it with water. Make sure this isn't stuck shut. Check everything from the impellor right back to where the muck goes in is airtight. It doesn't take a huge hole to lose you a lot of suction. Pay particular attention to places that are meant to come apart routinely, and places where hoses join to hard fittings. If in doubt, run the machine and listen for sucking noises. If there's a filter between the fan and the air outlet (there usually is) make sure it is clean Assuming the motor is running, check it is turning the fan impeller. Hopefully, one or other of these will get you somewhere. A.
Apr 06, 2007 | Hoover Floormate H3000 Upright Wet/Dry...
Vacuums Logo
69 people viewed this question
Top Daewoo Vacuums Experts
JoeVacs
Are you a Daewoo Vacuum Expert? Answer questions, earn points and help others
