Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer will not spin. I can hear it pump to drain but when it clicks to spin it just makes some funny noised and then the digital display starts flashing
  • 15,935 Answers
What is it flashing? the time remaining or an error code??
Posted on Nov 20, 2009
The drain pump of my whirlpool duet washer makes a ticking noise
Hi, Remove your strainer cover, located in the kick panel at the front, and use a mirror and flashlight to see up into the pump cavity. It sounds like there is enough debris in the strainer and pump to explain your problem. Remove any foreign material you find.
Regards, --W/D--
Aug 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't spin, but making funny noise and water drains
You have a broke motor coupling broken between the motor and transmission the part is not expencive but a little hard to explain how to put it in.
Mar 29, 2009 | Whirlpool Washing Machines
My washer will not drain or spin. It showa a "sud" error.
hello check the drain hoses make sure its not block check the pump
electrical wires make sure the pumps running check the drain pump filter if these do not work change the pump good luck
shaun
Mar 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer won't spin
Sounds like the whirling noise is the pump, pumping. Does it drain at all? Check the drive belt and make sure that it is not broken. This system uses a drive belt with a clutch system to agitate back and forth. The clutch system could be bad as well.
This might not be a cheap fix, these are the main components of the system
Mar 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer is making a funny noise
try removing the top cover to the unit, 3 screws across the back. after ermoving check to see exactly wehre noise is coming from. some times a solid "smack " witha screwdriver will quiet teh dispensor motor if needed
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer will not spin. pump drains well. low humming noise.
"low humming noise??" soundslike the pump trying to pump, did you try removing the lower acess panel and physically cleanout the drain pump filter?? sondsas if its still trying to empty water
Mar 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet front loader ghw9100lw error code F02
if your hearing clackling try and clean the pump and the hose leading into the pump for a coin ,,small ,,(dime),,,hair clip,,also its a must that you use he detergent,,or you sude up,,if you do use he your using to much,,now bleach the unit out on a normal cycle hot wash cold rinse with about a pint of bleach...and no you can purchase part of a pump..it comes as you see it in unit..onthejob
Jan 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Duet washer doesn't run through the entire spin cycle on heavy duty setting. Clothes come out of washer, naturally,WET!!!!!!!!!!!!!! Seems to spin out better on the normal cycle. spin cycle dosent...
If the drain time exceeds eight minutes, the water valves are
turned off and “F/02” is flashed. Press PAUSE/CANCEL two
times to clear the display.
NOTE: After four minutes the “Sud” error will be displayed,
then four minutes later the “F/02” error code will be
displayed.
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make
sure the pump is running.
4. Check the drain pump filter for foreign objects.
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer Making Loud Grinding Noise
not nesseccarrily your pump, possible you have a rear bearing going bad, which will sound as if a helicopter is coming through your laundry room. ( noisy pump can be the issue , honestly a better and cheapre problem to have) in order to determine if its apump problem you can remove the lower access panel and unplug the pump then start the spinn cycle, if it still loud the pumpms not hte issue.
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
