Question about Xerox Phaser 8400 Laser Printer
Blue color appears pinkinsh/now stripes and smudging
First the blues were printing a purplish pink. Then all four color printing was washed out and the colors were not true. Then light stripes. Now smudging. I have followed the suggestins for running the cleaning procedures to remove light stripes and smudging. It has only gotten worse. Any suggestions? Thanks!
  • 1 more comment
  • fennelln Nov 20, 2009
    Thanks for reading my post. There is no toner it is a solid ink machine. The maintenance cartridge says it still has 1,000 pages to print before it is due to be changed, and I am not sure if the maintenance cartridge has anything do with the problem. It is happening with all applications, even when I print out the diagnostic sheets from the keyboard of the printer.
  • mohamed vyadally May 11, 2010
    did you try a software reload of the machine?
    when last did you change toner? Does this happen when you print from a specific application or from all applications??
    Guru:
  • 110 Answers
Are you using third party ink? make sure your ink is xerox OEM. This will clogg up the inkjets and ruin the print head for ever, If you have always used the third party ink then you might want to get a new print head. . If you have used xerox ink then It sounds like the magenta reservoir has spilled over the cyan. This is caused by moving the printer and not waiting for the cool down procedure. Also you might want to change the print head wiper. If the print head wiper is over used it won't clean the print head properly and what that causes is for ink to build up and causes smudge. also make sure the drum maintance kit is still in good shape. (its the yellow roller on the right side of the printer. Well hopefully this helps .
Posted on Dec 03, 2009
Find Yamaha 0564 Deep Purplish Blue Metallic C (DPBMC) paint
Hi, Rebecca for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Amazon com Yamaha Motorcycle Aerosol Spray Paint 0564 Deep Purplish Blue...
Yamaha 0564 Deep Purplish Blue Metallic DPBMC
Yamaha 0564 Deep Purplish Blue Metallic 5815 AEROSOL CAN KIT OEM COLOR eBay
Paint Yamaha 0564 Deep Purplish Blue Metallic DPBMC DC MD VA Road Runners...
Spray paint that will match yamahas stock colors
Sep 20, 2012 | Yamaha Motorcycles
I need to know which connectors go to which O2 Sensors on my 2005 Jeep Grand Cherokee 4.7L 4WD. Can you help?
Hi, the easiest way to tell is by the signal wire color. These are the signal wire colors:
right front: dark blue/pink stripe
left front: dark blue/light blue stripe
right rear: Brown
left rear: dark blue/yellow stripe
Apr 17, 2011 | Jeep Grand Cherokee Cars & Trucks
Replace factory stereo with after market for 98 Dodge Ram 2500
Right Rear Spkr (-) Blue w/ Orange Stripe
Right Front Spkr (-) Blue w/ Red Stripe
Right Rear Spkr (+) Blue w/ White Stripe
Right Front Spkr (+) Purple
+12 Volt Ignition Wire Lite Purple w/ White Stripe
+12 Volt Battery Wire Pink
Left Front Spkr (-) Brown w/ Red Stripe
Left Rear Spkr (-) Brown w/ Blue Stripe
Left Front Spkr (+) Green
Left Rear Spkr (+) Brown w/ Yellow Stripe
ground would have to be connected directly to vehicle's frame
Jun 05, 2010 | Car Audio & Video
What wire colors do i connect to my old wires in my 95 dodge neon
For Dodge Neons:
Factory in-dash wire harness has 2 pc harness (black plug and gray plug).
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
Metal braid plastic connector attached to back of radio is the ground wire.
May 20, 2010 | Car Audio & Video
I have a 1996 dodge grand caravan with 8 speakers. Im hooking up a kenwood stereo but I can only get 4 speakers to turn on. How do I get the other 4 to turn on?
here is the wire digram hope it helps
Factory in-dash wire harness (this vehicle has a 2 pc harness)
that snaps into the factory radio
Black Plug
Gray Plug
Radio Wire & Color Code Information Page 2 of 2
Typical Dodge/Chrysler Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Spkr (-) Blue w/ White Stripe Purple w/ Black Stripe
B Left Rear Spkr (-) Brown w/ Yellow Stripe Green w/ Black Stripe
C Right Front Spkr (+) Purple Gray
D Left Front Spkr (+) Dark Green White
E Right Rear Spkr (+) Blue w/ Orange Stripe Purple
F Left Rear Spkr (+) Brown w/ Blue Stripe Green
G Power Antenna/Amp White (use for Infinity Radio) Blue
H +12 Volt Battery Wire Pink or Pink w/ White Stripe Yellow
I +12 Volt Ignition Wire Red w/ White Strip Red
J Radio Dimmer Wire Do Not Use
K Headlight Dimmer Wire Do Not Use
L Right Front Spkr (-) Blue w/ Red Stripe Gray w/ Black Stripe
M Left Front Spkr (-) Brown w/ Red Stripe White w/ Black Stripe
N No Wire
Metal Braid Or Plastic Connector Attached To Back Of Radio Is The Ground Wire
Feb 22, 2010 | Kenwood KDC-MP242
Ok, here is a list of the factory wires coming from the car that I have for hooking up a radio and there colors. Red wire with blue stripe, red wire with yellow stripe, brown wire with white stripe, brown...
Hello jlharris28, Here's the color code for the '92 Sentra: Radio Constant 12V+ Wire: Red/Black Radio Switched 12V+ Wire: Blue Radio Ground Wire: Chassis Radio Illumination Wire: Red/Blue Radio Dimmer Wire: Red/Yellow Radio Antenna Trigger Wire: N/A Radio Amp Trigger Wire: N/A Front Speakers Size: 5 1/4′ Front Speakers Location: Doors Left Front Speaker Wire (+): Blue/White Left Front Speaker Wire (-): Blue/Yellow Right Front Speaker Wire (+): Brown Right Front Speaker Wire (-): Brown/White Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): Red Left Rear Speaker Wire (-): Green Right Rear Speaker Wire (+): Blue Right Rear Speaker Wire (-): Pink It's better to use an aftermarket wiring harness that plug into the vehicle wiring. The Metra part number 70-1763 seems to be the correct one for your vehicle. Hope this helps.
Aug 12, 2009 | Car Audio & Video
Will not print blue
clean head cardrige and calibrate color cardriges.
Jun 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon i960 printer won't print in blue
Your problem is the print head. You can buy one from Canon for about $95, or find them new from dealers on Ebay for $60 to $70. For a less expensive fix, try to remove the print head and clean it. (You don't need any tools, just remove the ink tanks and pull the print head forward and out. Over time, the receivers tend to get dry & crusted ink on them. Note that the inks used are fast drying inks to keep your pictures, etc. from smudging after you print them. Try not to use solvent. I use q-tips and hot water, then dry using another q-tip. If this does not work, there are commercial cleaning kits available for about $10. Short of that, your choice is to replace the print head or the printer itself. My i960 prints such good quality color prints and normal color printing, that I would fix it rather than replace the printer. I hope the easy cleaning does it for you!
Jan 13, 2009 | Canon I960 InkJet Photo Printer
MFC-9840 prints vertical stripe ~2" from right edge on all color printouts
The first thing i would try to do is clean the corona wire on the drum unit. It might also be a faulty magenta cartridge.
Dec 07, 2007 | Brother MFC-9420CN All-In-One Laser...
Xerox Phaser 8400 Laser Printer Logo
494 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
