Question about KitchenAid Ovens
My "Probe" keeps beeping. I tried cancelling...no help. Tried heating oven at 400 degrees as suggested by one person (to take out the humidity....)for 15 mins. Helps for awhile but then starts beeping again. Any other solutions? My Kitchen aid oven model is KEB 5147DBLZ. Thank you. L Matsuda
  • wmatsuda Nov 20, 2009
    This is a Wall oven unit and is built in. How can I get to the inside? Thank you.
  • 6,927 Answers
The top oven the stove will lift up,with effort,and fold back,unplug first,and see if it needs cleaning and the sensors are in there I think,clean them,try to unplug it to reset,see if that helps.
Posted on Nov 20, 2009
  • Ronny Bennett Sr.
    Ronny Bennett Sr. Nov 20, 2009
    It will have to be removed,from the wall,try and kill the breaker and turn the breaker back on after a minute.
Have a frigidaire wall oven that won't get to 400 degrees
Hello Bruce Hubley, thanks for your post!
Based off the information you have provided your Frigidaire wall oven will not heat up higher than 400 degrees. It may be a problem with your thermostat or control panel. I would recommend performing a reset on your oven and you can do that by disconnecting power from your oven for roughly ten minutes. If this does not help correct your issue I would suggest having a professional come out to provide the proper repairs on your oven. Best of luck! -Matt
Jan 25, 2015 | Frigidaire Ovens
My oven is keep beeping and I can't cancel it
Good Morning Friend, that's a great question!
Typically error code F10 indicates that your Frigidaire range has detected an issue with the runaway temperature (overheating). Let's attempt reprogramming your range by either unplugging it or flipping the household circuit breaker off. It is best to wait roughly ten minutes and then turn on your range. Usually this will clear most false error codes. If issue persists, at this moment I would suggest contacting a professional to proceed further. Most likely the RTD Probe (Resistance Temperature Detector) or the EOC (electronic oven control) will need replacing. Hope this helps! - Z
Aug 13, 2014 | Frigidaire Ovens
My KitchenAid Superba oven is not heating. Code F2- E5. thank you
Hello and sorry to hear about your problem. The code you have given, will have this problem. I suggest you contact a service person.
F2-E5 - Cancel Key Line Open - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure. Select the 'cancel' function and wait 60 seconds. If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
I have tried to help you. Please help me by Vote/Rate the response. Thanks and good luck
Dec 20, 2010 | KitchenAid KEBC107 Electric Single Oven
The oven temperature isn't correct. Ovenw Won't heat up.
has the oven got a fan on it. if so then maybe fan is faulty.
if convection oven then maybe one of elements is faulty
or the thermostat is a problem
regards
richard saupe
Appliance repairman colchester
appliance repairman
Mar 14, 2010 | GE Profile JT915 Electric Single Oven
Keep getting a message that says 'remove probe' but we don't have a probe in. Hit 'cancel' and tried reducing the temp on the oven when this message came up ('remove probe'). I hit 'bake' and tried to...
You might want to try and use a q-tip and some rubbing alchohol and try to clean the inside of the probe connector in the oven. Some liquids or something might be in it causing the control board to think the probe is connected. Make sure to do this procedure with the range unplugged. Then wait about 20 minutes before plugging the range back in. Hopefully that will stop the issue. If not could be a control board problem.
Nov 26, 2009 | Ovens
Superba convection oven probe display problem
I had a similar problem today with my KitchenAid Superba wall convection oven (2002 model). I was roasting tomatoes at 225 degrees F for 3 or 4 hours when the control pad changed and showed that the probe was in use (never have I used it and had to look for it). I, too, tried to plug in the probe and take it out, but nothing changed. My worry was that I could no longer use the timed bake function. After trying to reset by turning off the oven at the breaker, with no change, I turned on the oven to 400 F and left it on for 10 - 15 minutes hoping that the high temperature would dry out whatever moisture that must have gotten in the place where the probe connects. Then I turned it off and just waited. After a half hour or so the control pad cleared and nothing showed (that is what you want when the oven is off!). Everything is back to working now.
Sep 08, 2009 | KitchenAid KEBC107 Electric Single Oven
Dacor oven beeps and shows F1 code
-F1- Alarm “System Watchdog Circuit”
The system will detect a failure in the internal watchdog element relay circuits and will activate a
cancel feature. F1 will be displayed in the time digits and will beep until the cancel button or another
function is selected. An F1 failure could be detected in cook or time of day mode. With an F1 failure
the ERC is picking up a command to supply heat without receiving an input from the membrane. The
watch dog circuit is designed to prevent this.
If the beep continues after pressing cancel check the main control (ERC)
Dacor
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 20, 2009 | Dacor ECS130 Epicure Electric Single Oven
Re.probe and bake
I had the same problem and pulled off the contorl panel and removed the ribbion looking thing. You might have to do this a few times and wiggle it a little. It took me about 4 trys to get it to stop. also you can lock the control panel and the beeping will stop...this was my temp fix until I figured out how to get the control panel off and what to do.
Oct 11, 2007 | GE Profile JTP56 Electric Double Oven
Ovens Logo
152 people viewed this question
Top KitchenAid Ovens Experts
Craig Butler
Craig Butler
Jim Goldsmith
Jim Goldsmith
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
